heart-of-wessex
Hello all,
Even though my top loco of all time is the racehorses, especially D9000, there is a couple of things I am stuck on, can someone help me answer the questions?
1. Clag. AFAIK it is not actually clag, its just a normal proceedure that the engine causes, but what exactly? I know usual clag is overheated or broken injectors, but is the Deltic white plumes to do with a 2 stroke engine or something?
2. The second engine cut in. When does this actually happen, is it 20 or 25? And when the train reaches this speed I presume the 2nd engine powers up to whatever notch the train happens to be in (and I guess when re-applying power from 0 at, say, 80mph, the 2nd engine works with the 1st immediatley in tune, or is there a delay between the two?)
3. how many times does it work through the field diverts? I know it sounds like the engine is winding down a notch for a whilst before powering up again, I forget how many times and it there is certain speeds this happens at?
any help appreciated!
cheers,
James.
cheers,
James.
