John Bull @garius
So there's been some press out there blaming a
@Crossrail train on testing for causing the Paddington delays. This is wrong. It was a new GWR 802. Here's the damaged unit. And if you're a train nerd you'll spot something weird about it. Let's play detective!
#rail /1
10:25 AM - 18 Oct 2018
So it's clear now that a pantograph (the bit that gets power from overhead) went up when the train was travelling over 105mph in an area where no pantographs should be raised while moving (oops). BUT... what's interesting is that the HEAD of that pan appears to be intact
/2
So, if the HEAD didn't cause the damage, that means the other bit must have done - the joint bit (also known as the elbow). Oh dear. So how does the ELBOW go up, but not the head? /3
Well digging around for unit numbers shows that this particular unit seems to be Italian made and pretty 'fresh off the boat'. Oh dear. There have been claims of workmanship issues with the Italian IEPs (over the Japanese or local ones) for a while...
/4
But still - how does the ELBOW go up on the second pan, not the HEAD?! Oh... oh wait. Test run... fresh off the boat... The pans are meant to be secured down at BOTH ends (elbow and head) during transit aren't they? But, what if one of them kinda... wasn't? /5
Let's say you're strapping down the pantographs in Italy, and maybe not concentrating as much as you should. Let's say you make a bit of a boo-boo on one and only strap it down at the head. Let's say the quality control officer is also not really paying attention. /6
Let's say - hypothetically - that this train then goes all the way from Italy to England head first, so the strapped down end is always travelling INTO the wind. Nobody is going to notice are they? /7
Let's say that the first time that GWR 802 then runs elbow-first is on speed test run. Those those lovely little - but surprisingly aerodynamic - GWR 802 elbow winglets are now facing into the wind... ...SO FLY LITTLE PANTOGRAPH ELBOW! DON'T LISTEN TO THE HATERS! FLY! FLY! /8
...and that would be one way you'd strip 500m of old-but-still-kinda-important OHLE tech off of the main line. Oops.
(And double expensive oops if you're Hitachi, who supplied the train...) /END
