Do trains run service for BST and GMT tonight due to clocks changing?
9 Mar 2009
Was thinking while on Train today about train services that run overnight tonight from Manchester to York and wanted to know so they run say a service at 01.30am brit summer time and then when the clocks go back again GMT? or do they change the clocks when no services are running?
SS4
30 Jan 2011
There is a similar thread (albeit about the clocks going forward) here
Post 9 in that thread
*pulls WON out*
Summarising slightly (because I'm not typing it out in full):
1. Adjustment of clocks in railway premises - at 0100 GMT signaller resets clocks to 0200 BST. At places closed at the time the change operates, clocks must be changed by the last person on duty on Saturday 26th March.
2. Train services - trains to due to commence their journey before 0100 should run as if GMT still applies. Trains due to commence their journey at or after 0200 will run at BST. Train crew booking on times should be adjusted accordingly. Any times between 0100 and 0200 should clearly indicate whether they are BST or GMT.
3. Records and journals - must show the actual time of train running in GMT until 0100 and BST thereafter. Records between 0100 and 0200 should show whether they are GMT or BST.
Just change BST and GMT around where appropriate <D
Peter Mugridge
8 Apr 2010
Epsom
I wonder.... at the spring change, if there was an hourly overnight service, presumably one would be cancelled and at the autumn change they would add an extra one in?
radamfi
29 Oct 2009
Looking at http://traintimes.org.uk/vic/gtw/00:59/30-Oct
There would appear to be two trains leaving at 01:00 from London Victoria towards Gatwick. I suspect the journey planner is a little confused, but I would imagine that this means that there is one leaving at 01:00 BST, and then another at 01:00 GMT.
According to my friend who has access to past train times, the first 0100 train to Brighton ran but the second one (i.e. at 0100 GMT) was cancelled. Was the second one really cancelled or was it never really intended to run? Would passengers wanting to go from London to Brighton at 0100 GMT be entitled to a taxi from Three Bridges after getting the 0200 GMT train?
Mojo
7 Aug 2005
The 01.00 from Paddington to Reading only ran once (at 01.00 BST) and was shown as this in the journey planners/departure boards.
Crossover
4 Jun 2009
I thought this may crop up today so thought I'd have a look at how things work when the train is mid-service and it seems that the Live Departure Boards change system time but the train runs under the normal time - sure to help the PPM!!!
Service 2A94 - 0100 (BST) London Victoria - Brighton
Code:
[B]Location 	  	Sch Dep.  	Exp Dep.	Lateness[/B]
London Victoria		0100		0102	 	2
Clapham Junction	0108 		0108	 	On time
East Croydon	  	0122 		0122		On time
Purley		  	0127 		0128 		1
Horley	 	  	0138  		0143 		5
Gatwick Airport		0147 		0147 		On time
Three Bridges 	  	0152  		0151 		-1
Haywards Heath 	  	0206  		0105 		-61
[B]			Sch Arr		Exp Arr[/B]
Brighton		0223 	  	0118		-65
radamfi
29 Oct 2009
But that was the first 0100 train. What about the cancelled one an hour later?
Nicholas43
16 Jun 2011
Radley
If we stayed on GMT all year, but the expectation was that typical working hours would be (say) 9 am to 5.30 pm November to March, and 8 am to 4.30 pm April to October, could the train companies cope with changing the timetable (instead of the clocks) to deal with the different peak travel times in winter and summer?
In the UK, sunrise typically varies between 4 am and 8 am (GMT). There is therefore a case for varying the typical working day, in four steps, from 5 am to 1.30 pm GMT (June and July) to 9 am to 5 30 pm GMT (December and January). Could the train companies cope with that?
amcluesent
19 Dec 2010
I suppose the TOC with a delay/repay scheme are happy as they had an "extra" hour to complete overnight journeys?
MCR247
7 Nov 2008
"2A94 London - Brighton (the second one) didn't run because a member of train crew was unavailable" but that could just be an excuse given instead of saying the real one?
GB
16 Nov 2008
Somewhere
Why would you wan't to go to the great expense and hassle of changing the timetable and working hours rather than just changing the clocks?
Most businesses do not revolve around how much day light there is anyway.
Crossover
4 Jun 2009
2A94 did run but 2A04 did not and I believe I saw what you saw, that it was cancelled due to lack of train crew.
To be honest, it could well be the case as if you end up with two trains at 1am, the stock/staff required to run it may still be out elsewhere so cancelling it due to lack of train crew could well be a valid cause
9 Apr 2011
Over there
This may have been discussed on another thread, but if we stayed on GMT all year, sunset on Jun 21st in the south would be around 8.30p.m. and it would be dark soon after 9.
This would be even more noticeable by mid-August, when it would be dark by 8 p.m.
I am not sure this would win much support with the holiday trade.
SS4
30 Jan 2011
One might be tempted to say they're doing so already with their Draconian definition of Peak.
eg: < 9:30am is often peak = no change
1600-1900 is also peak = no change
