Doubling back within same Routeing Group
maniacmartin
15 May 2012
Croydon
Hi all,
I have a quick routeing question. Is doubling back allowed if staying within the same routeing group?
The journey in question is Bletchley to Euston, and I wish to travel to Milton Keynes, changing to a fast train there. Bletchley and Milton Keynes are both members of the Bletchley routeing group.
NRE shows this as a valid journey, and trainscanbecheaper says permitted by map EN. Is this the reason why its permitted, or is there another rule at work here?
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
Both the origin and destination need to be outside the routeing group for doubling back to be allowed under the group stations rule.
NRE shows it as needing two tickets: "You need to buy multiple tickets for this journey". Looks like perhaps a little bug in trainscanbecheaper; I'm not sure why it's saying it's valid.
maniacmartin
15 May 2012
Croydon
I wasn't aware that NRE showed routes that need multiple tickets. I'll have to check more carefully in future.
John @ home
Fares Advisor
1 Mar 2008
Doubling back is allowed within intermediate routeing point groups, that is groups whose stations are neither the origin nor destination of the relevant journey.
National Routeing Guide - Instructions said:
GROUP STATIONS
Some stations are grouped together to improve interchange between trains by offering customers access to a wider choice of train services and station facilities. A customer may travel via any station in such a group, including doubling back, provided that the group is on one of the permitted routes between their origin and destination stations. This extended availability is for interchange purposes only and does not apply where the origin or destination stations are part of a group.
http://www.atoc.org/clientfiles/File/RSPDocuments/instructions.pdf
Bletchley Group comprises Bletchley and Milton Keynes only. Therefore a Bletchley - London Terminals is not valid via Milton Keynes, but both versions of the Fenny Stratford - London Terminals ticket (route Any Permitted and route Via Bletchley) are valid via Milton Keynes. It is, however, often cheaper to buy more than one ticket.
CheapAndNerdy
17 Jan 2010
You need to select the fare for an individual journey and then look down to the Ticket section to see that multiple tickets are required. I think the NRE website could make this clearer by indicating the need for multiple tickets alongside the fare, without requiring that the fare first be selected.
Brucey
7 Jan 2010
Doubling back is allowed within intermediate routeing point groups, that is groups whose stations are neither the origin nor destination of the relevant journey. Bletchley Group comprises Bletchley and Milton Keynes only. Therefore a Bletchley - London Terminals is not valid via Milton Keynes, but both versions of the Fenny Stratford - London Terminals ticket (route Any Permitted and route Via Bletchley) are valid via Milton Keynes. It is, however, often cheaper to buy more than one ticket.
So a Bedford to London Zones 1-6 (Travelcard) is valid via MKC? This is never something I've even considered before and ended up always travelling from Bletchley.
I'm thinking here about travelling at weekends, where an Any Permitted from MKC is £26.40 whilst it is £20.00 from Bedford.
(Before someone says something, I know a £20 LM only or VWC only is available, but sometimes flexibility is nice)
IanD
18 Sep 2011
Newport Pagnell
Flexibility is always nice especially if it doesn't cost extra! This would be great for weekend days out.
Unfortunately, I can't get any of the booking engines or NRE to give a 'single' return ticket from Bedford to London via Milton Keynes so would probably need to take loads of documentation to prove the validity.
Brucey
7 Jan 2010
Bedford to London tickets are issued to London Thameslink. So I was thinking along the lines of an outboundary Travelcard.
bb21
4 Feb 2010
Map LM clearly permits Bedford Group - Bletchley Group - London Euston for travel between Bedford Group and London Group. This allows the holder of a
Bedford Stations - London Zones 1-6
Route Any Permitted
Super Off-Peak Day Travelcard
£20.00
ticket to take the route via Milton Keynes.
tony_mac
25 Feb 2009
There has been some discussion questioning if the line 'This extended availability is for interchange purposes only' implies that you cannot start or end your journey in these circumstances.
If it doesn't operate the barriers, then it may cause some problems with the staff.
Brucey
7 Jan 2010
I would agree with this. Seems fairly clear. My situation above would be used from Woburn Sands anyway (between Bedford and Bletchley).
SickyNicky
Verified Rep - TrainSplit.com
8 Sep 2010
Ledbury
It was allowing double backs in groups even at the start of journeys. I have fixed the bug and it correctly shows it as not valid now.
