Drop in passenger numbers sees train services cut
reddragon
24 Mar 2016
Churn (closed)
https://www.gwr.com/travel-updates/live-network-updates/disruption-information
High Speed Services
On the following long-distance routes there will be 1 train per hour in both directions:
• between London Paddington and Bristol Temple Meads
• between London Paddington and Swansea
• between London Paddington and Worcester Foregate Street
• between London Paddington and Plymouth*
*Please note: Services between London Paddington and Plymouth will alternate between a stopping service in the first hour, calling at Newbury, Pewsey, Westbury and Castle Cary (between 23-28 March, due to planned engineering work, this service will terminate at Castle Cary) and a fast service between London Paddington – Taunton – Plymouth in the second hour.
An hourly shuttle service will operate between Penzance and Plymouth with a varying calling pattern to intermediate stations.
A two hourly shuttle will operate between Swindon and Gloucester.
London and Thames Valley
An hourly service will operate on the following routes:
• between Reading and Basingstoke
• between Didcot Parkway and Oxford
• between Reading and Redhill
• between Reading and Newbury / Bedwyn
• between London Paddington and Didcot Parkway
The following branch lines will operate with a reduced service with amended timings:
• West Ealing – Greenford
• Slough – Windsor
• Maidenhead – Marlow/Bourne End
• Twyford – Henley-on-Thames
GWR states Sunday service but WTT shows a Saturday service on Thames Valley on Monday
LNR basically a Saturday service - quite surprised as that's basically almost no actual cut, just no peak extras.
Avanti:
- Hourly Liverpool/Manchester/Glasgow/Wolves
- No Scottish via Brum service
- Chester 1tpd each way, Holyhead 1tpd each way (this is a surprising axe)
- 0.5tph Chester-Birmingham via Stafford (an odd addition!)
Avanti:
So that's 4tph out of Euston instead of 9-10tph.
The Birmingham-Chester replaces the Birmingham-Scotland as far as Crewe, connecting with the Euston-Glasgow which calls at Crewe.
No Euston-Crewe-Manchester either.
That explains why TPE are concentrating on Preston-Edinburgh, with Avanti operating only to Glasgow.
They clearly cooperated on the north WCML timetable.
Presumably GC will not start their Blackpool service in May (no Avanti Blackpools either, or Salops).
The reductions are quite severe really.
Sunday service on TfW, so 2-hourly Birmingham-Salop-Chester and only a couple of Cardiff-Holyheads.
Manchester-North Wales reduces to an hourly Manchester-Chester shuttle, connecting into an hourly Crewe-Holyhead.
Strangely, the new Liverpool-Chester remains hourly.
PHILIPE
14 Nov 2011
Caerphilly
TFW will be operating a Sunday service but as the Sunday service starts later, there will be some enhancements in the morning before the normal start up
hwl
5 Feb 2012
With the proposed EMR service levels this means EMR could withdraw the existing VP185 HST sets over the weekend, will they?
johntea
29 Dec 2010
Many ‘leisure’ destinations now set to close from tonight, which I assume will drop passenger numbers by quite a spike! (Even though they were previously advised not to go out unless essential...)
infobleep
27 Feb 2011
Well the North Downs Line are not getting a Sunday service that is for sure.
Has anyone got examples of stations that won't have a train service from Monday or will have a greatly reduced one?
South Western Railway Twitter staff say that passengers for Wanborough have use the Kite bus but the Wanborough Rail Users Group claim that is the other side of the parish and not much use.
@grantshapps “We are...ensuring key worker heroes can get to their jobs to keep this nation running." Unless they have the bad luck to travel from #Wanborough, in which case they have no means to get to work at all. @SW_Help why can you not ask @GWRHelp to add stops? #abandoned
@SW_Help please could we have an answer to the question? Your network map shows GWR services running through #Wanborough, but it is impossible to use them to get to and from work: four a day in each direction and not at practical times. Why can you not ask @GWRHelp to stop 1/hr?
Kite buses are not a workable alternative for the vast majority of people who take the train because they run at the wrong end of the parish, unlike in Ash and Aldershot. Why are you not asking @GWRHelp to stop one train an hour at #Wanborough ?
https://twitter.com/users_rail/status/1240964429254201347?s=19
A member of the Twitter staff did at least say they would investigate further.
Worth noting that during the SWR strike, GWR didn't add in any extra stops and although SWR didn't run a bus,L for most of the strike, they did over the Christmas works around Guildford, which is when less people would have been travelling. They works were prearranged and a bus would have been requested as no doubt one has been for the Easter works.
JN114
28 Jun 2005
GWR North Downs will be hourly Redhill stopper from Monday
syorksdeano
7 Jan 2011
Northern have just announced their revised timetable, and it certainly takes some reading and understanding
infobleep
27 Feb 2011
Indeed, which isn't a Sunday service. That's all the point I was making, in case anyone through all Thames Valley services were a Sunday service from Monday.
infobleep
27 Feb 2011
Just noticed on Monday that between 23:00 and 0;00 there will be four fast trains from Waterloo to Guildford. That seems overkill.
Will these be running for stock positioning moments, but run in passenger service as they can?
In contrast between 19:00 and 22:00 here will be just one train per hour. So three trains in three hours vers four in one hour! Most of the day it is two trains an hour.
They have done well to put up the timetables this far ahead. I guess having the strike timetable to work from has helped.
Edit: I just looked up Real Time Trains Nd the answer seems to be yes. The 23;15 runs to Fratton once it reaches Portsmouth Harbour.
WatcherZero
25 Feb 2010
Everything between 5pm and 6pm Daisy Hill towards Wigan was showing cancelled today at the station, luckily finished work a little early and managed to catch one at 4:56 otherwise I would have been screwed again.
There were the planned cancellations but also all the services that were supposed to be still running were cancelled due to lack of drivers.
I am a key sector worker (Company manufactures medicine) but am expecting now total collapse of public transport at some point next week and so being unable to reach work.
hwl
5 Feb 2012
I am wondering if special security / monitoring arrangements are in hand for the Tesco trains. Thinking of 1963 .........
The Daventry - Inverness Bog Roll delivery being held up would add a certain level of surrealism to the the current situation!
WatcherZero
25 Feb 2010
At work Weve put our loo roll supplies in the cage where controlled drugs are locked up.
jon0844
1 Feb 2009
Looks like a full peak timetable has run on the GN side of TL
Given that many say that it's passengers that cause all the delays I hope everything ran to time ;):lol:
Pretty much. There were some cancellations here and there but I think the PPM has been in the 90s.
jon0844
1 Feb 2009
Thameslink are advertising short notice cancellations due to driver shortages will be happening until end of service on the 30th April, do they know something we don't?
A driver could opt to self isolate on the day, so surely every TOC must be saying the same? It's going to happen so people ought to prepare for alterations on the day that weren't on the system at the start of the day or before.
_toommm_
8 Jul 2017
It’s a big list of affected routes tomorrow. I really do wish I could work from home, but it’ll be interesting to see what Piccadilly looks like tomorrow morning...
MDB1images
9 Jun 2018
Northern will have a emergency timetable in place that gives a better guarantee of running than what some TOCs have witnessed this week as staff have fallen ill or been forced to self isolate so hopefully something in place that's less frequent but more robust so you can travel with more confidence to work.
bnsf734
15 Oct 2007
Nuneaton
I have looked at XC on Monday and the Birmingham - Leicester stoppers have been cut. There are no additional stops added on the Birmingham - Stansted fasts. This leaves Hinckley, Narborough and South Wigston with a large gap in service outside the peaks where the Stansteds do sometimes stop. In the case of Hinckley there is a gap in trains towards Birmingham between 0809 and 1809 and towards Leicester, between 0857 and 1658.
Nicholas Lewis
9 Aug 2019
GTR running Saturday service from 23/9 then Sunday service from 30/9. Totally understandable and better to go with something they can sustain just hope they have every train at maximum formation routes permitting
PTR 444
22 Aug 2019
Wimborne
Been checking the SWR website but they have no information regarding their reduced timetable effective as of Monday. Is there anyone on here from SWR that might have some idea as to what their proposed service pattern will look like?
Aictos
28 Apr 2009
Don’t think they are carrying bog roll. Should be ok.
Are they carrying bottled water as that was the other main product I've seen people go crazy for....
Where has this been confirmed please?
Close to the strike timetable.
Rich McLean
6 Feb 2012
Special Stop Orders will be added to these where possible. Will ask a friend of mine on the coal face at Cannan House for confirmation
