Highly doubt that is the issue, if it can't get the current it needs it'll just trip out the supply or pull the supply down to such a low a voltage that the device will not work, the sockets will also be normal mains for the area as there still is the chance that some supplies are not multi-voltage, even some switching supplies are not multi-voltage for technical reasons.
As to what happened here, I would assume it'd down to the filtering capacitors in the PSU, unless you put in enough inrush current limiting the primary (mains) side capacitors will draw a significant current when charging up, most laptop supplies will emit a spark from the plug pins if not "smartly" plugged in.
It's also why some devices have a much larger fuse in the plug than the wattage of the appliance would deem necessary, the startup/inrush current draw on some devices can blow a 3/5A fuse easily despite the device in use drawing less than 200W, there was a story on another forum where the appliance testers had replaced the fuses in their (decent brand) monitors from 13A to 3 or 5A due to the power rating, only for them to fail quickly as they couldn't handle the startup current, the manufacturer had used a 13A fuse for a reason!
