Elizabeth line ticketing
Tester
5 Jul 2020
Watford
You need to distinguish between an "Underground zone" ticket and a "via Underground" routing restriction.
An Underground zone ticket may be used on all interavailable National Rail routes, such as Chiltern Railways, c2c to Upminster, North London Line, Thameslink core, Crossrail central section, etc. However, if the ticket is specified to be Underground / DLR only in the routing field it is clear that you can't use the above, similar to a National Rail ticket which has validity on Thameslink core may be used on the Northern / Jubilee lines, but not if it is marked not underground.
In this case, the U Zone 1-4 portion allows you to use Elizabeth line from Abbey Wood, but the routing restriction forces you to use the Underground to access Ealing Broadway, therefore you need to get onto to the Central line to abide by the rule.
That is all, of course, factually correct.
But why.....?
redreni
24 Sep 2010
Slade Green
But why.....?
Indeed, and why does it make a difference to the fare?
Most people understood that the basic principle was to charge the same fares as London Underground on the Great Western line within zones 1-6. That's how it works on contactess and oyster, but if you want your off-peak Network Railcard discount you're presented with a fiendishly complicated menu of paper tickets, few if any of which are as cheap as they should be. It's almost as if TfL doesn't want the public to realise the Elizabeth Line is a national rail service in case they twig that they can get a third off when travelling off-peak.
I had an interesting conversation with the ticket clerk at Abbey Wood when I got back from Slough. Apparently they always sell tickets with the "underground from Ealing Broadway" restriction to destinations on the western section between West Ealing and Reading and they weren't aware of it causing any problems. The chap was firmly of the view that the wording "underground from Ealing Broadway" includes the Elizabeth Line as well as the Central and District Lines, so the ticket allows the passenger to make the whole journey on the Elizabeth Line. When I asked him if it was valid on GWR trains he thought not.
I did ask him why he would assume a passenger would wish to take a slow train to Slough in preference to a fast train to Slough after changing at Paddington and he said it was the passenger's responsibility to say if they wanted to take a fast train, which wasn't a point with which I found myself entirely in agreement.
I didn't try the ticket in the barriers at Paddington in the end, but if the people at Abbey Wood are not aware of any problems that would tend to suggest that the tickets are accepted in the barriers or, if not, the gateline staff at Paddington just let people through with these tickets. The chap said they sell a lot of them.
I'm no expert on train fares but I do have more of an understanding than the average passenger. I would argue that if I can't understand this ticket restriction, and not only that but two different, fully trained ticket office clerks working for TfL at an Elizabeth Line station can't understand this ticket restriction (or have a very different understanding than the expert members of this forum, at least), then something's not right.
It's not the fault of the people who don't understand it: it doesn't make sufficient sense.
