Interesting. The yellow route would be fine for vehicles, but the bridge under Queen Adelaide Way https://goo.gl/maps/ZKYbtBPpHpoLZ6e29 is a bit narrow to take a footpath as well as 2 lanes of traffic. It could be turned into a single track road with traffic lights, as with the underpass at Ely station. A footbridge with accessible ramps would be a bit of an eyesore.
The Eastern Crossing might be the least used but possibly the cheapest to address and also ameliorates the multi-crossing interaction issues some what.Good point, I hadn't considered that. I have used that track on foot or bicycle when the crossing has been closed for maintenance, but I admit I am not a standard pedestrian, and am happy to walk in the road. Of course, the Eastern crossing is the least busy, so it might not be worth doing anything with it at all, or do the road, and add the lights as you suggest, but leave the crossing in place as a CCTV controlled full barrier one, as you could see if it was closed and take the diversion only if necessary. Of course that might be taking everything too far and too expensive.
[Pedant on]*over[pedant off] The bridge is also 'a bit low' at 3.5m and would need to be raised, or perhaps more likely the road lowered. As the road is almost certainly at a lower level than the Great Ouse river some will now have a sharp intake of breath!Interesting. The yellow route would be fine for vehicles, but the bridge under* Queen Adelaide Way https://goo.gl/maps/ZKYbtBPpHpoLZ6e29 is a bit narrow to take a footpath as well as 2 lanes of traffic. It could be turned into a single track road with traffic lights, as with the underpass at Ely station. A footbridge with accessible ramps would be a bit of an eyesore.
The farm track joins Queen Adelaide Way far too close to the rail bridge to give adequate sighting. Any road junction would need to be futher south, possibly with a roundabout for extra safety.
None of this solves the issue of extra crossing barrier downtime associated with (even more) trains using a combined route.
The simplest thing to do these days (and probably most useful is probably a big wide spread APRN traffic survey for a fortnight to see what all the interactions are and what journey people are actually makingThat's always been my impression, since the public meeting. I assume there is a formula for network rail to use for the distance between crossings, expected road traffic flow and expected closed time, to give an idea of interaction problems. I wonder what it says in this case?
Survey has already been done!The simplest thing to do these days (and probably most useful is probably a big wide spread APRN traffic survey for a fortnight to see what all the interactions are and what journey people are actually making
There lack of parallelism in the junctions is another factor with ramifications not as straightforward as at first glance. It may limit the total number of trains possible to run through the junction, but it also prevents a number of movement combinations that with double junctions could pass each other in the area, using the same road closure. That becomes especially important if the crossings were converted to MCB with much longer warning time.
I assumed the improvements were going to at least put a ladder in between the Peterborough and King's Lynn lines. That, and a crossover north of the Norwich junction would allow a lot of simultaneous moves. Am I right in reading the track diagram as showing all the platforms are bi-directional all the way through to the Ely South junction and crossovers?
Traksy suggests that to be the case:
A further complication, as if one were needed, is that route would be across some of what is currently an open water part of the Ely Pits and Meadows SSSI [desig. 2008].
https://magic.defra.gov.uk/MagicMap.aspx?startTopic=Designations&activelayer=sssiIndex&query=HYPERLINK='2000642'
Ely Southern By-pass was authorized for construction at an estimated cost of £36m, during construction this was revised to £49m but I don't know the outturn figures. But it has been built, it is open, and is not the first Civils Project on this Island to be overspent.![]()
I understand the piles for the bypass viaduct are as deep as Ely Cathedral is tall, to give some engineering context....
That would make the pile depth 44m.The project to build the Southern Bypass around Ely has passed many major milestones from creating a unique, specially designed bridge with highly complex structures, to the depths of the foundations for the river viaduct being two thirds the height of Ely Cathedral.
I have been thinking about what to do here for a while, since it is a road I use a great deal, living in Prickwillow, and the recent conversation has given me a different idea. Not sure how viable it is, but in the attached image, the red line would be a new rail link, allowing the closure of the westernmost level crossing, and the yellow line is a existing farm track that could be purchased and relaid to close the Norwich line crossing. The orange line could be used to smooth out the road, for additional cost.
I see a few advantages to this over the use of the current West Curve bridge, it doesn't affect the nature reserve, allows large vehicles to get to the haulage depot from the east, and it doesn't involve much new OHLE (only where the current single lead junction is removed). I assume they want to change the junction layout anyway as part of any upgrade. It also doesn't cut the village in half, and puts the garage on the Ely side, so the owner won't be too upset at loss of trade, and there is no risk of one crossing queue running over another crossing. The disadvantage is obviously the remaining crossing is going to be closed a lot of the time, but that won't be too much of an issue, as there is a route into Ely via the road south and the station.
I would appreciate any criticism, I wonder what problems I have missed.
View media item 3392
So whats wrong with OD crossings?
No need really. The crossings at Peterborough, Lynn, & Norwich Roads (as they where known) work perfectly well as AHBs.Looking at your map I thought I saw or heard something suggesting that NR was already looking at a route similar to the red line on your picture.
I did a google car view along the road that refers to Queen Adelaide and was surprised to see all three crossings were of the AHB variety. Firstly is this correct and that Google car is out of date? If its still in date I'm surprised they haven't been made full barrier Crossing with CCTV supervision or Full Barriers as MCB OD Level Crossings.
Gosh it will be as deep as [insert ancient monument here] is tall soon!
Cambs CC quoted 2/3rds height of Ely Cathedral in their opening press release:
https://www.cambridgeshire.gov.uk/news/ely-southern-bypass-is-now-open/
The 'ground' as stated in lots of places is to say the least difficult. But it is what it is.
Around Ely North the railway is close to the edge of the Kimmeridge Clay and may not be quite as bad to the west of the line. But to the east ..... ?
Geological survey map:
http://www.largeimages.bgs.ac.uk/iip/mapsportal.html?id=1001668
I’ve been in Trowse SB ‘box and seen trains over the bridge in opposite directions less than 2 minutes apart. Yes it’s a constraint, but not that much, although swills will give a definitive view.
It’s the hell of a project, and always has been. The Civil Engineers who put the junction in 1992 squeezed a lot of speed out of it back then.
A wider curve looks plausible. At least 500m radius as shown here:
Even so, you’d be lucky to get 40mph through there, probably 30.
Also building new railway will face the same challenge as new road. There will need to be deep foundations.
Here's my development of the track reroute idea suggested above. This would involve reusing the old March-bound alignment for a rerouted road heading south to a new bridge over the junction into the Potter complex then exiting over their river bridge to Queen Adelaide Way. All three crossings would be eliminated for most traffic but the eastmost one would be retained for any local traffic that was overheight. It might be a MCB-OD that was normally closed to road traffic and opened on demand for vehicles that need it. The middle crossing might retain a pedestrian facility, perhaps a footbridge.
Yes, but that one stretch of lines foundations might be cheaper than a road that will in addition need at least 2 bridges over rail, and one over the river. Is 40 a problem? I have never seen a freight train move fast over the Peterborough crossing anyway, and all passenger trains stop at Ely, except one sunday service which uses the West Curve, so has to be slow for that.
I know there is no easy solution to this stretch of road, and I do want the rail service to be increased, so something has to give, but I think it quite unlikely they are going to pay the same or more as the Ely South bypass to fix a short section of road that has only 10,000 trips a day, so the road is going to get a bit worse. As long as they can remove some of the biggest risks.
I have no idea why people are so surprised by the ground conditions around Ely, or to give it it's olde name, Isle of Ely.That is bad ground!
