EMR Class 170 updates
TT-ONR-NRN
30 Dec 2016
Farnham
Do EMR 170s actually work in multiple with the 156s, or is this a data error?
Photo shows RealTime Trains and a service said to be operated by an EMR 170 and 156 in multiple, dividing en-route.
LowLevel
26 Oct 2013
They do operate like that but the rear set is locked out. It is for trains that are functionally shifting stock. There are a few to and from Lincoln to ferry units to and from Nottingham, in this case the 170 stabled at Cleethorpes last night and is required in Lincoln for it's next working.
This is another this morning, shifting a 158 and 170 from Derby to Nottingham.
Failed Unit
26 Jan 2009
Central Belt
Much better than the awful 156s which seem to frequent the route nowadays…
Actually if I have a bike I prefer the 156s as they have somewhere to put it.
EMR is a concern at the moment. You don’t know if you will be left on the platform or not. (Just like in the days with the 153s). Passengers are booming but getting an hourly service is mission impossible. Many of the trains on Grimsby- Leicester need 3 cars. But then I don’t know a single EMR route that can cope with demand.
STINT47
16 Aug 2020
In the short term overcrowding would-be eased if a full hourly service could be restored on key regional routes. Although it's better than a year ago there are still gaps on the Lincoln and Crewe lines leading to passengers crowding onto other trains.
In the long run three or preferably four carsneedsto become the norm on most regional routes. Nottingham to Crewe is getting really busy as passengersuseit to reach aces like Manchester and the North via the WCML at Crewe
liamf656
2 Aug 2020
Derby
The issue with adding more and more coaches to some routes is the length of the platforms, some stations only take two or three coaches
Introducing multiple 170s create operational difficulty if a whole unit is not platformed because the guard would then have to go through the trouble of making sure at the previous station that the passengers are in the right portion. In the case of the Crewe line, the 3 car 170 worked well with SDO only being needed at Blythe Bridge when they were allocated, however when 4/5 car 170s were used dwell times were increased
When 156/158s are brought into the mix it’s even more difficult. For example, some stations on the Skegness route are shorter than a 4 coach train and then would be local door only as Sprinters don’t have SDO. You could make use of the butterfly switch if the rear cab of the front unit is platformed but as far as I know it isn’t usually used at EMR, but I’m sure someone more in the know would be able to provide more info with regards to that
Failed Unit
26 Jan 2009
Central Belt
When 4 car 15x have appeared on the Grimsby-Leicester route the guard needed to manually open every door on the platform form which didn’t help the dwell time and built up a significant delay down the route. At stations like Swinderby 1 door is fine. At many others they needed to open all the doors.
I certainly think restoring the full timetable will help. But the 158s really need SDO and using on routes with short platforms.
EMR really needs the proposed December 2022 timetable. Not sure if it will ever happen but then the 170s could cope. The have less seats then the 15x so from that point of view we have gone backwards.
Mugby
25 Nov 2012
Derby
The 170s which EMR have received seem to me to be a bit wasteful of space.
Would it be possible to fit a few extra seats if one or two tables were removed?
Rick1984
23 Aug 2012
Do some of the class 170s not have declassified 1st class areas as well? These would need changed regardless of the refurbishment
rjames87
9 Apr 2010
I find the Lazzerini seats on the XC / WMT 170s really uncomfortable, so many are broken too. They also don’t give much leg room being a larger seat.
Class172
Quizmaster
20 Mar 2011
West Country
Seats are always very subjective, I personally find the Lazzerini seats amongst the most comfortable on the network.
43055
8 Mar 2018
The ex Scot Rail and ex TfW one has declassified 1st class sections.
liamf656
2 Aug 2020
Derby
Cheers. A shame as I never got the chance to ride it with EMR!
A link to 5M66 as mentioned above
morgainelive
27 Jul 2017
Looks like 170s are out and about again on the Liverpool Norwich route and as 2 cars. I really cannot see how this lobg distancecservice can continue like this especially those going all the wsy to say Nottingham or Pboro?
LowLevel
26 Oct 2013
Traction shortage is pretty critical so alas anything goes. A work task is apparently starting shortly to come up with a method of work for class 158 and 170 to work in multiple if need be which should as the fleet balance shifts towards 170 help matters.
scotraildriver
15 Jun 2009
What are the main issues with a 158/156 working in multiple with a 170?
Lack of gangway?
Scotrail have been operating 170/158/156 combos for over 20 years. The only oddity it the vigilance doesn't sound when the doors are open.
43102EMR
28 Mar 2021
Lack of gangway?
It used to happen a lot in the Central Trains days - can imagine it’s more a case of the paperwork/potentially certain mods being signed off before they’re allowed to work in multiple in passenger service.
Path in place for next week’s move from Selhurst to Etches Park.
170UTD
14 Mar 2022
Lincolnshire
I saw in Modern Railways that the three two-car TfW 170s are expected before the end of the year. Does anyone have a time frame for this?
43102EMR
28 Mar 2021
I'm wondering if they go off lease in December like the Angel Trains owned 156s for EMR?
If the 156s are expected to go off lease then, I think it’s a reasonable timescale; no doubt the Mk4 introduction on Manchester-Swansea services will create an internal cascade that’s enabling the 2 car 170s to be released.
Wyrleybart
29 Mar 2020
South Staffordshire
Wouldn't that depend on the continuing delay in class 197 and class 230 introduction though ? That also of course takes into account the Northern class 150 loans to TfW
