EMR Class 360's
221101 Voyager
17 Nov 2019
Milton Keynes
Not quite if it's a prototype unit. Most prototypes take sometime - otherwise you could apply that logic to the ScotRail 153s!
I suppose so. I've heard no news about those 153's for a long time.
Anyway back on topic, I think these 360's will look good with a good refurb and lick of paint.
James321
26 Jan 2018
Hello, Are some 321s covering the normal booked class 360s service to Clacton & Ipswich during daytime?
Defiance149
30 Dec 2013
It was 360116, video on YT confirms with readable numbers. Only one car of it went to Kilmarnock and that was for a repair to a minor bump, came back a while ago,
Alfie1014
27 Jun 2012
Essex
Yes for example the 11:05 ex Clacton on a weekday used to be 4 x 360 when I’ve seen it recently it’s been 8 x 321. Yesterday the service seemed to be almost exclusively 321 operated including the Norwich’s which were terminating at Ipswich due to engineering works. That said as Clacton was blocked also due to engineering work many 360s May have been tucked up in bed there.
DBS92042
13 Apr 2019
360116 went back to Ilford yesterday and 360113 came up to Northampton today. 47727 & 47739 providing the power this week
43055
8 Mar 2018
Just updated the list on the rebranding thread, Here is the 360 section. Would you prefer this being updated weekly (when the moves happen and numbers are known) or just when I update the main list on the EMR rebranding thread?
Class 360 (only showing units which have 110mph modifications)
360102 - Blue with Greater Anglia Fleet names (returned to Anglia)
360105 - Blue with Greater Anglia Fleet names (returned to Anglia)
360106 - Blue with Greater Anglia Fleet names (returned to Anglia)
360107 - Blue with Greater Anglia Fleet names (returned to Anglia)
360108 - Blue with Greater Anglia Fleet names (returned to Anglia)
360111 - Blue with Greater Anglia Fleet names (returned to Anglia)
360112 - Blue with Greater Anglia Fleet names (returned to Anglia)
360113 - Blue with Greater Anglia Fleet names (at Northampton)
360114 - Blue with Greater Anglia Fleet names (returned to Anglia)
360116 - Blue with Greater Anglia Fleet names (returned to Anglia)
360118 - Blue with Greater Anglia Fleet names (returned to Anglia)
360120 - Blue with Greater Anglia Fleet names (returned to Anglia)
360121 - Blue with Greater Anglia Fleet names (returned to Anglia)
221101 Voyager
17 Nov 2019
Milton Keynes
Having it on here makes it easier to find rather than having to scroll through the EMR thread looking for the list. ;)
colchesterken
Are there any external changes for spotters to observe to identify the upgraded units, from my back garden they all look the same!
Domh245
6 Apr 2013
nowhere
Depends how good you are at spot the difference! The only external mods are horns, windscreen wipers, headlights and pantograph.
Checking flickr for before & after images, the only differences I've been able to spot are slightly smaller horns, two washer pipes on the wipers rather than one, and a slightly sleeker pantograph head without 'lugs' at the bottom of the horns. Can't spot a difference between the headlights, it may just be the case that it's a brighter bulb
43096
23 Nov 2015
The next 5Q60 is en route from Ilford to Northampton as I type.
43055
8 Mar 2018
Copied over for you from the big list :)
360103 - Blue with Greater Anglia Fleet names (at Northampton)
360113 - Blue with Greater Anglia Fleet names (returned to Anglia)
Ethan1852
10 Jul 2020
Leicestershire
Could it be added tomorrow once the 360 returns to Ilford?
It might be added tomorrow.
Also don't know if it has been mentioned already but the overhead wires between Bedford and Corby were officialy energised in august. https://twitter.com/13milepost/status/1297481999855345664
As another point the overhead wires south of Bedford can only handle speeds of up to 100mph. So when the 360s enter service they will probably be limited to 100mph until the overhead wires can be modified to withstand higher speeds.
Correct.
Mikey C
11 Feb 2013
With the current reduced demand for trains in service, maybe they can do the interior refurbishment more quickly?
py_megapixel
5 Nov 2018
Northern England
I doubt it. The reduction in demand at the moment is offset by each passenger needing more space (for social distancing) so the units will probably still be required.
