Reports I've seen online state that it moved from Wembley on either the 6th or 7th of January behind 37884.In the last few days? I could have sworn I noticed one there a couple of months ago but OI didn't really take any notice of it...
Trial conversion to the power car for the TPE 442 cascade?![]()
I can't resist...
How much power can one of these EPS coaches generate?
Mystery solved.
http://www.wnxx.com/16/1601/150116/96371.htm
From WNXX
"Former 'night star' generator coach 96371, one of five constructed, one other is at Wabtec while the other three at at Long Marston, has been brought to Leicester as part of a project to try to convert its power output to that of a conventional locomotive. If successful the generator coach could be used for stock heating/testing at places such as Ilford where a Class 86 has been used for the task."
Would it be nearly 20 years since it's generators were fired up? Also it looks to be in reasonable condition considering it was in open storage for so long, although inside and the generators are probably not too good.
2 x 350 kVA Cummins engines producing 1500V AC I believe!
I can't resist speculating that 'the power output of a conventional locomotive' could run the traction motors of a 442; couldn't it?!!![]()
ETH output, not traction output.
Thanks for that! Mystery solved then as you say, and as mentioned another is in use at Wabtec.
As for the generators, I'd have thought if the original generators are useable after a good service - then they can and will probably be used. With the way modern technology is going, it wouldn't be too difficult I'd have thought to replace it with something like the MTUs used in the Class 800s or 73/9s.
Is the one in Wabtec actually "in use"? If so for what? AFAIK unless heavily modified they couldn't power anything in the UK?
