Gaelan
Anyone happen to know the going rate for a TGV?Quite a blunt reference to them potentially being short of funds for an acquisition. Suggests perhaps lack of confidence in the venture?
€2.7B for 100 trainsets ordered by SNCF. 2018 prices, and includes a maintenance contract. So maybe €35M a pop for someone like Evolyn?Anyone happen to know the going rate for a TGV?
So plausibly within the €1B of funding they're claiming, though who knows how much of that was intended for rolling stock.€2.7B for 100 trainsets ordered by SNCF. 2018 prices, and includes a maintenance contract. So maybe €35M a pop for someone like Evolyn?
I would prefer it if they went after a different market. For better or worse, expensive Eurostar have largely sown up the air market to Paris and Brussels. When the Amsterdam service stops, there is little connectivity to compete with air, other than Strasbourg doesn't involve trapsing around Paris.Interesting that if this does succeed, it will be the only operator to operate double decker trains to the UK, it would provide Eurostar with some much needed competition and could lower prices if it were to succeed. Sadly I don't think that they will provide as frequent of a service as Eurostar, due to them only ordering 12, so it would be more what Lumo, GC and HT are doing to LNER.
There are as many as 52 direct flights a day on winter Saturdays!At this time of year, Geneva is ramping to 20 or more direct flights a day to London. It should be just over 5hrs from London not 7hr.
Last years top up order for 15 trains was €590m€2.7B for 100 trainsets ordered by SNCF. 2018 prices, and includes a maintenance contract. So maybe €35M a pop for someone like Evolyn?
Are you sure that you haven't dropped a 0? £200k / train / month = £2.4m p.a. would sound about right. That would amortise the train over 15 years bit bear in mind capital costs. Obviously it will depend whether the lessor bears maintenance charges, it might be a bit lower if not.Last years top up order for 15 trains was €590m
which is €39.33m per train, about £34.4m
So around £450m (perhaps £500m with inflation) for 12 trains
Alstom receives new order from SNCF for 15 additional Avelia Horizon very high-speed trains
This is an optional tranche from the Avelia Horizon innovation partnership framework agreement, for an amount of nearly 590 million eurowww.alstom.com
Roughly £10k per train per month if assume 30 year life (before financing cost)
So even if it is double with financing, £20k per train per month, use it say 20 days a month, (£1k per day), got nearly 1000 seats, then that is only £1 per seat per day. So if 2 round trips (4 journeys) then cost of train is about 25p per ticket. Even if train was only quarter full it's still just £1 per ticket
I wonder how many seats that is, and how many 400m double deck trains would provide the equivalent.There are as many as 52 direct flights a day on winter Saturdays!
The whole point of Schengen is that it should matter not which country the train stops in after London, let them exit stamp passports in London like they do in the other direction.
The 'shortage of space' at St Pancras looks rather deliberate. There is a lot of space at that station, both next to Eurostar in the form of various handbag shops, and also behind the EMR platforms that doesn't see much use.
“The decisive factors are technical and economic reasons: the ICE BR 407 is not yet registered in Belgium and the economic environment has changed significantly as a result of the price competition with low-cost airlines.
One reason cited by the spokesperson, that its train model is not registered in Belgium, is technically correct – though similar trains are now used through the tunnel by Eurostar under a different brand name, meaning obtaining clearance to run them should not be difficult.
It's the first time I see this claim. What's the source? And what would be the season for this refusal?I agree, but an issue is that Germany (among others) has blocked direct rail services from the UK to Germany, another huge air market. For instance, London to Cologne and then onto Frankfurt would be revolutionary, along with the London-Geneva you mentioned. One could think of a London-Hamburg service which would also be amazing, the issue is that Germany doesn't allow it.
Multiple sources online that you can Google, a big reason that Germany uses is Brexit. Source: The IndependentIt's the first time I see this claim. What's the source? And what would be the season for this refusal?
It's come out of UKs stupid Brexit, basically UK cut access to the European crime and immigration computer (the one used for Schengen etc)It's the first time I see this claim. What's the source? And what would be the season for this refusal?
This is mad! I had no idea there was such a ridiculously high flow between Geneva and London.Most flights would be 156-200 seats, those using City airport fleet nearer 100 seats
Depending on train seating configuration, 7-9 trains.
Maybe just 6 trains if it is 1400+ seats
Alstom say upto 740 seats per 200m unit (1480 seats for 400m)
Presumably in February (which was the example given) it is skiing traffic predominately. Although there is an irony that these flights will themselves be contributing to climate change which may over time reduce the skiing season.This is mad! I had no idea there was such a ridiculously high flow between Geneva and London.
It it really true that let’s say approximately 20,000 people total are moving between Geneva and London and vice versa every day?? Who are they???
I tried but didn't find anything. Care to share a URL?Multiple sources online that you can Google, a big reason that Germany uses is Brexit.
Ah yes very true. Skiing it is. I would have thought then the non-ski season numbers are a lot lower.Presumably in February (which was the example given) it is skiing traffic predominately. Although there is an irony that these flights will themselves be contributing to climate change which may over time reduce the skiing season.
Quelle surprise! Post from Richard Clinnick on X it appears no order with Alstom exists only discussions on possible future orders! https://x.com/clinnick1/status/1713075997858279847?s=46&t=glukhskDLLZUitqCLTavbg
Plans for UK-Germany high speed rail services shelved due to ‘significantly changed economic environment’
Exclusive: Deutsche Bahn declines to say whether Brexit played a role in cancellationwww.independent.co.uk
“We ask for your understanding that we won’t comment on political developments like Brexit.”
It it really true that let’s say approximately 20,000 people total are moving between Geneva and London and vice versa every day?? Who are they??? Geneva is nothing like a Brussels or a Paris which is a natural hub for a lot of other traffic.
Germany hasn't blocked international services from the UK. DB abandoned its own plans for direct services for a few reasons.I agree, but an issue is that Germany (among others) has blocked direct rail services from the UK to Germany, another huge air market. For instance, London to Cologne and then onto Frankfurt would be revolutionary, along with the London-Geneva you mentioned. One could think of a London-Hamburg service which would also be amazing, the issue is that Germany doesn't allow it.
Amsterdam Centraal gets away with just a movable barrier, though I've no clue if that approach would work at Cologne.1) Services to the UK require non-UK stations to wall off a platform for more or less exclusive use for UK trains, because of immigration requirements outside Schengen. Doing this at Cologne for a few trains a day was deemed impractical given the demands on platform capacity.
Germany hasn't blocked direct rail services to/from the UK, but it benefits the current UK government to portray it as such.I agree, but an issue is that Germany (among others) has blocked direct rail services from the UK to Germany, another huge air market. For instance, London to Cologne and then onto Frankfurt would be revolutionary, along with the London-Geneva you mentioned. One could think of a London-Hamburg service which would also be amazing, the issue is that Germany doesn't allow it.
