I think you will find that almost without exception, they are designed to fail safe (which is a lot better than many plug-in chargers that are in use).
The sockets that I've just installed also comply with the latest rules in that with nothing plugged in they draw less than 100mW.
I hear they make it difficult for electricians to test the resistance of the circuit though, as the USB charger can't be disconnected. Maybe the newer models don't have this problem though?
Our shower is above a bath. And I'm not sure if installing a glass screen/door is feasible (quite apart from the financial aspect), as our upstairs bathroom is quite compact (the edge of the sink butts up against the edge of the bath for instance)[...]
My old flat had a similar layout, but it didn't stop the previous owner from installing a fixed glass screen at the shower end of the bath. The problem was that they left a 1cm gap between the screen and a built in unit thing with no way of accessing it to clean it...
Did you check that there was 500g in the packet and not 450g?
My guess is the portion sizes were originally specified in imperial. A 1lb (454g) packet could have 4 portions. Then they change the packet to be a round metric number and don't update the portion sizes.
Until we changed it, our bathroom sink was poor design. There was an all round rim, a bit inside the rim where the taps were mounted, then the sink proper. When fitted properly, the rim all round was perfectly level. Just inside the rim sloped backwards, not much but enough to cause any splashes to congregate at the back and fester. It was very difficult to keep clean.
I have a sink with this issue. Mould loves to grow on the silicon sealant there! Despite the awfully tacky website, I have found that a product called "Mould Magic Extreme" works well.
Here's a few nominations off the top of my head:
Cooker clocks that make it hard to set the time after a power cut
The speed limiter/cruise control in my car. It adjusts in increments of 5km/h or 1mph, and if you press the button too quickly it will ignore some of the presses. Why can't it go up in increments of 10mph? (I know someone is going to come back and say so you can set it at 72mph on the motorway to match an actual 70mph speed as read from a GPS, but still I find it annoying).
Any time a manufacturer deliberately doesn't follow convention or standard to make you buy their proprietary chargers, cables, accessories etc. - e.g. device that has a DB9 serial connector but does not use the Cisco pin layout. Although they might argue its better that way...
