I dont know what it would do, that is what I was trying to understand. The OP said the card showed up as unregistered - but would that be the case if it was blocked or hotlisted or whatever and they checked? That would explain both why it said unregistered and also why it why it wouldn't work on the barriers.Why would the machine tell you that a hotlisted, registered Oyster card was unregistered? I am totally confused.
I'm not from the TfL area though so I've no idea how this works.
Yeah, it does. Cheers for that.What happens when a registered oyster card is reported lost/stolen is this:
The registered owner will call oyster explain the problem provide there account details to oyster. Oyster then confirm the card that is reported as lost/stolen and then put a block on that card. If someone finds that card if they touch it on a POM BEFORE touching a gate it will show up on the POM as a normal registered oyster card. The minute a person then touches a hot-listed/blocked oyster card on a gate it will automatically become disabled/blocked as the system has now located this card as been used therefore will stop it from been used as the signal sent from oyster will now deactivate it.
If the person then returns to the machine it will still show up on the screen any balance that is on the card the historys etc however the function to now top up will be removed.
There is a code that appears on the gate for staff to know when a card has been blocked however I don't wish to disclose this code for obvious reasons.
Hope this helps
So picking up an Oyster Card that isn't yours, discovering that there is money on it and using it is perfectly ok now a days. I'll remember that next time I find a credit/debit card.
If it's unregistered, it's equivalent to cash.
Was it unregistered though? We've been told it was, but if it was killed then chances are it wasn't.
So, if you found cash, you would go and spend that to. Guess we are not going to see you in Metros good feed deed anytime soon.
................The minute a person then touches a hot-listed/blocked oyster card on a gate it will automatically become disabled/blocked as the system has now located this card as been used therefore will stop it from been used as the signal sent from oyster will now deactivate it.
And also helpfully, National Rail gate error codes:
