According to this link
http://www.engineering-timelines.com...em.asp?id=1151 the River Mersey Wirral Line tunnel were built to the following specification.
The main tunnel is lined with a 685mm thick layer of brickwork (six courses) set in cement mortar where it runs through sandstone. The brickwork is increased to eight courses where clay was encountered. It is 7.9m wide and 7m tall overall with 5.8m clearance between the rails and tunnel roof. There are recesses at 41.1m intervals on each side. The flanking tunnels are lined in four courses of brickwork. In addition to the double standard gauge tracks, telephone cables were laid in the running tunnel to improve cross-river communications.
This link
http://www.storycontracting.com/rail...ground-network describes the work of replacing the track in the 1970's built Wirral Loop tunnels under Liverpool and confirms the diameter of the tunnels.
Whilst I am no expert, the original tunnels would appear to have plenty of clearance for OHLE but I am not so sure about the 70's built tunnels on both the Wirral and Northern Lines, perhaps somebody can confirm?
To see the difference in the size of tunnel construction parts of in this video show the relevant sections.
http://youtu.be/MqQSrrXmrjk
I also seem to remember posting an article confirming that the new 70's tunnels were built to allow a Class 66 to transverse them. Unfortunately, for the moment I can't find it.
Fair points, I'd agree the connectivity issue could be a problem for passengers connecting between "local services" and mainline services, but what is the percentage or numbers of passengers involved, compared to total numbers using the services? If the majority of passenger are commuters, perhaps they would achieve better connectivity changing at Central, if necessary. On the other hand if suddenly, you have the prospect of running services say from the City Line to the Wirral Lines without the need for passengers to change, would this not be huge step forward for the Merseyrail network?
Electrify the Bootle Branch. North Mersey Line and Ormskirk to Preston and using the Edge Hill spur you could have Merseyrail stock reaching Preston. The 60 extra trans sets option in the invitation to tender would clearly indicate that Merseytravel want to extend the network, but the routes proposed, Ormskirk to Preston, Kirkby to Wigan and Bidston to Wrexham would not require this number of additional train sets. The initial order obviously is to replace the current stock which already operates in many six car sets on day to day basis and is due for replacement by 2020. A follow on order could specify a slightly different capability if it was intended to extend the network as proposed.
