...but Swindon to Cheltenham isn't being electrified either.
I know. When I said 'carelessly' I carelessly ommited the fact that I was refering to both Swindon to Cheltenham and Cheltenham to Severn Tunnel Junc. Swindon-Cheltenham I think makes more sense than Cheltenham-Severn Tunnel Junc., but they make even more sense together.
And I really don't buy into the "wiring diversionary routes" argument when (a) there are so many important routes not wired and (b) we're going to have bi-more IEP to allow London - Cardiff trains to run via the Gloucester route.
I agree that there are a load of important routes, but I feel that having bi-modes under wires to Swindon for the comparatively short leg to Cheltenham is a bit silly. It only makes sense as a stop gap, but these diesel engines are surely far too expensive to be thrown away arround mid-CP6, so it's no stop-gap.
Personally, I only see the use of wiring diversionary routes being beneficial when a) the diversion isn't that long; b) it offers the opportunity for other services to go electric that wouldn't warrant electrification on their own.
Swindon - Cheltenham - Severn Tunnel Junc. meets your 'b' criteria in my opinion. It allows the Cardiff - Cheltenham service to go electric when otherwise it wouldn't. It also allows Paddington - Cheltenham services to go electric.
Given your desire to be rid of "diesel islands"*, why the obsession with running DMUs under the wires from Cardiff to Port Talbot (and on via the Swansea District Line)?
(* - not that this would be much of an "island")
Unless stoppers are introduced on the southern end of the marches line, the Cheltenham - Cardiff stoppers would be a 'diesel island' if they remain worked by Wales & Borders as that TOC has no outer-suburban stock (and no further need for inner suburban DMUs in south Wales after electrification). The diesel part of South Wales (west of Swansea) isn't quite an island thanks to the HOWL, and the SDL service I propose is a way of maintaining through services to Cardiff while allowing the services through Swansea to be split into seperate electric and diesel services.
Depends on the type of SDO used, if it is door by door or f/r door lockout (as on A Stock and 1995TS) then it could work nicely if properly implimented. the problem is fat harnessing and if a 350/1 or /2 turns up you're back to UDS...
What's UDS?
The class 323's would be great for the Cardiff valleys and in particular for those services which use the SWML such as services to Maesteg and Ebbw Vale where the linspeed is close to 90mph which the class 323's top speed.
Doesn't the SWML have 100mph stretches?
Didn't say it would be hard to install, just said you'd end up with fat looms, there may well be spare train wires available and/or a SIL-3 certified data link that can actuate individual doors from the TMS / TCMS...
SIL-3? A colleauge of mine once told me that railways are SIL-4, is this correct?
if America, China and Asia etc did their bit fair enough but it seems that we are deliberately being made to spend more money on new designs which to me are not really needed.
Does any other Country comply with this stupid legislation or is it just us again!
It's not just us. Or is it not even us?
Perhaps we have legislation like this to make us look like we are trying to tackle the climate change problem, and perhaps other countries have similar legislation. However, are these policies actually making a blind bit of difference considering that 'investment' is still being ploughed into bypasses and other road capacity enhancment schemes which surely encourage modal shift in the wrong direction? Nobody really seems to have lifted a finger to do anything to reduce air travel either, the promissed 'Moratorium' on airport expansion in the south east seems to have been swept aside with a new study underway into possible airport growth.
My point is that, if SWT wanted to order some new 450s to compliment the existing fleet it wouldnt be allowed. They would have to buy* the new improved design which would require a different maintenance regime and spares to the existing fleet. It is just making things more difficult than it needs to be.
* I know they are all leased but you know what I mean.
Didn't Southern get the improved Electrostar with the upgrades found in the 379 but in a form fully compatable with their existing 377s? I don't think only building upgraded versions is necessarily a problem provided compatability can be provided to ease fleet expansions.
