It is the National Grid who provide / manage the generated input to the grid and they say that they do not need any additional power stations let alone 10 Hinckley points
Leaving aside that significant generating plant is connected directly to the distribution system these days, where will this extra electricity be generated?
We are going to have to consume a lot more electricity to replace all the natural gas burned in domestic settings, and all the petroleum fuels used in transport and other applications.
I have piles of models that demonstrate this.
Yes some local cables will need upgrading but according to DNOs they are older sub-standard cables due for replacement in a similar time period.
DNOs are also not planning for any significant decarbonisation of the energy system.
It is not going to happen under current plans!
Reductions in energy use, LEDs
LEDs' savings have already happened.
Virtually everyone is on fluorescents or LEDs already - the number of filament bulbs I see has dropped drastically in the last few years.
The mass giveaways of CFLs in the last decade saw to that.
private Solar PV, better appliances have addressed much of that issue already. None of this affects railway operations anyway!
Solar PV is of
almost no value to the power system.
Barring a mass rollout of air conditioning systems, solar power is off peak power.
Peak electricity demand tends to occur in February, at about 6pm.
Which is
after dark.
The fact is that, barring mass use of air conditioning, electricity produced at midday in June and July is nearly worthless.
Ah, the daft 30GW joke again. That is the theoretical charge rate if every single electric vehicle in the UK charged up at the same time. Now do 31 million cars go to the petrol station at 5pm every Friday night? No they don't!
Does fueling a petrol car take several hours?
Is there a petrol station in every single house, as you are advocating?
On average daily mileages, at tops 10kW/day is required that is 30GW per day, not per hour!
You are confusing power with energy.
The average car drives about 7900 miles per year, which is about 20 miles per day, this ofcourse does not count driving less at weekends which will load the grid more heavily on weekdays.
Typical electric cars use about 0.34kWh/mile.
This comes to about 7kWh/day
So thirty million cars consuming 7kWh/day is about 210 million kWh/day, which is 210GWh.
If it was spread over the entire day that would be a charging power of 8.75GW
Since cars will likely be mostly charged at night as that is one of the only times the owner will have the car at a charging point they control and such, we are looking at charging over about 7 hours of the day, which is about 30GWe.
Adding lorries and the like makes it even worse.
All new chargers from June onward required smart charging as standard to address this and domestic V2G is ready for roll out too. Commercial is widely used.
Domestic V2G is technically ready.
It's just hilariously uneconomic, and likely to be unpopular when a person gets up in the morning to discover his car's battery is flat because it got pulled into a V2G scheme.
Tell South Australia that batteries do not work! They closed a power station from the savings made by installing a battery!!
That was instantaneous grid support in a rural and relatively week grid environment.
This is not the use case we are talking about here.
