GBRf Class 99 - 30 locomotives now ordered
Nottingham59
10 Dec 2019
This is not the limiting factor when adhesion is low.
Not sure I understand you. Surely the tractive effort that can be delivered when adhesion is low is the only thing that matters?
EDIT: Though agree that the tractive effort at times of low adhesion will be far less than the theoretical maximum. What we haven't seen is any indication for the 99 or the 93 of how well they perform in poor conditions.
bahnause
30 Dec 2016
bülach (switzerland)
Maximum tractive effort alone doesn't tell you much about the speed range it can be delivered. I'd guess a 93 will probably be able to keep maximum tractive effort up around 35mph and will probably beat a Class 66 above 15mph in electric mode.
hwl
5 Feb 2012
The key point is poor adhesion limits the maximum tractive effort per axle hence more axles helps. Also adhesion tend to improve with successive axles hence more powered axles help.
i.e. 6 axles is the way to go for a GB wide freight loco and GBRf have got their thinking right
4 axles is probably ok for most intermodal on the ECML which looks like having been the 93 target market.
ac6000cw
10 May 2014
Cambridge, UK
Sounds right. Power = Force x speed = 290kN x 15.9 m/s = 4600kW
The cl.93, 91, 37, 66, 43 (HST) and 67 tractive effort versus speed curves are here - https://www.railforums.co.uk/threads/class-93-tri-mode-loco.210779/page-33#post-6791682
Nottingham59
10 Dec 2019
When they announced the 93, ROG said that Stadler persuaded them that, with modern wheelslip control, they could get away with four axles and still get traction in poor adhesion conditions. We'll just have to see how that pans out in testing, but the omens are not good.
I guess that ROG are suffering the fate of pioneers. The 99 is a far more capable locomotive, which benefits from being the second modern UK bimode to be specified.
Thanks. I was looking for that chart this morning and couldn't find it
ABB125
23 Jul 2016
University of Birmingham
Seems to work fine in the rest of Europe, where Bo-Bo TRAXX and Vectrons dominate the freight market. Though admittedly on the more challenging Alpine stretches they normally just stick another on the front (thus doubling power to ~13MW over 8 axles)
bahnause
30 Dec 2016
Nottingham59
10 Dec 2019
According to https://www.railforums.co.uk/threads/class-88-ukdual-eurodual.107049/post-2843016 the 88 performed nicely and I don't see a reason, why the 93 would not.
Sounds promising, but is that consistent with 88s needing to be double-headed over Shap and Beattock, as described in this post?
The 88s perform adequately on the Tescos but, when the adhesion’s low, they are double headed by another 88 or a 68. A 93 may be slightly more powerful but is higher geared so probably performs the same as an 88 on containers up Shap but a 99 has an extra two axles with which to lay down its increased power so should perform better especially considering its lower gearing.
bahnause
30 Dec 2016
If I compare it to a random "standard" european AC-locomotive with four axles (they all are similar in the end) everything between 1200-1300t should be fine going up Shap (my TOC values, others might vary).
Siemens sells the Vectron with an "Xload" feature. The feature improves friction coefficient utilisation and thus enables higher loads. In addition, the driving characteristics resulting from the feature reduce wheel and rail wear. They mangaged 2000 tons on 12‰ and 1020 tons on 27‰ (1 in 37)
Bristol
16-1800t is the normal trailing weight in the timing load for a 775m train...
hwl
5 Feb 2012
One post refers to testing before entry into service and the other describes what has been shown to be needed in practice. The GB rail network on a damp autumn day has proven the need to double head because of low adhesion in practice compared to adhesion testing in Velim referred to 8 years ago in the class 88 thread.
An 88 is rated for 1400t on the northern WCML. So shorter / lighter trains and the need to double head in autumn...
bahnause
30 Dec 2016
That should work fine then as our tables are made for longer inclines than Shap. Short inclines often have special tables with higher acceptable loads. Some comparable routes are rated for 1750 tons. But that is up to the TOC.
Nottingham59
10 Dec 2019
Good, didn't realise it was that high.
So the 93 with its more modern wheel control should be rated for a bit more - perhaps even a maximum intermodal at 1600t - 1800t. In whicih case, I can see a good financial case for the 93 hauling intermodals compared to the 99, which would be expected to have much higher track access charges.
bahnause
30 Dec 2016
The only similar line I could find is the Bözberg. It has a gradient of 12‰, which is slightly less than Shaps, but it is quite a bit longer at 16km. We allow for 1700 tons there.
hwl
5 Feb 2012
So the 93 with its more modern wheel control should be rated for a bit more - perhaps even a maximum intermodal at 1600t - 1800t. In which case, I can see a good financial case for the 93 hauling intermodals compared to the 99, which would be expected to have much higher track access charges.
Er???
Wheel split etc control will be very similar and the gearing is worse on a 93 making wheel slip control comparatively less effective.
Intermodal train resistance is higher per tonne than Aggregate etc.
The 99 has very low axle loads (RA5 instead of RA7) and a slightly flexible bogie design that should reduce curvature resistance and thus attract low track access charges.
The slightly increased TAC of a 99 is more than off set by the marginal revenue from more containers...
Nottingham59
10 Dec 2019
ROG said it was a new system, with better performance.
The 99 weighs 116t, compared to the 93 at 86t. Slightly less axle load (19.5t vs 21.5t), but six axles instead of four. Do we know what TACs for these classes will be yet?
Not if the 93 is rated to get a maximum length intermodal over the hills. I don't see how the 99 could haul more than that. Which is why the performance on gradients under poor adhesion is so important.
EDIT:
93 traction control was described here:
Tractive effort science in action​
The industry standard class 66 diesel leaves everything else standing for tractive effort, the ability to start a train from rest. However, even though the ’93 has just four axles, and the ’66 has six, once the train is above walking pace, the ’93 keeps on pulling. “The control of tractive effort has improved so dramatically as to radically change the way locomotives behave on the track”, says Watts. “The older technology – thyristor control – is superseded by systems that deliver constant manipulation. At one time, wheel slip control that activated within an eighth of a wheel revolution would be industry leading performance. Now, the constant control available and systems built in to the class 93 is almost instantaneous. We have a spectacularly advanced traction control system on this locomotive.
Green ambition​
Remarkably, individual axle control can be used to proactively enhance tractive effort. Wheel slip creep is designed to condition the railhead. Preventing the rail equivalent of burning rubber is critical, if damage to the railhead is to be avoided. “Allowing controlled slippage of the first axle, effectively conditions the railhead, affording better traction for the following three axles on the locomotive”, says Watts.
All these technological enhancements challenge the established order of brute power and diesel traction. With the UK government goal of eliminating diesel-only traction from Britain’s railways by 2040, there is a growing incentive to develop and deploy electric and hybrid traction. However, with green ambition out pacing electrification, and around half the UK network still without wires, the case for locomotives like the class 93 grows ever more compelling.
23 Nov 2015
ROG have had a lot to say about the wonderous properties of these locos. They also had plenty to say about their logistics business, 100mph intermodal trains and whatever else - which hasn't happened.
D365
29 Jun 2012
Class 99 is RA5? That would be monumental if so.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
Beacon's data sheet https://beaconrail.com/en/fleet-item/cl-99/ says weight of 113T over 6 axles, or 18.833...t per axle. RA isn't quite as simple as a strict t/axle loading, but it's a fair guide. The limit mentioned on Wikipedia for RA5 is 19t axle loading, although the NR pages cited return a 403 error.
Must be more to it than just axle load, as you say. A 47/3 was 113t but RA6.
hwl
5 Feb 2012
They compared it to a 66 not an 68, 70 or 88 all of which have sophisticated three phase motor control
No 113 tonnes as others have pointed out
it won't be
The 99 will be much faster so easier to path
EDIT:
Every modern existing GB freight loco already has that tech: 70, 68 and 88
"Remarkably, individual axle control can be used to proactively enhance tractive effort. Wheel slip creep is designed to condition the railhead. Preventing the rail equivalent of burning rubber is critical, if damage to the railhead is to be avoided. “Allowing controlled slippage of the first axle, effectively conditions the railhead, affording better traction for the following three axles on the locomotive”, says Watts.
The problem is when you take the power off the leading axle and redistribute it to the other locomotive axles it works far better when you have another 5 axles vs another 3 axles. See post #424
The formula is fairly complicated but 99 has even axle loadings 47 didn't (close but not completely matched) and modern locomotives are better at reducing bogie pivoting.
Modern 3 axles bogie locomotives (e.g. 99) all hang the motors towards the middle of the locomotive (so the application of power or braking works against bogie pivoting where as older locomotives tended to hang the middle and outer axle motors towards the middle of the locomotive side of the axle and the inner axle motor towards the locomotive end side of the axle.
ac6000cw
10 May 2014
Cambridge, UK
Re. 3-axle bogie design, this is a (1972) paper about the design and performance of the EMD 'HTC' bogie ('truck' in the US) - https://utahrails.net/loconotes/EMD_HTC-Truck_ASME_72-RT-3_March-1972.pdf (as fitted to our class 59 and thousands of other locos around the world - AFAIK first used on production SD40-2/SD45-2 in 1972).
As per 'hwl's comment above, this has all traction motors on the 'loco centre' side of the axles. (Fig. 5 in the paper compares the layout of HTC to an older design with two motors facing one way and one the other).
HTC = High Traction C (3-axle), HTCR = High Traction C Radial steering (as on cl. 66)
That's not encouraging for the 93s. According to wikipedia, they deliver less tractive effort (290kN) than an 88 (317kN). But that discussion is for another thread.
I suspect the difference is probably mostly down to the 10% difference in gearing (100mph max for the 88, 110mph for the 93). The motors will have an upper limit on torque/current, with higher gearing that translates into lower maximum axle torque/tractive effort.
