hurricanemk1c
The Class 66 bodyshell doesn't meet current crashworthiness criteria. This will be the end for new Class 66s
From Modern Railways, July 2014 article on 66752:
"Any locos built after 31 December 2014 would need to meet Category IIIb emissions standsa and EMD says it cannot fit such a low-emission 710 engine in the existing Class 66 bodyshell. The possibility of putting a low-emission Caterpillar engine into a '66' body has been looked at, but the current Class 66 design will not meet recent, more stringent, crashworthiness tests" (my bold)
Fitting a different engine changes the safety case. And the last previous new Class 66 was built in 2008, so issue 4 wasn't in force
I have heard drivers call them turtles lol and weirdly I can see that
With around 450-ish Class 66's produced since 1998, and a further 30 Class 70's, these will be the mainstay of UK freight haulage for the next 20 to 30 years. 30 Class 67's and 25 Class 68's aren't going to change that!
Would track and structures cope with that amount of tonnage at that sort of speed?
Assuming that the rail operator can get it to/from where the trains are loaded/unloaded efficiently.And 75mph freight on a proper run will beat road transport every time - especially since Hauliers are now required to travel at 90kph and no more.
Sheds, shed, sheds and yet more sheds. I am getting bloody sick of sheds. Thank god for 70's and 68's!![]()
I think you may be creating solutions for problems that don't exist.Your assuming that the Class 68 is going to be the only BO-BO design to come about in the next decade? 20-30 years nah the industry won't wait around for them. If they do they'll lose hard earned business to road hauliers. It's not the Class 68 itself that is going to drive change, it will be the customer that do that, like they always have done and will continue to do so, and even 450 Class 66's aren't going to be able to prevent that. So unless a miracle occurs and a Class 66 is experimentally re-geared for 100mph running and is successful in going so then they aren't going to last long. The next decade is gunna be a very expensive one for FOC's. The simple fact is that railfreight needs to move faster, 75mph just about cuts it now, in ten years time that's going to be considered very slow. Think HAA hopper vs HTA hoppers they allowed more coal to be moved more quickly. Now just like the hoppers there will shortly be a demand for a wagon that maximises the carrying capacity for 4000 boxes, can carry 9ft 6inch boxes on not gauge cleared routes and can move at 100mph with a capable loco. A principal that has been demonstrated time and time again throughout the world is that you rather innovate and give the customer what they want or you lose out the to your competitors.
It would be possible, but a 4 axle wagon would limit where you can operate at these kinds of speed. I reckon a 100mph wagon would have to be 6 axle development on an existing design. A bit radical here but common in Europe.
With spreading electrification I would expect EFMUs to take off before 100mph freight operations. (Electric Freight Multiple Units - on relatively simple container diagrams they have important benefits, and with 25kV making huge power outputs available they will be able to accelerate like anything).
This isn't really my field of expertise, but could someone confirm or deny whether a freight train travelling at a higher speed generates more track forces than the same weight train travelling slower?
I suspect that (for example) a 1500t freight train travelling at 100 mph would give the track a far heavier pounding than a 1500t train travelling at 60 or 75mph.
As it's the same force applied over a shorter duration, I'd imagine the track deforms more. Without knowing much into the field either![]()
Not so much track deformation, more to do with impact to surrounding infrastructure - the 3973 haws mentioned above are almost always in areas with old/weak underbridges.
There's a formula somewhere explaining the exponential force increase with increased speed but it's been years since I've seen it - basically, keep it below 24t per axle and you're fine up to 60mph on most of the network.
