ChrisCooper
Does anyone else have a particular train type that is generally well regarded but they look down on due to personal experiance? In my case it's the 158, just because travelling on them back in Central trains days I had so many issues due to them, in fact I know for a fact I've built up more delay minutes due to problems with 158s than any other type, even when relative milage is taken into account. I also never found the original seats that nice, particularly once the padding was failing (or in some cases the bottom cusions were loose) and I found the air condioning was either ineffective or not working at all. The vast majority of my 158 milage was with Central though.
My first problem was a 2 hour delay due to dragging brakes on a 156+156+158 Nottingham to Skegness, leading to the eventual abandonment of the 158. Another time a 158 refused to release it's brakes at Oakham and then Stamford without the driver opening up and shutting down the rear cab, leading me to miss my connection at Peterborough. To make matters worse, the next GNER Newcastle (which I had to pick up at Doncaster) had the 91 blunt end first so was late and lost even more time. Another similar incident the 158 operating the "Ivanhoe" shuttle from Leicester to Loughborough failed and was cancelled, meaning I missed my connection at Leicester only to find the next Stansted was also cancelled, and the direct Birmingham - Norwich that ran at that time was also delayed and was then crush loaded on leaving. Twice a 158 has failed at Norwich, leaving me to get the next in an hour (this was before the Cambridge service). Another big one was a 158 which had a big engine failure near Manton Junction, leading to a 2 hour delay, thankfully having limped to Oakham (especially as the aircon was not working and everyone had moved into the front coach as the back coach smelt of diesel). Finally, whilst not the 158s fault I also ended up spending nearly an hour stuck on a 158 at Saltley due to a Gas Leak near New Street Station. Another thing was that once Central lost the centre cars, seeing a 158 approaching was a guarantee of a fairly cramped journey, wheras especially on Liverpool to Norwich a Turbostar had a good chance of being 3 coaches.
