superkev
Are they still using the factory train as intended?
K
K
K
How it works:
With several consists in one train, the HOPS will leave the purpose-built depot in Swindon and split up to head to different parts of the line at its 60mph top speed. It carries enough supplies and equipment to avoid having to bring anything to the trackside on lorries and staff can be picked up at stations en-route.
The different consists are:
- A piling rig, with two MPVs with Movax vibro piling heads, which literally vibrate the steel piles into the soil, 2 pile carrying wagons, and finally a Fambo hydraulic percussion hammer MPV for tougher ground.
- An excavation and concrete batching consist. This will feature an Hitachi excavator plus a Kniele concrete unit which will mix concrete from onboard aggregate, cement and water tanks.
- A structures consist, which will erect the Series One masts, portal booms and twin track cantilevers. It is intended to carry 30 masts for erection, per night.
- Ancillary conductor consist, which will install the earthing wires, return wires and small parts such as registration arms and other equipment.
- The contact and catenary consist, which will string up the remaining wires, under tension. Another unit install other articles such as contenary wires under low bridges, neutral sections and record information such as height and stagger.
Each consist will include two MPVs with full driving cabs, powered by MTU power packs, which can be driven at 60mph off-site. On site driving cabs will allow the train to be driven very slowly in possessions, such as when installing contact wire.
According to some posters at RMWEB, as of the 27th March Maidenhead's platform 5 didn't even have SPS installed.
Is this true?
The London end of Platform 5 through to Maidenhead East Junction has yet to be wired, though IIRC the SPS is installed. Should be a quick job, though slightly odd given the turnback siding has wires but no track yet!![]()
What's SPS short for?
Only thing I spotted was that the little glass wall installed on the pedestrian over-bridge above Platforms 1 and 2 has been removed.
Catenary wire has gone up on the UM from Reading side of Ruscombe S&C to the existing wired section.
Approximate mileage for the above is MP29 to just after MP29 1/2.
The DM adjacent to this has now wired, catenary and contact.
On the UM, continuing on from the section with just the catenary, a further wiring run has gone up to near MP30.
Any contact wire?
UM MP29 to MP29 1/2 is just catenary.
On to MP30 is catenary & contact.
I was at Maidenhead briefly earlier, I notice p5 is wired, however one of the masts has two reg arms on it (pic); the one with the longer steady arm is tied up and not used? What's that for then, is it something to do with tensioning?
I think this is new in the last few days: There's contact wire installed on one line on the east-south curve of the Reading Triangle, towards Reading West.
The overbridge at Bourton (72m 15c) has a sign announcing overnight closures from the 15–23 April. I'm assuming this is to do with increasing clearances?
Is the East-South curve from the Reading direction or the Tilehurst direction?
