Great Western Electrification Progress
Linda smith
31 Oct 2018
Looks like the wiring of the line to Newport has passed under somerton bridge, will confirm how many lines have been wired tomorrow
Linda smith
31 Oct 2018
Checked this morning, j can confirm that both relief lines have their ATF plus c&c wires. I don't know how far towards maindee this goes as yet. Will check on friday as I am travelling to london that day
oglord
13 Oct 2010
Newport, Monmouthshire
Wiring progress at Duffryn: Up and down reliefs fully wired; Up main done except for a strange missing loop on the catenary wire here; Down main currently missing wires. Bonus Class 66 triple-header with ridiculously short train.
JRV
30 Dec 2017
Winter Park, FL, USA
That's a great shot!
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
That missing loop on the UM looks like the current jumper for the Mid-Point Anchor (which that portal structure is).
I see the ATF wire is missing on the Up side too.
Linda smith
31 Oct 2018
Also did a bit of Flickr digging-around, and discovered that the Down Main & Up Main are now wired for a short length west of the platforms to at least Hillfield Tunnel.
lines from p1 & both thru lines are wired to the tensorex just before the river usk bridge. The relief wired are now just short of caerleon bridge & the earth wires end where the posts with the span wires are.
On the other side of the city, both relief lines are now wired under somerton bridge to the east usk yard. With a run of earth going I little further past that. Between somerton and caerleon bridges in Newport, they only have the remaining equipment for the contact & earth wires left to install.
yanti
26 Apr 2018
Took the train from Bristol to Cardiff and back yesterday and from what I could see from the train nearly all of the wiring, apart from a short section (the last few hundred meters before Cardiff Central and a few short stretches here and there) seemed to be completed. It looked to my layman's eye as if the whole thing could be wrapped up in a weekend if the will was there.
59CosG95
18 Aug 2013
Installation of wires is one thing; installation of wires at points, crossovers and complex station areas is another. That's even before the power element of it is considered - each electrical section, between neutral sections, located at either an ATFS (Auto Transformer Feeder Station), SATS (Sectioning Auto Transformer Site), or MPATS (Mid-Point Auto Transformer Site) has to be fully connected up to the OLE, with earthing points installed, before it can be electrically proven - which requires a total line block in that section. It's not something you can split between "mains & reliefs"!
I'm sure the will is there, but the staffing and the cost is the main issue.
ATW158Xpress
6 Dec 2016
Traction changeover zones, diesel notice boards and raise/lower pantograph signs but covered over in black sheeting are being installed west of Severn Tunnel Junction station directly under the M4 bridge.
Which way are they facing? Does this mean there will be an electric "island" between STJ and Cardiff and the tunnel will remain diesel-powered until the rusting earth straps are fixed. Or for ever?
JN114
28 Jun 2005
I suspect it’s much more likely to be for trains headed to/from the Gloucester line.
2392
7 Apr 2015
Felling on Tyne
OK yes a triple header on a short train. Bear in mind that on occasion that it would save on a "light engine" movement, to get an engine/engines from A to B. What's more these days it could well be cheaper to make a shorty train a triple header and save on track access costs as well, when making a "light engine" movement.
Linda smith
31 Oct 2018
With this in mind, it must not be forgotten that there is a Bristol parkway - cardiff blockade due next weekend. This will give them the time to finish off the majority of the remaining work between magor and Newport station.
59CosG95
18 Aug 2013
Apologies if it's a day late, but here's the newest update! Am on holiday in Austria at the moment, so won't have the best access to updates.
GWML Electrification: State of Play, as of week commencing 22/7/19.
All mileages given from Paddington, except where noted.
Paddington to Wootton Bassett Jct - LIVE
  • All main line tracks wired as far as Wootton Bassett Jct, and are to be considered "live" as such. From Wootton Bassett Jct, the envelope of "live" wires continues along the South Wales Main Line to Filton Jct (inc. Bristol Parkway), and to the Limits of Wiring on the Berks & Hants line and Reading-Basingstoke Line; details are given below.
  • TTCs have replaced/been replacing headspans at various locations within London - locations include Westway (beneath the A40), Acton Main Line, Ealing Broadway, and between Southall & H&H. These are part of the works for the Elizabeth Line.
  • Everything wired at Reading (bar P4-6 which were never in the plan). Includes the TCD & the curves, down to Reading West (see B&H section).
  • West of Didcot Parkway, all lines are wired & live heading towards Swindon.
  • Everything wired at Swindon (bar the goods lines north of P1, where provision is provided).
Small Points
  • ATF wires in operation from Maidenhead to Wootton Bassett; Kensal Green to Maidenhead currently only using return conductors but will be AT-ready in the near future. Some AT wires up along this stretch now; whether they are live remains to be seen.
  • Parapet Work extended upwards at Southbury Lane Bridge, Ruscombe; the wing walls remain unfinished. Original Coping stones have now been replaced.
  • Platforms all extended at Tilehurst, Pangbourne, Goring & Streatley and Cholsey; PIS systems still advertise them as being 7 coaches long.
  • Platform extension at Didcot Parkway (P2 & P3) is visually complete but barriered off.
  • Few masts and cantilevers now up on the Didcot Avoiding Line, which finish at Appleford; Appleford LC being the limit of structures for the time being.
  • Oxford Lines west of Didcot Pkwy wired as far as the loco fuelling sdg; Down Oxford as far as 53m 31ch, Up Oxford as far as 53m 42ch. Didcot avoiding lines have sprouted masts (4 portals, 2 TTCs), with a wire pair over the Down Didcot Avoider.
  • A note on Steventon: Wires up under the High St Bridge (aka the "Brunel Bridge"); however, the bridge may well be demolished in CP6. "Temporary" parapet work to protect passers-by from stray currents now complete. Wires west of Causeway Crossing are only authorised for passenger service on 80x trains in both directions, however, 387s are allowed to run empty to/from Cocklebury sidings under AC. The appeal to demolish the bridge is due to occur in the autumn (of 2019). The discussion continues.
  • Overruns through Swindon Jct (77m 36ch) onto the Golden Valley Line have also been wired.
  • Swindon Cocklebury Sidings in operation for Class 387 stabling as of 2/1/19.
The "Main Line"; Wootton Bassett Jct - Chippenham (Cocklebury Lane Bridge) - LIVE
Until further notice, the 25kV transmission wires will run in a trough from Cocklebury Lane Bridge (just east of Chippenham) to Thingley Jct. Large steelwork is expected to remain in situ until wiring is authorised west of Thingley, but some specific items may be poached if required elsewhere (and duplicates aren't stored at RAF Wroughton). Details given in the "Postponements" section.
  • Both lines are LIVE, signed off for passenger use, and in service from Wootton Bassett Jct to Christian Malford (93m 31ch) as of 0700 on 21/04/2019 (Easter Sunday).
  • Catenary, contact & Earth wires are up over/adj. to both lines from Cocklebury Lane to Wootton Bassett Jct.
  • Limit of AT Feeding: the Auto-Transformer at Christian Malford.
Chippenham (Cocklebury Lane Bridge) - Thingley Jct
  • No piles in Chippenham station, nor any masts affixed to the viaduct.
  • All piles in and majority of masts (and cantilevers) up from the western end of the viaduct to Thingley Junction (where the feeder station will be). Most TTCs have booms from beyond the viaduct to Thingley East Junction. About 14 masts are up in the vicinity of Thingley Feeder Stn, 2 of which have TTC booms affixed. Another has an STC boom.
  • Piles continue westwards to the next bridge.
Thingley Jct - Keynsham
  • No wiring for the foreseeable future, but overbridges between Thingley Jct & Box Tunnel have all been rebuilt. Corsham Main Road Bridge needs its parapets raising. New aqueduct & footbridge at Corsham complete.
  • Both Box & Middle Hill Tunnels have had track lowered.
  • A new footbridge has been built at Ashley Box.
  • Piles also in (and have been for over a year) at Ashley (beyond Box Tunnel) - these might well be trial piles.
  • Bathampton Jct to beyond Sydney Gardens has had track lowered. A new signal gantry at Bathampton Jct was installed over Xmas 2017 and is now in use after the removal of the old gantry in May 2019.
  • Bath Spa platforms realigned & raised, with track also slewed.
  • Track through Oldfield Park & Keynsham now lowered.
  • A lot of piles are in along the embankment around Saltford and Keynsham in readiness for future wiring.
South Wales Main Line (Wootton Bassett Jct-Bristol Parkway-Severn Tunnel-Newport-Cardiff)
Wootton Bassett Jct to Filton Jct (inc. Bristol Parkway) - LIVE
  • Wires from Wootton Bassett Jct to Bristol Parkway in passenger service since 30/12/18.
  • All 6 through Lines at Bristol Parkway have been wired and are live.
  • Live wires continue to Filton Jct & Stoke Gifford IEP Depot; Chipping Sodbury Goods Loop and the Cheltenham Curve overrun (as far as the limit of wiring) are also fully wired and live.
    • Limit of Live Wires on the Filton Lines (+ Down Bristol Parkway Relief): 112m 23ch.
    • Limit of Live Wires on the Charfield Lines (from Westerleigh Jct): 120m 59ch.
  • Filton Bank bridge works (mileages all from Temple Meads):
    • Easton Rd Overbridge (1m 18ch) completely rebuilt.
    • Narroways FB (2m 12ch) & Ashley Hill FB (3m 11ch) replaced.
    • Bonnington Walk Overbridge (3m 62ch) - parapets raised.
    • FB south of Filton Abbey Wood (4m 18ch) will need work if wiring is to occur.
Filton Jct - Severn Tunnel
  • Stoke Gifford IET Depot all wired and energised.
  • Patchway Tunnels conductor rail installed.
  • Wires extend westwards from Filton Jct through Patchway and Pilning (across all lines) to the Severn Tunnel (on BOTH lines).
  • Limit of Live Wires on the Tunnel Lines extended from Stoke Gifford Jct to Patchway Jct (112m 68ch) as of 0220 on 12/5/19.
  • Cattybrook Brickworks Bridge closed since 18/3/18.
Severn Tunnel - Newport
Due to have IETs in AC service by next year - hopefully sooner!
  • Severn Tunnel Conductor rail in place.
  • Wires are now up over all lines (both Tunnel Lines, both Main Lines & the Down Relief) at STJ Station; this also includes the overruns on the mains towards Chepstow. Wires continue westwards to Somerton Rd Bridge (East Usk Yard); all 4 lines have C&C. In the Magor/Undy area, the Down side and Up side are missing short lengths of Earth wire and ATF wire; the .
  • The Up Tunnel Loop between STJ & the Tunnel is fully wired.
  • Ground trunking installed at STJ in preparation for the electrical feed.
  • Feeder cables now hang from both the eastern set and western set of Switchgear Masts at STJ Feeder.
  • 6-track portals, probably 'Vierendeels', going up around East Usk Yard (approx. MP157 1/2).
  • Between the Maindee Jcts (157m 74ch to 158m 16ch), a cluster of piles is in beside the Down Relief; these are complemented by masted piles on the Main side (adjacent to the Up Main).
  • Both Up & Down Hereford Lines are wired between Maindee West Jct & Maindee North Jct (41m 03ch from the former Rotherwas Jct, just south of Hereford); the Limit of wires is just north of signal "NT 1559".
  • The gap between the Maindee Triangle (Caerleon Rd Bridge) & East Usk Yard (Somerton Rd Bridge) is closing, with the erection of a number of back-to-back non-Series 1 TTCs in East Usk Yard. The Reliefs are now fully wired between Somerton Rd & East Usk Yard.
  • At the AT Feeder Station at the Maindee Triangle, the tall masts have now gained their spanwires in readiness for the C&C below.
  • Wires are up over the Usk Bridge; C&C is now up over BOTH Relief lines from the Tensorex portal immediately east of the bridge, through P1 & the Through Lines at Newport and up to Hillfield Tunnel.
Newport
  • All canopies now cut back.
  • All steelwork in Newport is complete.
  • P1 and both Relief (Through) Lines wired. The Down Side ATF is also up over the Through lines. The Down Main & Up Main are wired between at least Hillfield Tunnel & the western edges of P3/4.
Newport - Cardiff
  • Plenty masts up around Gaer Jct (159m 32ch) north of Cardiff Rd Bridge (the B4237):
    • one by the Down Relief;
    • two by the Up Main (one of which is a boomed TTC with SPS);
    • three by the Gaer Jct - Park Jct Chord.
  • Currently unknown if Alexandra Dock Jct Yard will be electrified. The Reliefs appear to be wired past ADJ Yard.
  • Lots of steelwork up immediately behind the signal gantry adjacent to the Up Main at Ebbw Jct; this includes a full portal boom and a TTC acting as an overrun mast on the Ebbw Vale branch.
  • Almost all steelwork up from Ebbw Jct to Long Dyke Jct (169m 35ch) east of Cardiff Central; most SPS is now up too.
  • ATF wire installed on the Up Main between Lighthouse Rd & New Dairy Farm bridges. In the Up direction, the Earth Wire is in place until just before the bridge over the Ebbw River.
  • Wires up through Duffryn on both Main lines between the Ebbw River Bridge & New Dairy Farm Bridge, after which it switches to both Relief Lines. At the MPA Portal at Duffryn, the Reliefs are fully wired, the Down Main is unwired, and the Up Main lis fully wired (bar the MPA Jumper & Z-dropper). The Up side ATF wire is also missing.
  • Wires up across all 4 tracks between Pengam Jct (168m 40ch) & Marshfield.
  • About 4 or 5 portals have been erected just west of Pengam Jct; 5 masts are up on the Up side east of Rover Lane bridge, complemented by 2 on the Down side.
  • 1 run of C&C has gone up between Moorland Road Jct (168m 65ch) and Long Dyke Jct (169m 35ch) over the Reliefs; this is assumed to be a crossover as it crosses from one Relief line to the other.
  • At Long Dyke Jct, all masts are up, and the ATF wire is now up over the Relief Lines.
  • In the Pellet St area, a Mid Point Anchor Portal Boom has now gone up.
  • Just east of St. Mary's St Bridge, 2 hexagonal Tensorex Portals have been erected over all tracks.
  • Over the bridge over St. Mary's Street in Cardiff (just east of Central), and immediately to the west of the bridge, 5 portal booms spanning all tracks have gone up.
  • Similar bespoke mast foundations are going in just east of Bute St Bridge, near the junction with the line from Queen Street.
  • Splott Rd Bridge upgrade work now complete.
Cardiff Central - Platforms 0-4 to be wired
  • Re-signalling completed. Platform 0 now open. 3 masts now up over P0/1 with TTC booms.
  • An Anchor Portal (of the hexagonal "TGBU" variety) has gone up over P2/3, just east of the canopies.
  • All large steelwork for P4 is now in position.
  • Most (if not all) TTC masts for P2 & the Up Through Line, along with P3 & the Down Through Line have gone up at the station. Some already have SPS.
  • Brackets appear to be in place on the coping stones on the Taff Viaduct (at the western end of the station).
  • Plenty piles up adjacent to Cardiff Canton. Increasing numbers of these now appear to have masts on them, as seen from a westward-facing shot from Central. A portal boom has gone up over the P2, P3 & Through lines immediately west of the station, behind the signal gantry.
  • Brickwork Sidings to be increased in length (and electrified) to accommodate GWR Class 387s; the first masts and cantilevers have now gone up, with around 2 boomed TTCs and 2 STCs in position.
  • Proposed Limit of Wiring: Leckwith Loop North Jct (171m 55ch) at a guess.
Swansea IEP Depot
  • New IEP Depot at Maliphant Sidings, Swansea now complete; all steelwork up. SPS, such as Insulators, Switchgear and Cantilevers have all been taken down, leaving only bare masts/booms in situ.
GWML/SWML Blockade Works (2018):
  • 6/7 to 3/12: Reduced capacity (2 lines only) for wiring work between Newport & Cardiff Ctl.
  • 15/9 to 6/10, and 13/10 to 14/10: Bristol Parkway electrified.
  • 27/10 to 18/11, 24-25/11, 1-2/12: Filton Bank 4-tracked.
  • 11/11: Bristol TM to Bath Spa resignalled.
  • December blockades at Bristol Parkway & Didcot Parkway done.
  • Christmas-New Year Blockade at Severn Tunnel Jct done.
GWML/SWML Blockade Works (2019):
  • 20/1/19, and 10/2/19: Newport to Bridgend blockaded (inc. Cardiff Central) for electrification work AT Cardiff Central; both done.
  • 17/2/19: Bristol Parkway to Newport blockaded for electrification work over the Usk Bridge at Newport; done.
  • 31/3/19: Newport to Bridgend blockaded (inc. Cardiff Central) for electrification work AT Cardiff Central; done.
  • 19/4/19 to 22/4/19, and 27/4/19 to 28/4/19: Bristol Parkway to Newport blockaded for electrification work in the Severn Tunnel Junction area; done.
  • 9/6/19, and 16/6/19: Newport to Bridgend blockaded (inc. Cardiff Central) for electrification work; done.
  • 27/7/19 to 28/7/19: Bristol Parkway to Cardiff Central blockaded for electrification work.
  • 25/8/19 until 14:00: Bristol Parkway to Cardiff Central blockaded for electrification work.
  • 8/9/19 until 14:00: Bristol Parkway to Cardiff Central blockaded for electrification work.
  • 14/9/19 to 15/9/19: Newport to Bridgend blockaded (inc. Cardiff Central) for electrification work.
  • 22/9/19 until 14:00: Newport to Bridgend blockaded (inc. Cardiff Central) for electrification work.
  • 29/9/19 until 14:00: Newport to Bridgend blockaded (inc. Cardiff Central) for electrification work.
  • 13/10/19 until 14:00: Newport to Bridgend blockaded (inc. Cardiff Central) for electrification work.
  • 20/10/19 until 14:00: Newport to Bridgend blockaded (inc. Cardiff Central) for electrification work.
  • Details of any further OLE-related blockades will be added as they are made available.
Berks & Hants Line (Reading-Newbury) - LIVE
Electric trains in squadron service.
  • Wires from Oxford Rd Jct are LIVE to the limits of electrification (53m 42ch on the Newbury Lines, 38m 07ch on the Basingstoke Lines) since 0650 on 21/10/18.
  • Class 387s are now in service on Reading-Newbury services as of 31/12/18.
  • Within Reading West, piles for the new footbridge (under Murphy's remit) are in, but have been "decapitated" (i.e. shortened) and capped until a new footbridge solution is found.
  • New stairs from Reading West's Down platform to Oxford Rd are now in use. Work is ongoing for a permanent footbridge replacement.
  • Parapet work on Tilehurst Rd Overbridge has been completed on both sides, although Heras fencing was still in place at the end of April.
  • Platforms extended at Reading West, Theale, Aldermaston and Thatcham.
  • Newbury's new footbridge is now open; lifts in service as of 19/4/19.
  • Immunised signalling continues to about MP55 1/2. Bedwyn Turnback Siding now extended to accommodate 5-car IETs.
Project Postponements
  • Thames Valley Branches:
    • Windsor & Henley deferred to at least CP6. The first few yards of the Windsor branch (Not the Henley Branch) have been wired as an overrun.
    • Marlow removed from scope of current programme. The first few yards of the branch have been wired as an overrun.
    • Southcote Jct to Basingstoke deferred to at least CP6. The first few yards of the Basingstoke Lines have been wired as an overrun.
  • Appleford LC to Oxford paused; if CP6 accounts allow for wiring to be extended to Oxford, it would be very likely to happen now that Oxford has been remodelled.
  • Catenary & Contact wires between Chippenham (Cocklebury Lane Overbridge) & Thingley Jct have been deferred until at least some point in CP6. All Large steelwork to remain, unless required elsewhere.
  • Bristol Temple Meads to Bath & Bristol Parkway paused, dependent on Bristol resignalling:
    • Taunton-Bristol Parkway completed over Easter 2018;
    • Bristol Temple Meads to Bath Spa completed in November 2018;
    • The WSM stretch from Flax Bourton Tunnel to Cogload Jct remains outstanding;
    • Track remodelling of Bristol East Jct remains outstanding;
    • Filton Bank 4-tracking completed Autumn 2018.
    • Further Signalling works due in 2019: Bath Spa due to be resignalled over the 11th/12th of May (done), and the 23rd of June. N.B. The Severn Beach Line will be closed for resignalling works on Sunday 7th of July.
  • Bristol Temple Meads' "Midland Shed" to be reopened in CP6 at the earliest, after Bristol resignalling is complete and the PSB is demolished.
As always, do let me know if I've missed anything!
(apologies to anyone who saw it in a state of source code chaos too).
Linda smith
31 Oct 2018
20190722_164121.jpg can someone please explain why this cantenary near moorland park in Newport is different from others please? Thanks in advance.
9 Nov 2017
View attachment 66140 can someone please explain why this cantenary near moorland park in Newport is different from others please? Thanks in advance.
Those are switching components installed on the boom - is that what you’re referring to? They’ll be used to either electrically section the overhead lines into smaller, controllable areas; or control the feed of power into the system.
The insulators will physically support either side of the switch and there’ll be a moveable blade between them. The coiled wires currently fixed to the boom will carry the current from one side of the switch down to the catenary/contact wire once fully installed.
Linda smith
31 Oct 2018
Huge update : had a post card notification from network rail today, the line from Bristol parkway through to St Brides (Newport) is due to be energised on 14 september, with testing of that section to be done in the weeks following that. Am not sure of how long after that date the line will be authorized for passenger use. But for now this is still very good news
800002
19 Jun 2019
Does this mean that the sparkies can run through the tunnel, as sparks?
GRALISTAIR
11 Apr 2012
Dalton GA USA & Preston Lancs
Well it would make sense for a number of reasons. As we know there have been corrosion issues on the conductor bar but constant use will almost certainly alleviate this issue though obviously not remove it completely. There will be other wear and tear of course (erosion) but assets are meant to be used not left unused.
800002
19 Jun 2019
Damn - When you phrase it like that... I have not previously read a comment of that description. It does make sense.
With continued use, the maintenance regime can be properly implemented to mitigate against the corrosion issues.
*silly me.
GRALISTAIR
11 Apr 2012
*silly me.
Well in fairness I do have a MSc and DIC in 'The Corrosion of Engineering Materials" from Imperial College London.
