rdlover777
slightly Off-topic but how close can i get to the channel tunnel portal without tresspassing in order to watch these trains arriving?
Sort of Dollands Moor (where they are dragged to after exiting) is viewable from an overbridge and from the side via some woodlands next to Folkestone Rugby Clubslightly Off-topic but how close can i get to the channel tunnel portal without tresspassing in order to watch these trains arriving?
The actual tunnel portal is do-able but the walk from the nearest road or proper footpath isn't advised in anything but firm, dry conditions as the gradients are not for the faint hearted
What a lot of spin, oh and by the way the 153s are 30 years old not 40! But what’s 10 years between friends!
Wasn't that the 379s & they where ordered under NX?Never let facts get in the way of a good story.
What I want to know is where the 30 trains are that were introduced by Greater Anglia in 2012 on Stansted Express, since nobody has seen them operate in service?
What I want to know is where the 30 trains are that were introduced by Greater Anglia in 2012 on Stansted Express, used to reference the ability of that company to bring new fleets into service, since nobody has seen them operate in service?
Initially the PR I thought was spin and style over substance from when they one the bid, that was bad enough, but now we appear to be getting exaggeration, creative figures and misleading comments.
They are all the same. I remember NX (under the hideous 'one' branding) taking all the credit for the excellent 'Ipswich Tunnel Blockade' back in 2004 even though all the hard work & planning was done by FGE & AR. Nothing changes.They were the 379s which were fully in service before Greater Anglia even came into being, 7 years ago, that they now appear to be trying to take credit for, in order to defend themselves from the accusations of having an inexperienced team, whilst at the same time name checking someone who most likely will carry the can after the others at the helm have jumped ship.
Some would suggest that GA should spend less time spinning and misleading people and making incorrect statements to make them sound better than they are and more time on running the railway which they have done a very poor job of lately and a project that is going poorly to date. They have certainly gone down in my estimation this last year.
By the week I get less confident that they can deliver on this plan, it's just the constant, everything is going to be great, everything will be amazing speak that irritates me, and the fact they're getting their excuses in early and already bigging themselves up and taking credit for stuff they didn't do and making themselves seems better than they are, is almost like they are shoring up the decks before the inevitable waves hit them and the ship starts springing leaks.
Can anyone confirm that 321328 is back from Renatus refurb please?
Roger Ford's monthly email available online at http://live.ezezine.com/ezine/archives/759/759-2019.01.21.04.02.archive.txt
describes a table to be published in Modern Railways next week:
Greater Anglia is Exhibit A for PRM-TSI compliance. Supplementary Tables in the column list the existing fleets being replaced by each new fleet, with non-compliant stock colour coded red. It’s a colourful column in some places.
In the case of Greater Anglia I make it 137 non-compliant EMUs which will have to be replaced by the end of the year. In addition the non-Renatus Class 321 units come off lease on 31 October, placing more pressure on Aventra deliveries.
Bombardier is increasing the number of Aventra production lines at its Derby works to six. It’s going to an interesting race been production capacity and time.
There is loads of space in the ROC. But unlikely to move from Liverpool Street now until they need to upgrade the signalling system.See that article also says that Romford ROC is no more, took a lot of time to admit it ! It does say that Liverpool St is still an aspiration, but they will need another floor or shed along side to put it in
another "Norwich In 90" test run today (as far as Witham and return) due to engineering works. 90011 + MK3 set used.
Norwich to Witham
http://www.realtimetrains.co.uk/train/F60305/2019/01/27/advanced
Witham to Norwich
http://www.realtimetrains.co.uk/train/F60304/2019/01/27/advanced
Yes it's 70 bidi then although the crossovers there are 50mph the approaching signalling is quite restrictive. Throw in a running brake test & it's all very hit & miss.A pretty pointless test really, given it was cut short for obvious reasons. The set lost a little bit of time between Witham and Kelvedon on the return too, probably because it had to go bang-line until Church Street crossing which doesn't really mimic the everyday scenario. I think its 70 max wrong line on that stretch.
Norwich in 90 should really be diagramed for a pair of 360s. 90's are great on a dry rail ...but lose too much time in the wet as they struggle to get power down.another "Norwich In 90" test run today (as far as Witham and return) due to engineering works. 90011 + MK3 set used.
Norwich to Witham
Witham to Norwich
All GA 90s now fitted with auto-sanders. Use of 360s is precluded by crew knowledge & the fact there are never any spare. Hopefully 755s will to the job in practice from May.Norwich in 90 should really be diagramed for a pair of 360s. 90's are great on a dry rail ...but lose too much time in the wet as they struggle to get power down.
Running time Norwich to Witham was 57.5 minutes excluding stops. The fastest recorded Class 90 time from the Railway Performance Society archives from Liverpool Street to passing Witham is appx 31.5 minutes. So there isn't a huge margin for delays or engineering work.It's also rather short of the mark, you can't do Liverpool St to Witham in 22 minutes, so I'm assuming there is a specific section much further up than Witham being tested.
Used a pair of 321's the other week, they worked OK
Today;s up road run was 6 mins faster than a hauled set stopping at Manningtree and Colchester
I may have to sample a run on a wet day to see if that has improved matters! Last wet run from Stratford to Norwich back in Sept 2016 lost time accelerating from every stop and braking to a stop due to the wet rails. We ended up 8 mins late at NRW. The 360s and 321's don't seem to suffer so badly. Though the Non Renatus 321s struggle to reach 100mph!!All GA 90s now fitted with auto-sanders. Use of 360s is precluded by crew knowledge & the fact there are never any spare. Hopefully 755s will to the job in practice from May.
