I'm curious, what do guards, or other non-drivers (as you would have the DRA?) on-train crew who have dispatch responsibilities, do to remind yourself to check the signal and/or remind yourself it is still red, to prevent you from closing the doors and giving a Ready to Start signal bell when the signal is still red?
I'll be honest, I am by no means complacent, recently had a slight lapse in concentration, and forgot to check said signal when stepping off of the train. I had closed the doors and had only noticed before closing my local door that the signal is red. I'm wondering what other guards have done to help prevent this?
The 444/450's are easy to manage in this respect, as you can remain keyed on and can close the panel. Unfortunately a lot of other stock either holds the key captive, requires a different key to open the panel, or is awkwardly placed, so I cannot simply close the panel if I see red.
Someone said they had a colleague who would write G, Y or R next to the name of the station on their paper schedule card when they step off of the train, which is not only useful to put you in to a pattern of checking the signal, but can also be helpful for delay reports if you look at the schedule card and see you had a number of restrictive aspects in a specific area. This idea sounds decent and would also apply no matter the traction being worked, but I'm sure there are many other ways people manage this risk.
So, if you are or were a guard or similar, do you do anything similar, and if so, what?
