GWR Class 165/166 Turbo Diagrams
Jim
11 Jun 2005
Wick
I think the issue is 2 car units are often daily occurrence on that route, and fairly often on more than one diagram - and the capacity issues have been made even worse by the Bath Market.
A quick look on JourneyCheck a couple of Fridays ago showed 3 services in a row short formed to 2 coaches with reports of them being full and standing from Fratton or Southampton towards Bristol. GWR may have their hands tied with aging (and seemingly increasingly unreliable) stock, but it’s the passengers who suffer. Would be good if the short forming was shared out with other routes as it seems the Cardiff - Portsmouth passengers have to put up with more than their fair share of it!
A 2 car 158 vice a 3 car Turbo on Severn Beach peak time trains is totally unsuitable too though.
Whatever is done has a negative consequence for somewhere sadly.
30 Jul 2015
Unusually, it looks like the 166 on the 0652 Worcester Foregate St - Didcot was not swapped over with the 165129 on the down service at Shrub Hill and 166204 is running through to Didcot
06:43 Hereford to London Paddington due 09:38 will call additionally at Shipton, Finstock and Combe.
06:52 Worcester Foregate Street to Didcot Parkway due 08:45 will no longer call at Shipton, Finstock and Combe.
This is due to a fault on this train.
Will be formed of 3 coaches instead of 2.
Jim
11 Jun 2005
Wick
Bearing in mind that a Turbo can call at places like Avoncliff that are local door only, I don't really understand in a way why the same practice of the guard controlling just one door, cannot be used for these on an ad-hoc basis.
Some unusually long formations on Cardiff-Portsmouth today (although only going to Fareham) according to Real time traiins
1F07 Bristol-Fareham 8 cars to Southampton (formed CBAEDCBA)
1F13 Cardiff-Fareham 7cars between Bristol and Westbury
Some platforms only really fit 5.5 cars (nearer 6 if driver stops by platform ramp) so staff at Bath Spa will have to be on the ball to ensure no one gets stranded in back unit if getting off at some smaller stations.
CC 72100
23 Jan 2012
I'd anticipate the rear unit to be locked out, as the route is built around a 5 car max model as that is what most of the platforms can fix.
Door release options are 1 door or whole train, so the Bath situation for other stops can't arise.
Sounds like a unit positioning move to save on an ECS to me.
Not easy to lock out rear unit on a train from Cardiff, as it reverses at Bristol
30 Jul 2015
166220 has appeared on Thames Valley diagrams
Sunday
2B90 2200 Cheltenham Spa to Swindon
5B90 2316 Swindon to St Philips Mrsh H S T D (cancelled)
Monday
5L08 0540 Swindon to Reading
2L08 0624 Reading to Oxford
I notice that from the new timetable that the 0652 from Worcester Foregate St goes to Weymouth instead of Didcot, and the 0510 Oxford to Worcester Shrub Hill returns as the 0701 Worcester Shrub Hill to Didcot. This will end the daily swap of 2-car 165s between West and the Thames Valley. Unless the swap is accomplished elsewhere that I have not noticed, which is quite possible, the two turbo fleets will return to being independent of one another?
30 Jul 2015
Thank you for your reply. I guess this is a knock on effect attributal to the delays with the 769 programme, which I thought was the original reason for creating the fleet inter working?
The Thames Valley really seem to be suffering with 165 shortages at the moment. I am not sure what this is on journeycheck today;
16:20 Didcot Parkway to Oxford due 16:32
17:07 Oxford to Didcot Parkway due 17:24
17:34 Didcot Parkway to Banbury due 18:23
18:36 Banbury to Didcot Parkway due 19:23
19:37 Didcot Parkway to Oxford due 19:52
20:37 Didcot Parkway to Banbury due 21:24
Will be formed of 1 coach instead of 2.
Last Updated:08/12/2022 04:03
At least it is one more coach than the a.m peak part of the diagram which is 0 coaches.
RPI
6 Dec 2010
Formed of 1 coach instead of 2? Either a mistake, or its a 2 car turbo with one coach locked out of use!
FGW_DID
23 Jun 2011
81E
It was 165127 with doors LOOU, on that diagram, but the driver failed it anyway so it returned to the TCD.
ValleyLines142
25 Jul 2011
Gloucester
Sunday
Monday
What's the situation with the 0604 Gloucester to Worcester Foregate Street then? At present I believe that forms the 06:52 to Didcot?
Benjwri
16 Jan 2022
Bath
So the doors were faulty? Is there any sense in running that service even, seems like asking for abuse of staff. Especially on a rush hour service between Didcot and Oxford, they're normally full and standing anyways, telling a commuter they can't get on a train when they can see an empty carriage is not going to down well.
FGW_DID
23 Jun 2011
81E
no idea what the fault was if any. Perhaps what I should have wrote was:
”165127 was allocated to that diagram but as it was found to have some doors LOOU was failed by the driver and went ECS to the depot.”
127 was still showing on the system as allocated to that diagram for quite a while, even after it was sat on the depot. That may explain why journey check was showing those later services as 1 coach vice 2 coaches. In reality it would have been a different unit sent from the depot (or indeed maybe 127 once the doors had been given a clean bill of health).
Mitchell Hurd
28 Oct 2017
Better 1 coach than no train or stop one of the Oxford - London fasts there additionally.
Benjwri
16 Jan 2022
Bath
Stopping a London fast would definitely be better. I just mean for the sake of the station staff who would’ve had a nightmare dealing with angry commuters. Ive seen enough arguments about full and standing Oxford shuttles.
Benjwri
16 Jan 2022
Bath
Do you have evidence to support this claim?
I mean undeniably whatever capacity is possible is better.
However perhaps doing some kind of soft cancellation, such as listing the service as cancelled but still running it, would be better, to avoid huge crowds forming, and stop people rushing to the station to make the service, but help take what it can from those who are already there.
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
Well I agree with this, in any case. A single 20m carriage is not an example of where the “better a train than no train” will work. If anything it could just become dangerously overcrowded.
Parallel
9 Dec 2013
Just passed 166203 on platform 2 on the 1845 to Okehampton. First time I've seen a turbo on the Okehampton branch. Does this happen regularly?
Not regularly but they do turn up on that route from time to time, from my observation.
RPI
6 Dec 2010
Funny enough, I've seen a 165 on there a few times but never a 166
FGW_DID
23 Jun 2011
81E
Covering a failure probably(unless it was an STP amendment), there are no current 16x diagrams with workings to Okehampton.
Jrocks
27 Apr 2021
Torbay
Usually happens when 2T29 the 1831 Paignton service Is short formed, the Okehampton service (2K13) splits off of this service. Today however, there was no 2T29 for the unit to detach from as the Paignton circuits were hourly due to the industrial action. The 166 came off of 2L92 which was the Axminster service, curtailed at EXD to provide a set for 2K13 (plus the fact turbos arent cleared up the mule).
REVUpminster
3 Jan 2021
Paignton
The first record I have of Okehampton is 166203 on the 10 January 2022 and the same week 165132 on the 13 January 2022. There was 158766 3 September 2022. I don't know about Sundays.
Maybe to do with Christmas. There are no 165/166s operating today out of Exeter. All except one are short formed 150s in Devon and Cornwall. Maybe the strikes have affected shopping traffic to Exeter.
