Isn't it quicker by Cross Country from Swansea to Newcastle with a change at Bristol Parkway?
Not much in it, plus I have a few friends in London to tend to add an hour on to the time to cross it and grab at pint in Kings Cross.
Crawling out of platforms with an HST in notch 2 until well clear of the platform or hitting the ramp at 10mph when braking is just rank bad driving (or poor standards from above). It eats capacity by massively extending platform re-occupation time and is something that has been policy (at least at certain depots such as Bristol) on Great Western for years.For me, passenger comfort is more important than slamming the controller straight to max in either direction. If running on time (especially on electric) then the best thing to do is gently introduce power or brake and then incrementally increase it. There's little benefit in arriving at the next station a minute early if your shirt is covered in coffee!
If running late then I would brake and accelerate through the controller more quickly, but would never go straight to maximum power. Having been driven by a Worcester based driver back from Paddington the other day who went straight to maximum power every time and was quite aggressive with the brake, it really did make the journey uncomfortable - especially as we were following a freight for part of the way - and felt like I was on a rocking horse!
I crawl out of Paddington in notch 2 purely to allow a little more time for the train in front to get the hell out of my way to then allow some decent acceleration later on and hopefully a none stop run to reading. The xx03 departures do seem to have drawn the short straw as inevitably the xx00 catches up the xx50 when it calls at slough hence my reasoning for hanging back. But I agree slow approach speeds INTO platforms is pretty unforgivable.....Crawling out of platforms with an HST in notch 2 until well clear of the platform or hitting the ramp at 10mph when braking is just rank bad driving (or poor standards from above). It eats capacity by massively extending platform re-occupation time and is something that has been policy (at least at certain depots such as Bristol) on Great Western for years.
3 minute headways are so tight that it really requires the train ahead to depart on time at least - and then keep well out of the way. But yes the Slough stoppers on the main line are still timed for 90mph turbos in some cases . The xx;00 is scheduled to be only 2.5 mins behind at Twyford, which is close enough to suggest he will be seeing yellows! And once he starts slowing down - - then the xx:03 on his tail will also start seeing yellows - which causes a kind of wave effect in train terms. The only trains leaving Paddington that don't have this issue are the xx;50/52 and xx:20/22 Worcester/Oxford/Herefords which stop at Slough. They depart Paddington 5 mins after the Swansea - so theoretically should have a clear road!I crawl out of Paddington in notch 2 purely to allow a little more time for the train in front to get the hell out of my way to then allow some decent acceleration later on and hopefully a none stop run to reading. The xx03 departures do seem to have drawn the short straw as inevitably the xx00 catches up the xx50 when it calls at slough hence my reasoning for hanging back. But I agree slow approach speeds INTO platforms is pretty unforgivable.....
Yes no idea why they are so stubborn on the paths between reading and London so much could be done to give decent paths. Having travelled intercity lines through the UK quite a bit lately, it is only the western where almost all services seem to be poorly parthed into London. Wcml , ecml etc seem to get a generally clear run in / out.3 minute headways are so tight that it really requires the train ahead to depart on time at least - and then keep well out of the way. But yes the Slough stoppers on the main line are still timed for 90mph turbos in some cases . The xx;00 is scheduled to be only 2.5 mins behind at Twyford, which is close enough to suggest he will be seeing yellows! And once he starts slowing down - - then the xx:03 on his tail will also start seeing yellows - which causes a kind of wave effect in train terms. The only trains leaving Paddington that don't have this issue are the xx;50/52 and xx:20/22 Worcester/Oxford/Herefords which stop at Slough. They depart Paddington 5 mins after the Swansea - so theoretically should have a clear road!
Looks like some minor timetable tweaking could have been done here to improve things. Re-time the xx;50/52 Slough stopper to xx;48 or xx;49 to allow it to stay further ahead of the xx;00 And use 800's -not turbos!! Does the departure time have something to do with the pathing of trains into Paddington?
Let's hope the December timetable change sees some improvements.....
Yes..lets hope indeed. Another factor that doesn't help is the Heathrow Express service using 100mph trains. It didn't matter in the past, because their better acceleration than HST's meant they skipped off into the distance and were onto the branch before the HST's were back on their tail. The 800's arguably accelerate equally as good if not better. Let's hope the use of 387's and an upgrade of the overhead line equipment brings allows an increase to 110mph. But i maintain the HeX should have had 125mph units. The amount of times i have come back from Bristol or the West Country only to trundle behind a HeX unit from Airport Jn in is appalling!!Yes no idea why they are so stubborn on the paths between reading and London so much could be done to give decent paths. Having travelled intercity lines through the UK quite a bit lately, it is only the western where almost all services seem to be poorly parthed into London. Wcml , ecml etc seem to get a generally clear run in / out.
The problem is there is little capacity to switch Thameslink trains out of the way for late-running EMT services. I was on a Thameslink unit recently that had a late running EMT train coming in behind - but we were kept on the Up fast, to the the frustration the driver and passengers of that 222 - as we stopped Luton Airport Parkway, Harpenden and St Albans, before a fast dash to West Hampstead. I was following the progress of both trains live on RTT and astonished we were not moved across onto the slow lines until Kentish Town!!They're better than the MML, at least they have priority over commuter services....
Can we start discussing 800s again please
Fair point.
I used a pair the other day, Reading to London, and they were on diesel. Is this still a regular thing?
Toilets didn't need to be emptied on the HSTs, they emptied themselves onto the tracks. Now if the toilets aren't emptied often enough, they'll be out of service.I don't know which GWR service from London to the North Cotswolds got terminated at Reading not long ago but the reason was no toilets working. Not a great reason but very understandable - toilet unreliability must have happened too often, assuming it was an 800 that this happened.
Why is it such new trains aren't reliable at working toilets at the moment? We seem to go from timetable problems to catering reliability and now to problems with the toilets on the 800's!
Typical example of 21st Century vehicles - as nice as the IET's are.
Isn't it Agility that are in charge of that?It's not a problem if the TOCs plan properly to ensure they are emptied!
While passing through Reading this morning on the way to the office, I noticed a pair of 800s (027/029) working a service to Penzance - was that due to units out of place or is there a booked 800 turn down there now.
A 5 car 800 worked Cardiff to Taunton yesterday
In this case it has nothing to do with the TOC. It is Agility Trains' responsibility to properly prepare the trains for use.It's not a problem if the TOCs plan properly to ensure they are emptied!
It is to do with the TOC - they are the ones who have the effects on their customers. Up to them to put pressure on the supplier and to use whatever contractual mechanisms that may be available to achieve that. GWR cannot abdicate responsibility and say “not our fault g’uv”.In this case it has nothing to do with the TOC. It is Agility Trains' responsibility to properly prepare the trains for use.
View attachment 60952 Just saw this pass the Dawlish Beach web cam (https://www.dawlishbeach.com/cameras/free-cameras/the-blenheim-cam/) and wondered if the silver stripe below the windows is just on this unit or whether it is a modification to be rolled out across the fleet.
Thanks.That looks to be 800308 which is just on that unit. List of the names of the GWR railway employees who died during the 1st world war
