GWR operating short 'HSTGTi' sets (see diagrams section for workings)
nat67
23 Apr 2014
Warwickshire
Wabtec are behind refurbishing the MK3 coaches due to the following:
1) Loss of skilled welders.
2) Excess or unforseen levels of corrosion.
3) Each or most of the MK3 coaches are different because they were hand built in the 1970's.
And some of them are ex-loco hauled, rather than HST spec.
mic505
26 Nov 2016
I'd assume the 143's will stay with GWR until December, to cover the loss of the 153's to TfW.
29 Sep 2018
Yes that would make sense otherwise they would end up having a serious stock shortage if they sent the 143s off lease at the same time as the 153s. Plus Bristol still doesn’t quite have enough Turbos at the moment so Cardiff-Portsmouth can’t go 100% Turbo at the minute and they are still having their mods fitted. Slam door HSTs will be very useful over the coming months until more power door sets arrive.
jimm
6 Apr 2012
Not sure that is the case with anything that is coming out of the GWR long-distance HST fleet. I believe all the conversions in 2012 or thereabouts to create more trailers for FGW sets were of redundant HST buffet cars, not former loco-hauled stock.
FGW had hoovered up lots of the ex-CrossCountry HSTs after they had been replaced by Voyagers or after use on Project Rio services between London and Manchester during the WCML modernisation work, with last influx to replace the Class 180s in 2008.
I don't know why you think it should make any difference to fitting power doors - the differences between HST and loco-hauled version are principally the electrical system (renewed anyway in the case of stock converted to HST standards) and the locations of underfloor equipment.
nat67
23 Apr 2014
Warwickshire
Not sure that is the case with anything that is ex-GWR. I believe all the conversions in 2012 or thereabouts to create more trailers for FGW sets were of redundant HST buffet cars, not former loco-hauled stock.
I don't know why you think it should make any difference to fitting power doors - the differences between HST and loco-hauled version are principally the electrical system (renewed anyway in the case of converted stock) and the locations of underfloor equipment.
there are one or two ex-loco hauled Mk3's with GWR though.
43096
23 Nov 2015
42382/383 were converted from from 12128/172 for FGW.
In terms of conversion, what you say is broadly true, though the control end is no 1 end on LHCS and no 2 end on HST stock. No, I don’t understand why either!
Bringback309s
22 Aug 2013
Classic Castle out again today Penzance - Plymouth, 43042 on the rear, didn't catch the one on the front but was with yellow and white "Welshman" graphics
ijmad
7 Jan 2016
With such a short train do they still have both Class 43s in push/pull, or is it more fuel efficient just to turn the trailing one off?
Bringback309s
22 Aug 2013
The classic set runs continue this week and are running again tomorrow. They seem to be a very specific set of times - are they running a "ghost" service to what will become the norm in May when more trains start running between Plymouth and Penzance? rather than just random testing of the rolling stock?
D2007wsm
26 Jul 2015
The modified set went through Worle this morning around 08:40 heading towards Bristol.
Apedlar12
13 Apr 2017
I have just noticed, that GW01 is running 2E47 from Plymouth to Exeter St Davids currently. But I thought that was a 150 booked diagram...?
PHILIPE
14 Nov 2011
Caerphilly
Ah, thanks for the info, much appreciated :)
The working is:-
5C40 04+30 Laira to Par
2C40 0610 Par to Penzance
2P83 0739 Penzance to Plymouth
2C44 0950 Plymouth to Penzance
2P90 1256 Penzance to Plymouth
2A99 1532 Plymouth to Newton Abbot
2P81 1623 Newton Abbot to Plymouth
2E47 1740 Plymouth to Exeter St. Davids
5C47 19+05 Exeter St Davids to Laira
