RBSN
- Joined
- 14 Jul 2014
- Messages
- 383
The recent incident at Huddersfield was due to platform room, the driver was back driving the next day as it was out of his control.
As the other poster mentioned, there is TPWS. However TPWS is not fitted at every signal. You won't find it at most automatic signals and its not fitted to ground position lights or stop boards.
Automatic Train Protection should stop a train if the conditions are not met and with in-cab signalling, while there are no line side signals as such, the system will stop you if you haven't received a movement authority.
Do you mean the apparent spad or the collision?
If it was a cat A spad the driver wouldn't have been back driving the next day, and if by "due to platform room" you mean that a signal was passed at danger without authority during a coupling (or uncoupling) procedure and proximity to the signal was a factor, that would most certainly be within the driver's control and there are clear procedures in place to be followed in such a scenario, such as attaching/detaching from the 'other' unit, repositioning both units with authority of the signaller prior to attaching/detaching or arranging for the signaller to clear a signal to allow the procedure to be made safely. This would include consideration of unlikely events such as a pull-away test failing during coupling.
Exactly, if it was a spad he wouldn't have been back driving next day. So it was recorded as an operating incident. Similar has happened at Leeds occasionally with drivers splitting units carelessly not taking into consideration the position of mid-platform signals or IBJs.
One option he could've had with a bit of foresight (assuming he is aware of platform/unit lengths and that he drove the consist into 4 permissively) is stopping the leading cab say 9' away from the TPE unit and splitting towards that unit. If that means his rear unit is left partly outside the signal then there are provisions in the rules to deal with that later on. So long as he doesn't mske any movement further outside that signal when uncoupling everyone is happy. If he had already stopped 2m from the TPE set so couldn't split it safely from either end and couldn't reposition the TPE unit causing the issue (due to it being a TPE unit) then he should've rung the box and Northern Control and informed them of the circumstances and that he wasn't prepared to split the units as is. It's up to control to make the decision (can a TPE driver be found and the TPE unit be repositioned) what to do next and if they decide the units must be split where they are even if beyond the signal then the driver needs to ring the box, explain the situation and get authority before doing anything.
A similar situation happened to me. I was given permissive working and challenged the signal. I was told that there was room or me... Suffice to say I pulled in and ended up with 2 out the back. I called the Sig and I was asked to split the two off the back. Control, platform, and the box all gave me permission to split back into a set of point and whilst I was behind the signal.
I refused.
I took the unit into a nearby set of sidings, split it, and then returned to the platform.
We have had at least one SPAD due to a split in a tight platform.
So why has he been daubed with an operating incident on his record then if he was instructed by the signaller to make the movement? Something doesn't add up here.He contacted both the signaller and control and was instructed to to make the movement, even after he advised them of the situation.
This is why it’s an OI and nothing to do with the driver. I’m assuming you’re also a Leeds driver?
What’s with the moving after splitting?
And by so much enough to have a SPAD?
What do you mean with split safely?
Also, @ComUtoR , why would you refuse to split in that situation?
I refused.
As an extra note of pedantry TPWS is intended to prevent a train reaching the ‘point of conflict’ (i.e. the point at which one movement could feasibly come into collision with another) which may or may not be located beyond the length of the overlap. This becomes of significance when undertaking and scoring SORAT* assessments. Hence why certain locations - typically places where short trains with high rates of acceleration start from rest - have TSS equipment installed on approach to a signal.Also TPWS isn't meant to stop a spad, it is only meant to stop a train from exceeding the overlap/clearance point beyond the relevant signal.
Not trolling but genuinely interested in the answer.
If you knew you wouldn't fit why did you take the train in? Surely you trust your route knowledge or was you trying to make a point?
Yes, in a previous life I had to write a Sectional Appendix Local Instruction covering just that.Those signals with extra TSS have the likelihood of causing problems if a driver is authorised to pass the signal at danger with authority, as at some TOCs those signals with extra TSS loops aren't briefed to drivers.
A driver activating the 'train stop override' only renders it effective until a TSS set is encountered or the override times-out (20 seconds on passenger stock) - whichever comes first. It would therefore need activating twice to avoid an unintentional TPWS activation at the signal.
Where did he say he knew he wouldn't fit?
Why else would he challenge a permissive signal then??
Because as a driver you do not know what you are being put on top of or what room is available for your train. The permissive signal does not give you that information, only that you are entering an occupied platform.
I am not a Leeds driver btw.
And surely in that conversation with the signaller he would have been told what was currently occupying the platform? From comutor's previous posts he has years of experience so doubt he would just take the signallers word for it that's why i assumed he would know if his train would fit or not.
The RAIB has made three recommendations. The first, addressed to Great Western Railway and possibly also relevant to other train operators, seeks improvements to the training and assessment of new drivers. (...) The third recommendation, addressed to Network Rail and to be undertaken with the assistance of appropriate train operating companies, seeks a review of permissive working arrangements at stations.
Two learning points stress the care needed by drivers when undertaking permissive moves, (...)
TPE can't be given blame for an 'incident' in which a unit of theirs was berthed legitimately in a platform. There are no stop marker boards at Huddersfield, they have no way of knowing what units of Northern's may or may not turn up.He hasn’t been daubed with anything, it’s gone to TPE.
Thanks A lot for your reply, appreciate it.As the other poster mentioned, there is TPWS. However TPWS is not fitted at every signal. You won't find it at most automatic signals and its not fitted to ground position lights or stop boards.
The only thing that can be levelled at TPE might be a delay attribution claim for any resultant delays of the Northern stock due to not being accommodated. But even then, was the Northern stock the booked stock? Was the TPE driver of the berthed unit given instructions to berth it in a specific place on the platform?
