Let's hope that the weekend cold spell doesn't produce any more of the same snow!
It’s apparently going to snow in Sheffield on Sunday. Let’s hope the snow storm doesn’t extend out to Doncaster
Another HT 180 failed at Grantham this afternoon on what I am told was it's first service back since repair.
How long will they survive if they are constantly cancelling trains because of a shortage of units? Surely the cost will come back to bite them soon?
If it's the move to Crofton that has caused this I'm surprised First/HT are letting it persist for so long rather than pursing contractual/legal routes to have got it sortrd by now.Given their reliability over the last few months I'm not sure that maintained is the right word!
Rumours abound of a £2m backlog of maintenance required that hasn't been done as they run the fleet into the ground - that being said they are owned by First Group so should be financially stable enough to ride out the storm
It does seem an odd coincidence though that issues with spares coincided with the change in maintainance arrangements. One does wonder whether there were some creative solutions being used under the old arrangements that haven't been replicated.That is wibble. The problem is not a backlog of maintenance or the cost of maintenance - it is availability of spares, especially (but not only) the major components. This problem would still have occurred if the units were maintained at the Oak.
Is one back in action?
There was a 10:30 Hull to London Kings Cross but only to Doncaster that was re-instated at short notice earlier but nothing else additional to run apart from the other full diagram.
There were a couple of cancellations on Grand Central to/from Bradford today as well (1A63/1D73) - have GC got problems with their 180s as well?
Bombardier being slightly brave on twitter - I'd probably be not shouting about the 180s atm..... (see pic)
No. Supply issues for several types of UK rolling stock are starting to concern operators. It appears that we are starting to see the time taken for component supply lengthening and some suppliers of quite minor components are starting to increase their minimum re-order quantities. This is impacting both on the supply of new components as well as component repairs.
The smaller the fleet, the bigger the potential impact and that is all before you have a unit out for a major incident. The component supply issue with 180 units was becoming an issue even before the fleet transferred from the Oak.
Yet ATW appear to be managing to maintain a significantly larger fleet of very similar 175s without most of them routinely falling over...
But the 180's have a different engine and transmission. Probably bogies too although I'm not 100% sure on that.
And the duty cycle for a 175 vs 180 is somewhat different, they aren't carrying out sustained running greater than 100mph.
With a larger fleet it is more cost efficient to get components re manufactured for you that are obsolete, as the minimum order quantity doesn't hit you in the pocket so much. If your fleet of 27 units needs a widget costing £1000 to make with a 50 quantity minimum order, it costs you £1852 per widget in real terms. If your fleet size is now 14 it goes up to £3571, because you can't make use of the spare widgets you have had to have made, especially if they are not a consumable item.
I'm also watching this thread with interest, I'll soon be booking tickets for a trip in the summer and the combined HT+TPE fare is the cheapest available option.Fingers crossed on the reliability - i've just booked two more trips with them!
1With a larger fleet it is more cost efficient to get components re manufactured for you that are obsolete, as the minimum order quantity doesn't hit you in the pocket so much. If your fleet of 27 units needs a widget costing £1000 to make with a 50 quantity minimum order, it costs you £1852 per widget in real terms. If your fleet size is now 14 it goes up to £3571, because you can't make use of the spare widgets you have had to have made, especially if they are not a consumable item.
Agreed, but what's the cost of cancelling most of your services every day?! There are many fleets of obsolete rolling stock across the network, for which getting a hold of spares is a nightmare. However, if parts are required then they're required, and that's all there is to it. In this particular context, unless withdrawal and replacement with something else are viable options, the cost really doesn't - or shouldn't - matter.
