Jorge Da Silva
Hello, I wanted to see what Ideas people have to replace the Newark Flat Crossing which is a massive capacity issue for east-west connectivity between Lincoln and Nottingham.
I’d check the position of the river, locks and roads before going much further. I think of the theoretical four possible options the only practical solution is to lift the Lincoln line over the ECML.View attachment 66503
Something like this? ECML tunnels under the Nottingham-Lincoln line which allows the curve to be retained which would otherwise have to be replaced.
Would there be enough space for the ECML to tunnel under the Lincoln line? It would have to drop fairly steeply from the north end of Northgate station to get under the Trent.
May be easier to build a flyover for the Nottingham-Lincoln line.
It’s being replaced, in 3 weeks time!
As others have said, the only option is to put Nottingham to Lincoln on a flyover. Any other option requires a much longer bridge (to get over the Trent) or involves very wet ground.
In any event, how much of a capacity issue is it, really?
The flat crossing means that only 1 train per hour between Nottingham and Lincoln and effectively means that Lincoln cannot get a Birmingham service without extending the existing Leicester service. It is the only direct link between Lincolnshire and East Midlands directly otherwise you'd have to go via Retford and head via Sheffield which is a bit of a detour
...or running via Derby.The flat crossing means that only 1 train per hour between Nottingham and Lincoln and effectively means that Lincoln cannot get a Birmingham service without extending the existing Leicester service.
But there at least 2, often 4 or more, spare paths an hour E<>W across the flat crossing. Why does spending a couple of hundred million on a flyover make a difference?
Increase line speed for the ECML for trains not calling at Newark?
https://twitter.com/nrairops/status/1253598986759483392 is from National Rail Air Operations. It says:
"So yesterday whilst carrying out a survey of the ECML we passed Newark and as promised I managed to replicate the photo of the new formation. "
Last I checked Grantham is still in Lincolnshire, although I admit that the government in Lincoln seems to forget about us an awful lot.......
Off topic but maybe it is time for Kesteven to have it's status restored!As is Stamford...
Isn't there something in the EMR franchise agreement which limits east/west services to one simultaneous crossing each way each hour?
That would mean the Lincoln side villages had no way to Nottingham other than via Lincoln.That's just DfT stating that any franchise bid offering more than this would be deemed non-compliant. Basically because it would be an unrealistic assumption to plan franchise forecasts on given the lack of capacity across the crossing (otherwise, you could see the obvious revenue target of say a half-hourly Nottingham-Lincoln service)
In theory, EMR could bid to NR for additional paths over and above the franchise requirement if they believe any exist (unlikely given future ECML requirements which will always win) and there is an economic case for them.
Best bet would be making Nottingham-Newark hourly and then making Nottingham-Lincoln a genuinely fast service, calling Newark Castle only (with the villages generally picked up in the Nottingham-Newark or Newark NG-Lincoln services)
1, usually two carriage, train per hour? Lengthening existing trains seems more sensible before expensive grade seaparation
Given that post No.10 informs us that there are at least two spare paths an hour, I'd have thought a good opening theory would have been one train an hour from Lincoln all stops to Matlock and one fast train stopping only at Newark Castle, Nottingham, Leicester, Birmingham New Street and continuing south-west to somewhere like Gloucester.I'd be fine with something being built if there was a good business case, but there's surely scope to extend the current hourly Sprinter to something four/six coaches long before getting the crayons out. . . . .
. . . I've seen Birmingham mentioned but what guarantee is there that there'd be a Birmingham service? Given the clock-face world we live in, you're not going to see through trains to each of Leicester/ Derby/ Birmingham.
Or is this one of those situations where there's a reasonable population (but spread out over a wide area) to the east and a number of destinations to the west and we kind of feel that Something Must Be Done but there's no real consensus on what that would be?
Well I like to suggest it, but I'm proposing ~33-43m tram trains.e was no conflicts at Newark? Maybe extend the (currently ex-Matlock) Nottingham - Newark service through to Lincoln? You're presumably not going to replace any of the Northgate - Lincoln services (since you'd lose the London trains/connections). Or is anyone seriously talking three/four trains per hour from Lincoln to Nottingham?
