- Are there many loco hauled services in Ireland
- If so what routes are they?
- Are These Diesel or Electric ?
All Belfast-Dublin "Enterprise" services - operated with Class 201 Diesels and De-Dietrich push-pull sets
Most Dublin-Cork services - Class 201 Diesels and Mk4 push-pull sets (unrelated to British Mk4s), other Dublin-Cork are Class 22000 Diesel Railcars
What other types of traction are on Irish Railways?
EMUs on the DART (Dublin Area Rapid Transit) - Dublin's suburban rails system (these consist of the original Class 8100 and Classes 8500, 8510 and 8520 - the 8200s are stored out of use I believe)
Class 22000 InterCity Railcars (ICRs) on Dublin-Galway/Westport/Waterford/Limerick/some Cork/Tralee/most Sligo and Rosslare services (basically all the InterCity routes. Other classes of DMU operate Cork-Cobh locals services (Class 2600), the Limerick Jcn-Limerick shuttle (Class 2800), Dublin outer suburban services (non-electrified) (Class 29000 four-car suburban units), and the rural branches (all 2800s) - Manulla Jcn-Ballina, Waterford-Limerick, Limerick-Ballbrophy via Nenagh and the Limerick-Ennis-Galway Western Rail Corridor.
Class 201 and the older 071 operate the freight workings, the 201 are more expensive to run and so are generally reserved for the heavier freights.
In Northern Ireland all passenger services are DMUs - either Class 3000 (C3K) or Class 4000 (C4K), NI own two Class 201s and 3 Class 111s (same as IE 071s), the former are used on Enterprise, the latter on engineering trains.
Are there any "spotter / Enthusiast" type websites / forums (like this) out there?
Not sure, sorry
Are you allowed to take photos number etc. or some places ok to do it and other not allowed.
I believe the rules are pretty similar to here.
I've done a bit of a Google search and found Wiki, Irish Traction Group and the
Irish Rail site has a very limited bit of info on their locos.
Any info would be good.
Thanks in advance,
Class 201 are 3,200hp and 100mph locos. Built 1994-95, they replaced the 071s as the main passenger loco. Many are stored out of use since the end of loco-haulage outside the Dublin-Belfast and Dublin-Cork routes in 2008-09, the remainder are mostly push-pull fitted.
Class 071 are 2,475hp and 90mph locos. Built 1976. All 18 are officially still in service. Northern Ireland Railways has three identical locos but classed 111.
Freight-wise I'm not sure if these flows are current but you had:
Containers - Ballina to Dublin Port and Ballina to Waterford, the former 201s and the latter a mix of 201s and 071s
Timber - Ballina/Westport to Waterford, mix of 201s and 071s
Zinc Ore - Tara mines near Navan to Dublin Port, 071s
