Gosh, I'd never have guessed the direction that this thread headed in...
I'd love to see someone actually answer this issue.
My answer (as mentioned before on these kind of threads) is that we'll see at least a hundred 75mph DMUs replaced by EMUs in CP5, and that a similar amount of electrification in CP6 on "secondary" routes (since the remaining "main lines" are being wired in CP5) will allow us to withdraw all 1980s DMUs...
...which means that we'll have enough "modern" DMUs to run all unelectrified services in 2024 (that may be an entirely post-privatisation DMU fleet, that may also require Turbos)...
...any DMUs ordered today probably won't come into revenue earning service until around 2017 (esp since there's no "off the shelf" DMu that meets modern standards), so any newbuild of DMUs would be surplus to requirements after only around a quarter of their expected lifespan - a false economy.
Maybe in the 2030s we'll start looking at units for unelectrified lines (i.e. by the time that the earliest 170s are being pensioned off), but by that time the technology will have moved on significantly re batteries/hybrids/renewables etc.
Would you like to guess how many people travel from Edale to Southport each day?
Or are you just coming up with more extreme examples to try to prove a point? Personally, I don't think that these kind of rare examples help your case.
Again, how many people do this? It's two services tacked together (as
MidnightFlyer has pointed out) - partly to save platform space at Victoria, partly to utilise stock more efficiently - you might as well suggest that there are large numbers of people in Altrincham travelling all the way to Bury on Metrolink.
Certainly not something that a Pacer is "appropriate" for, but I'm guessing that the alternative was to cancel the service (since presumably the intended HST wasn't fit for service)?
I agree with you both - this is a fascinating Forum where I've learned a lot of things from a lot of cleverer people (inside the industry and outside it), but whenever there's a thread with "Pacers" in the title, you just know it's going to go into Panto mode and the same tired jokes/comments made.
What does that mean? Per head of population? Per passenger? Per passenger mile? Over which period? (presumably just over the last couple of years, since "the southeast" is seeing a high water mark in terms of infrastructure investment, after years of delays to building Thameslink 2000 and Crossrail?)
Does "investment" include subsidies to ongoing services? Because spending £1 on new infrastructure costs the same as the subsidy on the average two mile Northern service. Or if you are saying that Yorkshire should have the same investment as the "southeast" then does that mean that they should have the same subsidies per passenger mile too?
Or is it just a meaningless statistic that sounds big in an argument but isn't a useful benchmark?
The Cabinet? Dunno how they get to work, but I'd guess that some of them must have used the Circle/ District Lines over the past thirty year period that you refer to?
I wouldn't describe those Underground trains as being particularly gold plated, yet the people of Westminster seemed to cope.
True (sadly).
I'd love to beat the drum for investment in Yorkshire, I really would. But I'm realistic enough to appreciate that the business case for investment is better in busy areas.
We are already talking about Crossrail potentially being "full" from day one of operation - that's where the demand is.
Very selective quoting, since TPE obviously only stop their "express" services at relatively "main" stations. Southern, on the other hand, stop at every station on their patch.
If you travel from Lancaster to Carlisle via Barrow then you are either:
- Unable to read a timetable to understand that the "via Penrith" service is much faster/ more frequent
- A railway enthusiast who wants to take the slower scenic route
- Travelling at a time of disruption to the WCML
Regardless, it's not a "normal" passenger journey
True.
And if we did have a spare Billion then there are better things that we could be spending it on, than worrying about DMUs with less than a decade of service left.
What criteria are you using here?
- They are certainly suitable for the speeds (the same 75mph top speed of the 156s that used to be the mainstay on that line)
- They are certainly suitable for the relatively flat terrain (e.g. they aren't able to climb up to Buxton, but a flattish trip to the seaside shouldn't trouble them much) - certainly easier inclines than the Hope Valley/ Calder Valley
- The doubled up 142s on most journey are more suitable in terms of passenger capacity than the single 156s that used to operate (approx 60m of train now, compared to approx 46m of train before)
...so is it just a seat/comfort thing?
