Linking the Bakerloo and the city
robertclark125
12 Mar 2008
Cardenden, Fife
The stub of the former access road from the Waterloo and city Bank bound tunnel to the site of the former Armstrong lift (demolished in 1990) remains. I was wondering, as the Bakerloo line is nearby, could this be extended beyond the end of the shaft, to link up with the Bakerloo? If it was, it would eliminate the need for a crane to get trains in and uot of the Drain.
Drsatan
24 Aug 2009
Land of the Sprinters
Even though I'm no infrastructure expert, that would be quite difficult and costly because of the need to bore a large hole in the Bakerloo line tunnel which would affect its structural integrity. Moreover there would be water mains, gas pipes etc. which would get in the way of any extension.
A60K
26 Jun 2008
Kilburn
As the trains only need to leave the line once every 10-15 years it's simply not worth the money to link the two lines. The stub to the lift isn't very long at all, and if you tried to extend it and burrow down you hit the basement car park or foundations of the international terminal, let alone any other subterranean obstructions or alignment issues. Construction of this is why the lift was removed in the first place, as well as the planned new stock being to LU spec so that it couldn't be maintained easily at a mainline depot. Interestingly the original plans would have had the W&C stub realigned into the international terminal car park so that stock could be removed and brought in by road, and it was only once construction started that the Lower Marsh crane arrangement was put in place instead.
robertclark125
12 Mar 2008
Cardenden, Fife
Put me right on this one guys, is the crane a permanent one, i.e. fixed to the ground, or is it a lorry, hired in?
And while I remember, where is the W&C hole? I couldn't find it on google earth lol!
Capybara
10 Sep 2009
SE11
Both. There is a small permanent crane for, presumably, lifting small stuff in and out. When trains are removed or replaced, they bring in a big crane on a lorry.
http://www.london-se1.co.uk/news/view/2099
The 'hole, is on Spur Road where Lower Marsh and Baylis Road meet, close to the Old Vic.
Bill EWS
10 Feb 2006
Didcot
Here is a Google Street View of the lift on Spur Road, with Waterloo Station in the Background.
steve099
10 May 2009
Amazing. I go past Spur Road every day and never noticed that. Certainly wouldn't have realised it was for the W&C.
Royston Vasey
14 May 2008
Cambridge
This was featured in an episode of Monster Moves, screened on Ch 5 some time ago. It causes immense disruption, closure of roads and requires pinpoint placement of the crane to avoid underground infrastructure.
I can't find a link to the video online, sorry, but it's season 2 episode 3, look out for a repeat on National Geographic channel or Five.
http://www.locatetv.com/tv/monster-moves/season-2/541659
SWT Driver
29 Aug 2009
The Twiglet Zone.
Just out of curiosity.
How much difference is there in height between the DLR station @ Bank & the W&C line platforms?
Because if it's not that much, wouldn't it be a prudent move to link them up & then use the W&C for an extension of the DLR?
Or is that called being too sensible again?
I've always wondered whether it might have been worth joining the Waterloo and City to the City and Great Northern line through Finsbury Park to Highgate to create a sort of Northern Line relief route. As it turned out the eastern region had it's eyes on the City and Great Northern anyway !
18 Apr 2009
South East
See this diagram here: http://husk.org/www.geocities.com/athens/acropolis/7069/ltmonu.jpg
The problem is not so much the difference in height, but the fact that the two sets of platforms are at right angles to each other. Plus the Jubilee line now runs from Waterloo to much of the area served by the DLR, so I wonder how many people would take advantage of a DLR extended via the W&C. An extension to Moorgate (and from there to FPK) from Bank for either line might be more useful, especially for relieving overcrowding on the City Branch of the Northern Line.
tbtc
16 Dec 2008
Reston City Centre
At the other end, what would the chances be of linking the Waterloo & City line with existing services into Waterloo "overground"?
Just thinking that if some of the "local" services into Waterloo could be diverted "underground" to Bank, this would both save platform space at Waterloo and give a link to "the city" from places like Wimbledon.
Presumably the answer is "completly impossible"...
Mojo
7 Aug 2005
Not impossible, just vastly expensive. Both are the same thing in political terms.
10 Feb 2010
As far as im aware the tunnel bore is too restrictive for DLR and much too small for normal mainline stock.
Chris
Aictos
28 Apr 2009
Well the Green Party had a idea of connecting the Northern City Line to the Waterloo and City and using existing track to Richmond which can be found on the Wikipedia page for the Hertford Loop.
The plan was for services from Hertford North and Welwyn Garden City to offer a direct service to Richmond.
Interesting but not practical as they also had ideas for a relief loops at points along the line which would never happen but should ie Watton At Stone, Cuffley and Gordon Hill, Gordon Hill having both bays in use and converted to though lines and Cuffley/Watton At Stone having the loops the north end of the stations.
jopsuk
13 May 2008
To run mainline stock through the existing W%C would require the tunnels to be considerably bigger. Ideally, all the platforms involved would want to be eight-car as well otherwise on the W&C section you'd create massive overcrowding I reckon.
Aictos
28 Apr 2009
They did confirm that the W & C would need to be enlarged along with new tunnels linking Moorgate to Bank and the W & C to the mainline at Waterloo.
No word on how long the trains would be though but the only station on the Hertford Loop which will have trouble being extended to take is Hertford North with the pointwork at the South end of the station and the bridge at the north end of the station although Platform 1 could easily be extended southbound, Gordon Hill might have a issue but the vast majority of stations from Letchworth to Finsbury Park could take 8 cars with no problems providing platforms get extended, it's the NCL which is the really restrictive part as it's limited to 6 cars - if the restriction wasn't there then 8 cars in the peak would probably be the norm.
Thats interesting - I always imagined it as a tube line. That said, they managed to enlarge the central section of the central line in the 1930's so the Waterloo and City wouldn't have been impossible by any means.
Aictos
28 Apr 2009
Well I found the text highlighting the basic idea that the Green Party had:
Green Party proposal
The Green Party has proposed that the Northern City Line be connected to the Waterloo & City line to create a new cross-London route.[citation*needed] The core section of the route would be from Finsbury Park to Clapham Junction via Moorgate, Bank and Waterloo, with a new connection at Blackfriars. Through services could then run from Welwyn Garden City and Hertford North to destinations like Hounslow, Richmond, Shepperton, Kingston and Weybridge, thus enabling much better use of the capacity offered by this part of the network, particularly outside city commuting hours.[3] However, the Waterloo & City was designed and built as a deep tube line; were this to be connected to the Northern City line this would mean either a reversion to using deep tube stock along the whole length (as when the NCL was part of the Northern line), or converting the Waterloo & City for main line sized rolling stock. The latter would be made more difficult still because of the tight curves, which would not suit conventional carriages. It would therefore probably mean boring completely new tunnels for much of the length.
http://www.networkrail.co.uk/browse documents/rus documents/route utilisation strategies/east coast main line/consultation responses/g/green party.pdf
