Watford may not lose a service but does lose a route as it no longer has the direct LM one serving the Trent Valley line.In the draft timetable here http://www.rail-reg.gov.uk/upload/pdf/project-110-timetable.pdf
the current nn46 Euston-Crewe/Birmingham via Northampton is replaced by two 110mph trains:
1. nn46 to Crewe (MKC, RUG via Weedon, TV stations to Stafford then Crewe via Stoke.
Pathing is 10min slower than now north of Rugby
2. nn49 to Birmingham (WFJ, MKC, NMP [14min dwell] and then picks up current path to BHM).
3min faster to NMP, otherwise the same as now.
Thus Watford does not lose a service.
The press release does not make clear if both new trains run from December.
With a 5 minute connection on the down and 13 on the up at Rugby still good connections and a much quicker journey for the vast majority.Northampton is going to revert back to pre-2004; with just destinations to London and Birmingham. A big step back, IMHO.
Without wishing to sound rude, could we please stay on topic by not discussing infrastructure improvements on other lines. There are plenty of different threads for that sort of thing! Thanks.
In an ideal world you'd like to serve Nuneaton, Tamworth & Lichfield off the WCML, but atm it's just not feasible.
I should think the ICWC franchise will be quite content with this. It reduces the pressure on them for off-peak long distance services to stop.
Infrastructure? Rolling stock I'd have thought, considering the MML is already 110mph in various places and is being upgraded to 125mph in decent chunks.
It seems perfectly relevant to the topic, as cle was essentially saying he thinks other TOCs should follow LMs lead.
It does seem to me like the new timetable is essentially a win/lose situation, seeing as some lose while others gain.
The pressure for the reinstatement of Rugby, Nuneaton and Tamworth services is not just about fast trains to London: it's about Northbound services too, especially for passengers that connect through these interchange points. The new LM timetable does little to help with Northbound.
The one thing that LM helped on was trips to Northampton. That's now going to require a connection, halving the reliability of the trip, so I'll be back in the car for that one.
Paths that are sat in Dec 12 avoid Northampton both ways. xx.02 off Crewe with a xy.49 arrival at Euston. xx.46 off Euston with a xy.24 arrival at Crewe.
I thought I'd check; Do 350's have tilting capabilities?
Slightly off topic and probably answered elsewhere, but why wasn't the Northampton loop upgraded to allow 110mph (at least) during the WCML upgrades?
At last, the remainder of the Press Release (not on the news item) and confirmation :Thats published news item, do you want the original press release?
I am also currently awaiting a confirmation of some other details, specific to the rolling stock; the press officer doesn't know the details
No the Brum - Liverpool remains unchanged. The connection should remain in both directions, if a little longer.
However, can anyone work out the potential impact of LM's higher speeds for a potential service all the way through to Manchester? I.e. 2tph up the TV, one going to Crewe via Stoke, the other continuing to Piccadilly?
So something like: Watford Junc, Milton Keynes Central, Northampton, Rugby, Nuneaton, Tamworth, Lichfield TV, Rugeley TV, Stafford, Stoke on Trent, Kidsgrove, Congleton, Macclesfield, Poynton, Cheadle Hulme, Stockport, Piccadilly
No they won't. LM did want to extend the London-Crewe service to Liverpool and divert the 2nd hourly Birmingham-Liverpool to Preston but this was disallowed by the ORR.Am I reading it right that LM will run to Manchester?
It surely can't be true that the BHM-LIV services remain unchanged? That would beggar belief.
