Surreytraveller
- Joined
- 21 Oct 2009
- Messages
- 2,810
Only since September. Before that it was about 15 minutesThat's been the case for a while
WMT run semi fasts too. Currently 0813, 0913 1713 and 1813 paths off Shrewsbury. 1813 is also a diversionary route maintainer.But the semi-fast service is run by TfW and extends down the North Wales Coast. There will be many examples of where units/diagrams could be saved by merging the operations of multiple TOCs. If only the idea of a single operator for the entire network had been tried before!
It is a lot!Why 17 minutes longer than 20 years ago? The new trains can run at speeds of 177km/h (110mph) as opposed to 161km/h (100mph) south of Hitchin and like speed has increased in places like Shepreth. On the flip side, Cambridge (Central) is busier, the new grade separated down line north of Hitchin is slightly longer, and there are many more trains particularly along the Cambridge line between the ECML and WAML, and Cambridge North is an additional stop. But 17 minutes longer seems a lot!
Believe it’s something to do with having multiple pantographs so “close” (80m apart) together at speeds >100mph on the catenary. In theory a 4 coach could run at 110mph but 8/12 can’tGN 387s are not cleared for 110mph running on the ECML. Not sure why they’ve not even tried for it in the past.
I would imagine GN are happier keeping any extra time for padding & general reliability. The ESRs on the north end of the route over the last few months haven’t helped.
The line speed south of Woolmer Green is 100mph so the potential time saving from running at 110mph is measured in seconds.Believe it’s something to do with having multiple pantographs so “close” (80m apart) together at speeds >100mph on the catenary. In theory a 4 coach could run at 110mph but 8/12 can’t
At the risk of going off topic, I'll take your Wrexham Central - Bidston and raise you the Stourbridge Town - Junction service for shortest turn around (based on the public timetables)...It depends on the location and traction in question. The Wrexham Central-Bidston service has a 3 minutes turnround at each end, pretty much all day long. Hence it can't call at all stations and as soon as there's any disruption, it struggles to recover for the rest of the day.
3 minutes is about the shortest turnround time you will get anywhere, but tends to require a location-specific exception from the default value, which is generally 5 minutes for the quickest traction types (short DMUs/EMUs).
There is a lot to do with the 80m rule & the OHL. Take the 755 fleet (I know it’s only 100mph) but pans must be this distance apart when running in multiple. If for any reason they are not which could be two 3-cars with both D coaches coupled or a 4-car with the furthest pan isolated & therefore not 80m separating them, then one of the units will automatically operate in diesel mode.Believe it’s something to do with having multiple pantographs so “close” (80m apart) together at speeds >100mph on the catenary. In theory a 4 coach could run at 110mph but 8/12 can’t
This is just something I remember being told though, so it could be absolute <insert expletive of your choice>
Can it not be timetabled to commit two units/crews at any one time rather than three?The current York Scarborough hourly shuttle has over 50mins lay over in York for most of the hourly services, I know that the single platform at Malton doesnt help timetabling, the optimum timetable means that both trains arrive at Malton within a few minutes of each other, and delays then result. That was one of the errors in the May 2018 timetable fiasco, east and west bound services arriving within 3 mins of each other at Malton.
Current daytime pattern is leave Scarborough xx:34, 50 mins to York, arrive xx:24, 53 mins wait, xx:17 depart York, 49 mins to Scarborough arrive XX:06, 28 mins wait leaving again at xx:34
Sorry I guess it's the "Malton problem" which prevents that.Can it not be timetabled to commit two units/crews at any one time rather than three?
Not really. If you departed either end at the same time, the trains would meet at Malton - but Malton only has one platform.Can it not be timetabled to commit two units/crews at any one time rather than three?
How come, I assumed being push pull it wasn't very different from a normal DMU.Class 68/Mk5 rolling stock, as this requires 12 minutes for reversal/turnround
Presumably it's just the value that was agreed upon between the company and the union. It does seem rather excessive value though, akin to the 15 minutes mandated for a Pendolino!How come, I assumed being push pull it wasn't very different from a normal DMU.
So if you put in another station somewhere on the line and thus lengthen the journey time, it wouldn't affect the service and might create a greater gap between trains arriving at Malton, thus reducing operating difficulties ?Not really. If you departed either end at the same time, the trains would meet at Malton - but Malton only has one platform.
So you would either need to have the York-bound train run non-stop through Malton on the (non-platform) Up line, which would render the station useless, or retime things so that one of the trains ran later. But that would then mean a short turnround at one end, thus impacting reliability - particularly given the Malton platform constraint.
Even if you built a second platform at Malton, such a shuttle wouldn't work with the current Class 68/Mk5 rolling stock, as this requires 12 minutes for reversal/turnround - which clearly wouldn't work with the 50 minute journey time. So again you'd have to skip e.g. Seamer.
It's not a question of operating difficulties, I was just illustrating why it wouldn't really be practicable to run the line using two sets.So if you put in another station somewhere on the line and thus lengthen the journey time, it wouldn't affect the service and might create a greater gap between trains arriving at Malton, thus reducing operating difficulties ?
It seems excessive to me as well, that is not to say that it is, I am not a driver and I don't know but that was closer to being a question to a statement.Does it? I take it you have experience of driving and operating the stock in order to make that comment?
I have experience of observing how long it actually takes! The process isn't as quick as your bog standard multiple unit, but I've never seen a driver need the full 12 minutes.Does it? I take it you have experience of driving and operating the stock in order to make that comment?
I believe 12 mins may have been specified by the manufacturer (CAF) and may in part at least be related time 'required' for on board systems - perhaps the contract for delivery did not specify a requirement for a change ends time.I have experience of observing how long it actually takes! The process isn't as quick as your bog standard multiple unit, but I've never seen a driver need the full 12 minutes.
It is likely that 12 minutes is specified since that's the longest it would be expected to normally take, rather than the minimum or average. "Under-promise and over-deliver" and all that.I have experience of observing how long it actually takes! The process isn't as quick as your bog standard multiple unit, but I've never seen a driver need the full 12 minutes.
The rolling stock manufacturer won't specify the reversal time. It will be an agreement between the company and the union.I believe 12 mins may have been specified by the manufacturer (CAF) and may in part at least be related time 'required' for on board systems - perhaps the contract for delivery did not specify a requirement for a change ends time.
I fully accept the reversal time will be an agreement between company and union but it may be the way the manufacturer's software is set up has driven this timing. In ordering stock the TOC and ROSCO should bear in mind the timetable the train is planned to operate to and specify accordingly and in this case 12mins is longer than some of the planned turnrounds at the time the train was ordered.The rolling stock manufacturer won't specify the reversal time. It will be an agreement between the company and the union.
no need to bite Watershed's head off for that post.
Same at my TOC. It is a disciplinary offence to go into a licenced premises while on duty/in uniform. As others, again I assumed this was just a normal thing. We don't have a buffet car so that issue doesn't arise for us!
Does that mean you’re not allowed go in a station ‘Pumpkin’ to have a cuppa as they mostly serve alcohol for consumption on the premises? Must rule out most station buffets!
