The full completion (most of which doesn’t require the road closure) is delayed until 2024 now. There’s been further problems so I think we’ll be lucky for it to be open to two way traffic this year, I believe it was supposed to be open in time for the Festival.Does anyone know when North Bridge will be open to two way traffic again?
We know how much of a struggle the roads are when they’re all open during the festival. I certainly hope North Bridge will be open by July/August, however I just can’t see that happening. Originally it was never expected to be closed at all, but it became clear fairly quickly that that was never going to be possible.The North bridge diversion reroute simply will not cope during the festival. They have to get that road open and do whatever it takes to make that happen and keep it that way. The entire city even without trams running down Princess Street which is certainly helping the situation is still capable of falling over with a moment's notice right now because of the huge number of diversions. Gorgie road to Brunswick road on the 25 yesterday evening took 90 minutes
Last time I had the misfortune of riding the 37 all the way from south of the diversion to home in Muirhouse, the diversionary route itself took exactly 52 minutes according to Google maps timeline
There's talk around the garage of one. Something is in the works, all will be revealed shortly.does anyone suspect we’ll get a service change in April at somepoint? It’s been almost 6 months since the last service change so you have to wonder
You make it sound like there's something big and exciting planned although I know that's probably not the case!There's talk around the garage of one. Something is in the works, all will be revealed shortly.
It has been confirmed by the MD that a network review is taking place with a view to implementing any changes before the summer. That’s all we know so far.You make it sound like there's something big and exciting planned although I know that's probably not the case!
I think you’re being very ambitious there, I can’t see many ‘improvements’ on now. Possibly the odd thing here and there but certainly in most larger companies the number staff absences have stayed at a consistent level for a few months now, not one that is probably good enough to increase much. The 300 could be busy that’s the thing, but I understand why Lothian have taken the approach they have.I predict a frequency increase for the 21 and 30 which should never have been cut in the first place
Some city centre services which are having to cope with more than one big diversion split to improve reliability at either end to the route to prevent buses being spun round early which has become a pandemic all of its own in recent times
An increase in frequency on routes which duplicate or partially serve suburban rail routes that have seen frequencies savagely butchered by ScotRail and it's death of a thousand cuts approach to post covid service levels
Airlink frequency increase
Complete withdrawal of the 300 or a total fresh approach with a new route
Trial reintroduction of the X5
Speeding up of the x27 to cut journey time between Edinburgh and Livingston two under one hour
Yeah I’m not sure how you’d speed up the x27 either unless you put it straight onto the A71 at Lizzie Brice and miss out Mid and East Calder which would make no sense.I predict a frequency increase for the 21 and 30 which should never have been cut in the first place
Pending a massive change in staffing levels between now and the summer, I can’t see any increases being possible.
Ah fair.It has been confirmed by the MD that a network review is taking place with a view to implementing any changes before the summer. That’s all we know so far.
Ah fair.
A sensible thing I think would be to start thinking about introducing the planned changes from before COVID, like changing the 124 to become the X24... I can't remember what many of the other changes planned were though.
I'm going to stick my neck out here and predict that LCB will pull out of West Lothian.I predict a frequency increase for the 21 and 30 which should never have been cut in the first place
Not a chance. With all the money put into the depot at Livingston and work still going on there as we speak?I'm going to stick my neck out here and predict that LCB will pull out of West Lothian.
If I remember right the plan was to make all 124s limited stop Edinburgh to Musselburgh then all stops from there. The services which used to run as X24 in the peaks would then be replaced with additional X5s.I don’t think there were any plans to change the 124 to become the X24 full time, however the fact it’s still not been introduced for peak times is surprising, maybe when the X5 returns we could see this happen!
I don't really see the point in that to be honest, the 124 doesn't extend that far up Lothian Road and the 26 runs between Shandwick Place an Portobello with high frequency anyway.There were plans on the 15 extending to Eastfield to accommodate the 124 between Lothian Road and Portobello with a 15 minute frequency
I wouldn't say that it has no use, but it's certainly not as good as it used to be. I've been trying to think of how it could be "improved" (i.e. cost less to run without loosing links). The route could be truncated at the Gyle and run as a 35 Gyle to Semple Street? There would still be the 400 every half hour to connect to the Airport, plus there's the tram.But as for the 300, either it should be withdrawn as it’s pretty much been cut down to the point of no use, which would be a shame giving the route number would be a waste, or rebranded again!
I had been thinking about how to improve the airport routes in general, the first thing I would do is make them limited Stop across the whole routes.If I remember right the plan was to make all 124s limited stop Edinburgh to Musselburgh then all stops from there. The services which used to run as X24 in the peaks would then be replaced with additional X5s.
The 45 provides a direct link from the Tollcross area down to Portobello anyway.
I was on the 276 yesterday afternoon (towards Broxburn) and, I kid you not, it went from having three or four people to completely filled with approximately seven people standing.I'm going to stick my neck out here and predict that LCB will pull out of West Lothian.
From personal Experience, and from my family who also use them, the X27/X28 can be quite busy across the route, especially on the Edinburgh to Mid Calder section, the 280 is increasingly popular, especially with the unreliability of the X25. I don't see LC leaving West Lothian any time soon and if they play their cards right, they might find themselves the only big operator in the area, with the ever declining service from FirstI was on the 276 yesterday afternoon (towards Broxburn) and, I kid you not, it went from having three or four people to completely filled with approximately seven people standing.
My point is that Lothian Country are doing relatively well in West Lothian (minus the 275) with the X27/ X28 being quite busy going towards Bathgate/ Whitburn with the X18 being relatively full in either direction (I relised I've neglected the 280 as I don't often see that one so I cannot comment).
One of the main reasons the 200 does the route it does is because it replaces the 32. By sending it along Ferry Road it then just duplicates the 21 near enough the whole way from Ocean Terminal to Drum Brae (bar Blackhall) which in my view isn’t pointless, but doesn’t offer many benefits. It’s very well used on its current route, especially early in the morning where transport to the Airport used to be much harder. Airlines have a number of lodges on the route that crew use as nightstops and the airlines have (in many cases) deliberately picked ones on the Skylink routes as they are cheaper.200 - I would run it Airport - Maybury - Drumbrae S/N - Queensferry Rd - Telford Rd - Ferry Rd - Ocean Terminal (via Ferry Road as there are several B&Bs along there with potential for passengers)
The 400 is successful as it is now due to the fact its a southern orbit route. Making it express will cause passenger numbers to decline400- Exactly as is but Limited stop
Fair points here, I hadn't really considered the replacement of the 32, and the lodges factor.One of the main reasons the 200 does the route it does is because it replaces the 32. By sending it along Ferry Road it then just duplicates the 21 near enough the whole way from Ocean Terminal to Drum Brae (bar Blackhall) which in my view isn’t pointless, but doesn’t offer many benefits. It’s very well used on its current route, especially early in the morning where transport to the Airport used to be much harder. Airlines have a number of lodges on the route that crew use as nightstops and the airlines have (in many cases) deliberately picked ones on the Skylink routes as they are cheaper.
The Skylinks are different to the Airlink in my opinion. For me the primary purpose of them is to offer the suburban connections, and secondary to that is the premium Airport journeys - which are still important - The 300 was like this before but as we all know is a bit of an oddball these days. From my experience the Skylinks are more used by locals than tourists, but this may have changed. The Airlinks main market is and always will be the journeys to and from the Airprort, very few use it as a suburban bus and with the introduction of the X18 and the set down only in some places Lothian have tried to move away from that as well.
There’s not that many B&B’s on Ferry Road, don’t get me wrong there’s more than the current route but not enough to justify it in my view, not to mention some of the congestion you’ll get along there as well.
Yes.Doesn't the 400 already serve RIE?
