stevenedin
I agree on those hybrids. I don’t like them. I prefer the B9TLs.Its not really when the Hybrid Gemini 3s are on it doing a lower speed on the motorway than what most of the B9s can achieve
I really like them - but they should be prioritized on the 43 and 72 with minimal appearances (or none) on the X27/8 or X40. One is on the X40 today. Hopefully as 846-850 join and possibly some 09s these occurrences are less frequent.I agree on those hybrids. I don’t like them. I prefer the B9TLs.
Any idea why Lothian have limited their B5LHs to such a low top speed? The ones at Stagecoach East Scotland reach and sit at 50mph comfortablyIts not really when the Hybrid Gemini 3s are on it doing a lower speed on the motorway than what most of the B9s can achieve
I suspect it’s got something to do with the fact these were new for the Skylinks which are generally stop-start routes. Ideally they need retuned.Any idea why Lothian have limited their B5LHs to such a low top speed? The ones at Stagecoach East Scotland reach and sit at 50mph comfortably
Has it been confirmed that 847-850 and 926-935 are rejoining the fleet and moving to Lothian Country?I really like them - but they should be prioritized on the 43 and 72 with minimal appearances (or none) on the X27/8 or X40. One is on the X40 today. Hopefully as 846-850 join and possibly some 09s these occurrences are less frequent.
850 has been photographed with frames added and Lothian Country branding put on. It isn't confirmed what the plan is with 926-936 but 936 has moved to Seafield and is understood to be losing it's East Coast Buses branding while 933 which was sat outside yesterday has gained a nearside fleet number - not that this means anything.Has it been confirmed that 847-850 and 926-935 are rejoining the fleet and moving to Lothian Country?
Thanks, interesting to hear about 936 moving away from East Coast Buses.850 has been photographed with frames added and Lothian Country branding put on. It isn't confirmed what the plan is with 926-936 but 936 has moved to Seafield and is understood to be losing it's East Coast Buses branding while 933 which was sat outside yesterday has gained a nearside fleet number - not that this means anything.
Yeah they need retuned definitelyI suspect it’s got something to do with the fact these were new for the Skylinks which are generally stop-start routes. Ideally they need retuned.
For a mostly high speed A Road, dual carriageway route it would be ideal to have the best performing B9TLs allocated to it, preferably with limiters removed.I really like them - but they should be prioritized on the 43 and 72 with minimal appearances (or none) on the X27/8 or X40. One is on the X40 today. Hopefully as 846-850 join and possibly some 09s these occurrences are less frequent.
Limiters removed? You know that's an MOT fail, and PG9 prohibition.Yeah they need retuned definitely
Again, this is set at time of manufacture, to alter would render the bus an MOT failure and result in a PG9 prohibition.What they mean is allow the bus to operate at 53mph instead of the current 40mph.
Correct me if I'm wrong but aren't some ex-London buses specifically modified to allow for "country running" with higher speed limits than in the cities?Again, this is set at time of manufacture, to alter would render the bus an MOT failure and result in a PG9 prohibition.
Weren’t the ex London’s gearboxes retuned rather than the limiters touched?Correct me if I'm wrong but aren't some ex-London buses specifically modified to allow for "country running" with higher speed limits than in the cities?
Frankly the hybrids should be reserved for city work, and swapped with an equal number of B5TL MMCs of which would be better suited.
I'm not specifically referring to Lothian by that, as Lothian (city)'s probably go as fast as London's did!Weren’t the ex London’s gearboxes retuned rather than the limiters touched?
Yes, you're wrong. The gearbox was remapped.Correct me if I'm wrong but aren't some ex-London buses specifically modified to allow for "country running" with higher speed limits than in the cities?
Yes, under the construction and use regs. Exceptions are if it fails mid-journey and only to complete journey, and to travel to a place where limiters can be set or repaired.Except for 1050 none of the ex London B9TLs I've driven have been restricted to 40mph (or is it 38 in London?) - I believe they've had their limiters increased to 80kph.
When I started Cardiff Bus the incumbent MD specified that the Scania N49UD deckers were limited to 40 (except for two with tachos) - after he resigned the other 11 had their speed limiters altered to 100kph by Scania.
In my first job I took a B10M to Volvo with a faulty speed limiter (stuck at 38mph) - they removed the limiter while awaiting parts - are you sure this actually renders a PCV unroadworthy?
It's part of the first registration process. Yes, you can remove them, but if you make changes, this can only be done under extreme circumstances and the bus recertified. Removal or 'turning it off' will result in a PG9 and MOT failure, as well as action by the TC.Except for 1050 none of the ex London B9TLs I've driven have been restricted to 40mph (or is it 38 in London?) - I believe they've had their limiters increased to 80kph.
Buses at LB are calibrated for 50mph with coaches and the ECB B8's at 60mph.
It’s currently being swapped from a 2G system (yes really!) to I believe a 4G system. This should hopefully make it more robust. At the moment there is essentially an operating ‘square’ across the network and it doesn’t cover much of West Lothian, nor North Berwick, Haddington and Dunbar. So anything outside of these areas not fitted with a new AVL doesn’t track properly unless it is in service. Even then it’s not the best. If it’s not in service it will just straight line North to South track at the perimeter of this square.Can I also ask how they do their tracking as it always seems decidedly more vague than others? (looking at Bus Times for example it only seems to update position every few mins rather than every 30s like most of the others I’ve seen).
37MPH for all London buses i believeExcept for 1050 none of the ex London B9TLs I've driven have been restricted to 40mph (or is it 38 in London?) - I believe they've had their limiters increased to 80kph.
Does the X40 actually use the city bypass? Must be a nightmare. Can it operate in high winds?
Yes, Its only really a nightmare with congestion. And yes its only a bypass. As said above Lothian use it for empty moves to and from the depot all the timeDoes the X40 actually use the city bypass? Must be a nightmare. Can it operate in high winds?
Looking at it, the 73 and 74 must be interlinking. A one minute layover at Livingston on the 73 wouldn't be sufficient.
Why do you think the 72 timetable is bad? Serving Pumpherston and Eliburn was always expected to take some extra minutes.That new 72 Timetable is worse than what Horseburgh offered when it operated the awful 557 service, However I see they have put in some extra buses around 6.30am. Maybe they are watching the social media posts from passengers?
