That's not necessarily true - it depends what sort of a 'failed train' we're talking about. When an AC loco/unit brings down half a mile of wires on the WCML/ECML, it can cause hours and hours of heavy delays for huge numbers of people - and this happens depressingly often. It too might indeed be running ECS or light engine, and therefore merely be 'playing at trains', as you put it.
If an AC loco or unit was running ECS or light engine somewhere, this is more than likely going to be a much needed positioning move so said loco or unit can run in a revenue earning service. This happens every day, in an ideal world every stock move will be in a revenue earning service but this just isn't possible, unless you want to do maintenance on them in the termini instead of the depots.
No one *needs* a steam engine to run, it is just a hobby and should be kept off major revenue earning routes such as the ECML because people actually *need* these. Exactly as 4SRKT says, I would much prefer to take a steam train over the Settle + Carlisle instead of the dull ECML. If a steam engine needs to go over these routes then they should be hauled by something that is used all day, every day. Which also means that the loco doing the hauling, will be in a revenue earning service.
