Markings along platform
Discussion in 'Infrastructure & Stations' started by aformeruser, 22 Nov 2011.
Thread Status:
  1. aformeruser
    aformeruser Veteran Member
    30,637
    23 Jan 2009
    I've noticed on the brickwork under the Chester bound platform at Knutsford they've painted vertical yellow lines at equal intervals then in between the lines they've put letters A through to Z, then continued AA, AB, AC and AD, giving 30 in total. Is this related to measuring the platform length?
    Rail Forums
  3. ANorthernGuard
    ANorthernGuard Established Member
    2,564
    8 Oct 2010
    I never noticed, I'll have a look next time I'm through there and figure it out (or ask a P-way lad) as they are doing alot of work in that area, Track renewal etc. it may have something to do with that
  4. asylumxl
    asylumxl Established Member
    4,260
    12 Feb 2009
    Hiding in your shadow
    Maybe for measuring the level of the platform or track using an automatic level? Seems a rather inaccurate way of measuring for anything but more than that.
    If it's not that, not a clue.
  5. Ploughman
    Ploughman Established Member
    2,222
    15 Jan 2010
    Possibly platform gauging locations so they measure the same point each time.
    And record it the same way each time as well.
    Is the platform a long one?
    Is it curved?
  6. aformeruser
    30,637
    23 Jan 2009
    I only noticed it yesterday and it looked fairly fresh paint.
  7. Old Timer
    Old Timer Established Member
    3,704
    24 Aug 2009
    Track renewals datum markings are always done on the platform wall so it is likely this will be in conjunction with a track or vehicle clearance survey.
  8. aformeruser
    30,637
    23 Jan 2009
    The platform in the other direction is the same length and has stop boards for 4 car and 6 car. The one that's marked doesn't have a stop board but every train stops at the furthest end of the platform. Both platforms are straight.
    At one end of the platforms the A50 goes over the railway lines, at the other end there's a bridge where the railway lines go over a minor road.
  9. 142094
    142094 Established Member
    8,782
    7 Nov 2009
    Newcastle
    Best marking I've seen on a platform is "Class 142 here" in chalk. This was at Darlington after a Northern service rear-ended a 225 set.
Thread Status:
Share This Page
