Years since I was last there but:I suspect at Ormskirk and Kirkby it was to simplify signalling. I don't know about Ellesmere Port, though.
there is still a connection to the docks West of the station requiring access through the northbound platform, which is the principal one (car park side....). The layout was, I would guess, unaltered at electrification apart from replacing shunt signals with running signals, and it is (was very recently?) still locally controlled.
Also, was there not some possibility of extending electrification East at one time?
Ormskirk and Kirkby have buffer stops so two trains can operate (one in each platform) at the same time, as the platform is essentially, just one long through one. Ellsemere port is a pair of platforms, so no need for buffer stops, as an overrun isn't going to cause much, if any, damage. Unless it overran all the way to Helsby!
Yes, it can be done, but requires more complicated signalling.This doesn't seem plausible given that similar situations arise at other stations, yet they don't have buffers. For example, platform 1 at Ashford International is used both by terminating services from Brighton and from Victoria (see the 10:18 from Brighton and the 10:21 from Victoria both occupy platform 1 at the same time), while in Tonbridge platform 1 is used both by terminating services from Strood and Victoria (see the 10:39 from Victoria and the 10:55 from Strood both occupy platform 1 at the same time).
I wonder if Merseyrail could be extended to Preston or Wigan , though it would be new third rail !
Although the freight line west of Ellesmere Port station to Manisty Wharf on the Manchester Ship Canal currently has no traffic, it is still extant and available for use.
Hooton to Helsby is a potential diversionary route and is also used very occasionally by special trains. Northern ran through workings a couple of years ago to celebrate the line's 150th anniversary. One of these continued to Lime Street via the Halton curve.
Presumably the lack of through lines at Ormskirk and Kirkby are due to the lack of accessible freight destinations south of those stations.
Reinstate both curves, extend Merseyrail to Burscough Bridge (only short third rail extension) and divert Preston-Ormskirks to Southport? Or alternate between Ormskirk and Southport if Ormskirk folk weren't happy with it..)
Further ahead, with electrification of Wigan-Southport, then Burscough Bridge-Preston, dual voltage units could run Liverpool-Preston direct..
A sensible proposal, but it would inconvenience residents of Ormskirk travelling north if the direct service from Ormskirk to Preston was removed.My personal view on the most sensible thing to do is to reinstate both Curves, mothball the direct Rufford-Burscough Jn line, and run services as Preston-Burscough Bridge (hourly, one unit), Liverpool-Burscough Bridge (either half hourly or every 15 minutes depending if redoubling was affordable) and the Manchester services as at present. The station is only immediately surrounded by car parks and low-grade industrial units, so a rebuild to add two more platforms, perhaps as two islands, would not be out of the question.
Burscough seems a really daft place to start terminating services - it's not actually a very big place.
Possibly a solution for those three rural basket-cases would be to select one (probably the one in the middle) to retain and upgrade as a "mini-parkway" to serve the villages and hamlets that currently each have their own station for some reason.New Lane and Bescar Lane are not near anything and have very poor usage (the higher usage in recent years at New Lane is fare avoidance, as there is an evening peak restriction from Manchester to Burscough but not beyond it). Should we not simply close them (and probably Hoscar as well)? It probably costs more to serve them than it would cost to provide a free taxi on demand to Burscough or Southport for anyone living within walking distance (1 mile perhaps?) of one of them. While those visiting Martin Mere probably just take a taxi from Burscough Bridge rather than walk 2 miles up a dangerous country lane with no pavement.
Meols Cop OTOH could really do with being served by all trains.
