Merseyrail derailment - 28/10/2022
karlbbb
26 Jul 2009
Merseyrail website currently stating disruption on the Northern lines between Moorfields and Sandhills due to a derailed train, and their Twitter saying an “operational incident”. Anyone have any more info?
EDIT - Link to original tweet from Merseyrail: https://twitter.com/merseyrail/status/1585969474880126979
Merseyrail said:
Due to an operational incident in the Liverpool Central area- All Northern line services through Liverpool Central are currently subject to delay and possible cancellations.
hexagon789
2 Sep 2016
Merseyrail statement:
Acting Managing Director, Jane English said:
“Earlier this afternoon, just outside Liverpool Central, a train travelling at low speed in a non-public area of the railway tripped a safety device which is designed to lead to a controlled derailment.
“No passengers were onboard at the time and no-one was injured. We are currently working hard to move the stranded train, although its position means disruption for passengers travelling between Sandhills and Hunts Cross.
“Further information will be shared later this afternoon. Passengers are advised to check our social media feeds or website for the latest information.”
SamYeager
20 Mar 2014
Seems to be an unfortunate run of derailments this year. Just pure coincidence or indicative of other issues on the railway?
Crossover
4 Jun 2009
ADHDTog
5 Sep 2020
Wirral
What is "a non-public area of the railway" in this context?
There are stabling sidings past Liverpool Central in the up direction, towards Hunts Cross
Edit: I assume the road will be blocked until the RAIB get done? 24-48hrs minimum?
Maybe it's Merseyrails's way of retiring the old stock?!
66701GBRF
3 Jun 2017
No RAIB involvement.
AntoniC
28 Dec 2011
Southport
I was caught up in this on my way into Liverpool.
12:50 Southport to Hunts Cross I was on was held at Bank Hall due to this incident, as I had an urgent appointent in Licensed Premises in Liverpool City Centre I walked up to the main road and caught a bus into Liverpool.
On the way home I caught a bus to Bank Hall and then a VERY crowded train home to Southport, standing all the way.
I was glad I bought the £5.70 bus and train ticket and not just the train Day Ranger today !.
stuart100100
13 Dec 2009
Ormskirk and Kirkby trains have started running through to Central again. Southport to Hunts Cross still terminating at Sandhills
81097
9 Oct 2018
Normal service resumed this morning on the Northern Line through Liverpool Central
MR-507508
17 Jan 2020
North West
Trains from Ormskirk re-timed slightly since they are not using the reversing siding to turnback at Liverpool Central today.
Planned to turnback on platform 2, after Southport bound train has departed.
Is the unit still in the reversing siding at Central?
XAM2175
8 Jun 2016
Presumably the reversing siding. Stretching the definition of “non public” a bit given there’s a running line immediately adjacent.
I suspect that they wanted to convey that it was a section of line over which trains carrying passengers don't travel.
SteveM70
11 Jul 2018
RAIB will only be involved if there is something which needs investigating. Obviously it's clear cut and such involvement is not required.
Sorry if I’m getting the wrong end of the stick, but doesn’t RAIB’s remit also include prevention as well as investigation? Whilst the direct cause may be “clear cut”, how can NR / Merseyrail be certain there are no learnings, either for them or the wider industry?
GB
16 Nov 2008
Somewhere
RAIB would have been notified with the relevant information and then would decide what action they take. As this was caused by a signal passed at danger and derailed on trap points as designed, they probably decided there was nothing for them to investigate.
If it had caused further damage or risk (like Paddington a few years ago) then they more than likely would have attended.
skyhigh
14 Sep 2014
And if there's no allegation against signalling, infrastructure or rolling stock there's nothing for them to actually investigate on the ground. They know why and how the train derailed. If they wish they can review the TOC incident report and interview the driver to get further information, but there's nothing to be gained by a site visit before recovery can commence.
Surreytraveller
21 Oct 2009
If trap points have worked as intended, then the prevention methods have worked as designed. ECS train on non-public track. I expect the RAIB were informed as a matter of process, but they would have declined to turn up.
If a member of the public was on board and was injured they may have been interested, but only to the extent of how the passenger came to be on board the train
PupCuff
27 Feb 2020
Merseyrail will investigate the incident themselves. It's not a serious enough incident that would need RAIB to come in and do an investigation too.
Yes, however if the cause is known to be a SPAD then the TOC has their own established procedures for investigating and reporting, and ultimately addressing root causes. RAIB will certainly have been notified, but will only commence a full investigation if their initial investigations determine the potential for lessons to be learned.
81097
9 Oct 2018
I believe so yeah, 508141
karlbbb
26 Jul 2009
Thanks for confirming this. Went into Central last night and stopped in the tunnel before crossing over to platform 2. I had wondered if the reverse siding was inaccessible.
