- Joined
- 14 Jul 2011
- Messages
- 16,745
Uh.... no?Is this meant as a serious comment? The railway exists to serve its customers, not the other way round. Would you tell prospective passengers who want to travel from Manchester to Northwich that they should go to Stoke on Trent or Crewe instead?!
Why would anything I have proposed cause to happen?
Journey times for Northwich to Manchester would decrease with this proposal - especially when you account for the drastically reduced average weighting time (30 minutes for hourly heavy rail to just 6 with the tramway).
If you read the electrification standards, even if you assume 750V must have the same clearances as 1500V does, the clearences are clearly very different - you save multiple inches even with 'special reduced' 25kV clearances.Where is the evidence that 25kV electrification is colossally more expensive than 750V on a line like this? The OHLE structures and clearance requirements are not very different, and 750V OHLE, like third rail, requires frequent substations - expensive on a long rural line. 25kV could probably be end-fed from the WCML.
Additionally while there would be several substations on the route they would be predominantly be low power installations as five trams per hour would lead to roughly six light rail formations on the extension at any one time.
That is a very low demand for such a project. The substations would likely be fed from the 11kV and 400V networks.
25kV being single end fed from the Northwich end would require ~3 route miles more electrification (unless you are proposing a simple power line from the WCML and a detached project) and would still require a large amount of substation equipment (since I assume you are going to allow the branch to be isolated seperately from the WCML it is attached to - which will require one or more circuit breakers).
Then there is the fact that Network Rail cannot keep anywhere near its budgets for 25kV installations - which are already far higher than those generated for a relatively low power installation like the one I am proposing.
So how do you make the business case for investment in converting the line to a high frequency tramway, if you have "no real idea" what the demand will be? Northwich is a small town with a population of about 30,000 and lies outside the main Manchester commuter belt. Knutsford is less than half that size. Yet you are proposing the same service frequency as that currently provided on the Metrolink line to Oldham and Rochdale, which each have a population of over 200,000!
Quite simple - my business case is based on the fact that the trams will be deployed in marginal time, extending from Altrincham - operating five trams per hour requires only five additional formations compared to terminating at Altrincham. That is roughly an 4-8% expansion of the projected 2017 Metrolink fleet (depending on double fractions).
If you were operating tram trains half hourly you would require at least six+ additional formations as they would have to operate the entire journey from central Manchester (or even out of the other side). So your tram trains take more new vehicles for 2tph as they the conventional vehicles do for 5.
(And since you would have to buy them from scratch this is comparable).
Have you seen a modern freight train accelerate? 66s are powerful locos. For example, RTT shows that today's laden binliner from Brindle Heath (656M) took only 16 minutes from Edgeley Jn to Altrincham, despite having to accelerate from a stand at the junction and accelerate again after the 15mph PSR around the curve from Skelton Jn. Passenger trains, getting up to 75mph for much of the way, take 14 minutes with one stop at Navigation Road.
Have you ever seen an electric multiple unit accelerate? The Mid Cheshire line will be timed for Pacers, complete with padding.
A tram or modern electric unit will leave them for dead.
