I was under the impression that TFL use the term "Tube" to describe all LU lines on official publicity... although I don't tend to use the term myself preferring "London Underground" or simply "The Underground".I'm not a pedantic person, but reading professional journalists and even some enthusiasts describing cut and cover underground railways as tube does tend to rub me up the wrong way.:roll:
What about when TfL use it? Just like they do for anything related to the London Underground.
A few sping to mind are
'the tube upgrade plan'
On the website the underground category's are referred to as tube
And I don't really see why. Does it annoy you when it's called the underground because most of it isn't? Only 45% of it is actually underground so that name is also slightly misleading and false as with the tube. But it's just easier than calling it the tube and sub surface railways etc etc
Because it evolved out of the London Underground Electric Railway Company and London Underground Limited?
However the "Tube map" stretches things a bit far, but the cable car, London Overground, DLR etc absolutely do need to be on the map, but I do wonder if the map has outgrown its name?
There's no problem when people refer to proper Underground lines such as the Met, District & Circle as "the tube" even though the trains are certainly not tube stock trains. "The tube" has become synonymous with London Underground so people know what you mean.
But anything that is considered to be frequent appears to count as a "tube", with the most daft example I've seen being a bus service between Oxford and London calling itself a "tube" - this is just nonsense to me!
It is still the "Tube Map" but helpfully also shows connecting services from the same operator......
However the "Tube map" stretches things a bit far, but the cable car, London Overground, DLR etc absolutely do need to be on the map, but I do wonder if the map has outgrown its name?...
I said they absolutely do need to be on the map, it sounds like you agree with that? But the map seems to have outgrown the name "Tube map".I completely disagree that the DLR and Overground shouldn't be on the Tube map.
I don't think the term 'Metro' is any better than the term 'Tube' in this context.Surely the term 'Metro' best describes a frequent service and 'Subway' for all sub surface lines.
I completely disagree that the DLR and Overground shouldn't be on the Tube map. According to RAIL a couple of months ago the GOBLIN saw usage rise when it was put back on the Tube map. A lot of people won't use these lines if they're not on the map.
No problem, I realised that must have been the caseSorry Yorkie, I misread your post.
I worked with plenty of people that didn't seem to know about Thameslink as a very quick way to get from Farringdon to Blackfriars, compared to going around on the Circle sub-surface railway. (!)
It isn't (or wasn't) on every map so people never considered it when looking at the map to work out their route. And it's not surprising!
Subway simply means an underground walkway, and does not refer to trains in this country
Yes, if you're in Paris or New York. London has the Tube, in the same way that people Hoover their floors with a Dyson.Surely the term 'Metro' best describes a frequent service and 'Subway' for all sub surface lines.
I'd refer to the underground trains in Glasgow as the subway
I also refer to all tube stock as a "train" - because that is what it is. But I've known some people to be like "What are you talking about 'train' - it's a tube!"
It's part of the London vernacular.Re: the naming conventions, it annoys me when people talk of someone being "hit by a tube". This clanger appeared in a Metro newspaper not so long ago....
I really don't see anything wrong with it - use of the vernacular is part of Metro's style.My comment about the Metro was that "hit by a tube" is not an acceptable phrase for a national newspaper, I presume the sub-eds missed it.
