Add in order to replace 150s would make sense
Numbers-wise, the existing 195/0 order are part of the replacement of the Pacers.Do the 2-car Class 195/0 fulfil that requirement?
Did you mean to ask if a further order of 195/0s would be suitable?
I think that a follow-on order of class 195 (or 196) units for replacement of 150s would be a good idea, but I would expect to see it placed by the next franchise holder. (CAF are going to be delivering units to TfW until 2023, so the production line will probably still be active in 2025.)Indeed I do.
Should definitely have ordered 3 cars instead of 2. Very shortsighted.I'd suggest lengthening the 2s to 3 and the 3s to 4 may be a good "follow on order" bet. These units are likely to cause a big "sparks effect".
They obviously haven't learned anything from the 185 farce. Should've been orders for 3 & 4 cars.Should definitely have ordered 3 cars instead of 2. Very shortsighted.
Yes, 2 coach 195s are definitely a bad idea. Their published capacity of only 124 seats is less than on most 156s or 158s, so they will do little to solve overcrowding problems on many routes.they do have an option to add more carriages but it is the DaFT and they favour london more then anyone else.
They should've, but then this happens time and again and still they don't order to match demand or projected demand.
Unlike the previous time with the Class 185 units, this time they surely cannot claim not to have enough historical evidence of passenger demand.
Neither. The whole point of subsidising a rail service is to normalise the fares in areas that make big losses.Northern Rail has one of the highest subsidy rates in Britain.
And some of the lowest fares.
More units/ carriages would be brilliant but do the advocates want higher subsidies or higher fares?
Exactly, they can surely look at the relevant passenger figures and make an informed decision about how much capacity they need or get a projection on potential needs in the future but we keep seeing new trains ordered (not all the time though, some new trains have provided a capacity lift) with insufficient capacity for the short-term let alone any future rise in travellers.
They can look at the passenger figures based on ticket sales, and by guards' reports of overloading. They shouldn't tally because the guard can't get along the train to check tickets (and many don't when they can) and there are no barriers at most stations Northern serve. Revenue loss must be considerable. Running Pacer units on lines that had 3 coach steam and first generation DMUs is not an improvement.
As a diesel-only train that can't easily be converted to bi-mode or electric, the 195 is something of a technological dead-end. If we are to take elimination of diesel seriously then the next order should be of bi-modes or at least of DMUs that are capable of being converted. If that isn't possible at an economic price then perhaps it is the right thing to keep the 150s for another decade or so and see what happens in the meantime.
Perhaps we should view the 2-car version as something of a stop-gap to replace part of the Class 142 Pacer fleet. What would be the expected life-expectancy of these new units?
Having said that, ordering units which will mostly work in pairs without gangways was the work of an utterly imbecile organisation.
Nearly. Looking at the franchise agreement, the 3-car version is listed as having 204 seats, whereas a pair of 2-car units would total 248. But when you add in the specified standing capacity, it becomes 346 for the 3-car, against 442 for the pair of 2-cars.Where "paired 2-car" units are to be used (as a 4-car set) on non-electrified lines, on such lines (here I am thinking of the Clitheroe line as an example), would not the 3-car version provide seating capacity to meet the expected demand on such services which would allow the on-board rail staff to move freely the length of the train?
In the short-term, yes. Huddersfield to Sheffield is planned to have platform extensions to allow 3-car 150s (60m) which would still fit a 2-car 195 (46-48m), but that would then be the limit without digging up yet more of Huddersfield platform 1. Until the TRUG (Trans-Pennine Route Upgrade) is finalised and completed, bay platform lengths at Huddersfield are a problem. The need for the short platform 5 could be negated by interworking the Castleford and Bradford Interchange services, but this would result in a lot of fresh air being carried on the former (as it did in the days of the "Grand Tour" from Selby to Wakefield).Are there many places currently served by Pacers / Single 150s where anything bigger than a 2-car 195 would be impractical to use?
You could attach a motor to the body in place of the diesel engine, but that would use some of the space that might otherwise be allocated for batteries. The bogies may even be convertable to the 331 configuration with traction motors considering they probably use a lot of the same components. But as you say I presume they don't include a pantograph well or any fixings for a transformer. A battery hybrid is probably more likely to be assigned to a duty where each journey is partly under OLE, so it can be earning some money during its charging time, and for that a pantograph and transformer are essential.I'm not sure how hard it would actually be to convert to battery operation, though - in the end, the input is a rotating shaft at a given torque and speed - diesel is not the only way of providing that.
25kV rather more difficult due to a need to modify the body, though. And OHLE at the mainline junction is probably the easiest way to charge a battery unit on a branch line.
That was pretty much why they were ordered, although it's more of a cascade with the 195s directly replacing some of Northern's better units which are then transferred to more humble duties and most routes with Pacers now will probably get 150s. I assume they'd be expected to last 30+ years like other new units.Perhaps we should view the 2-car version as something of a stop-gap to replace part of the Class 142 Pacer fleet. What would be the expected life-expectancy of these new units?
That's probably so, but if more were ordered now (with a withdrawal date a couple of years further into the future than those now being delivered) would there still be a use for them towards the end of their lives? If the leasing company isn't confident of that then the leasing costs will go up.I believe the reason for ordering 2-car sets was indeed that they would, in the end, be the only DMUs left on non-viable-for-electrification branches unlikely to ever justify more (e.g. Ormskirk, Kirkby etc).
At least if more are ordered they could be the gangwayed variant like those being built for WMT and TfW.Having said that, ordering units which will mostly work in pairs without gangways was the work of an utterly imbecile organisation.
