Northern Class 195: Construction/Introduction Updates
Chester1
25 Aug 2014
I’d love for a situation where class 195s are so far down the Northern pecking order that they are only used on rural routes. When will that be, two franchises after this one?
Two franchises at ~10 years a piece, then they'd be getting on for 20-30 years old. I guess that'd be a reasonable age for them to be considered "bottom-of-barrel" stock.
I guess it depends on the definition of rural routes. I gave an example of three Northern Connect routes which would be suitable for battery power. Northern and its successors will need more stock to replace all the sprinters in the next 15 years. At that point the 195s will be less than half way through their usable life. The business case for new build DMUs longer than 2 or 3 coaches is very poor.
Bevan Price
22 Apr 2010
They may be too heavy for some of the most rural routes, and quite probably regarded as too high-powered & expensive to run to locations such as Whitby, etc. I imagine they will still be on the core routes (e.g. Calder Valley) until at least 2050.
There may have to be a new lightweight design of train to operate on some of the less busy rural routes where there is little opportunity for running at high speeds.
childwallblues
3 Jul 2014
Liverpool, UK
Unit end gangways would have been a good choice but I can see why 2 and 3 car units have been ordered. The 195s are likely to spend the majority of their 30+ year lives on rural routes. They are a short / medium term fix to improve services while the long term infrastructure and rolling stock picture becomes clear. Porterbrooks plan to add batteries to 350s going off lease shows how much things could change. With 2+2 seating they would be suitable for the Liverpool, Barrow and Windermere to Manchester Airport Northern Connect services. Arriva may have discussed longer 195s and simply been told no by the Roscos.
Liverpool to Manchester Airport would probably require four cars as the route includes Widnes, Warrington Central and Birchwood, all major population centres.
Clip
28 Jun 2010
The argument for 2-car DMUs is that as wires spread they will end up on branches, allowing 15x to be scrapped. I can't imagine Ormskirk-Preston or Preston-Colne ever needing more than 2-car.
Ive seen these services running as 4 car in the morning
Billy A
9 Jan 2017
I believe there diesel mechanical rather than diesel hydraulic and have the same multi speed ZF gearbox as the 172s.
K
I think it's a newer model but the same basic idea, it's a conventional car type automatic box. Interestingly one flaw with previous implementations of this gearbox for rail use is that the locking torque converter means that the train doesn't coast like a traditional hydrodynamic transmissioned one so the theoretical gain in efficiency is somewhat counterbalanced by the driver having to apply power going downhill, something ZF have addressed in their more recent gearboxes.
pt_mad
26 Sep 2011
I have no idea.
Let me rephrase it: I like the pattern.
Cool. Sometimes moquette describes the sort of velour fabric that is traditionally associated with patterned seats. Cloth seems to be making a wider appearance now, same sort of fabric used in car seats.
61653 HTAFC
18 Dec 2012
Another planet...
Not surprising coming from CAF
The 333s are pretty smooth and rattle-free, as were the CAF Spanish suburban EMUs I rode last month. Do CAF have a reputation for rattles then? How have they gained this reputation?
If it's just an issue with diesels, perhaps responsibility lies elsewhere?
js1000
14 Jun 2014
Unacceptable that it rattles and it's not even in service yet - that's something you associate with a 30 year train, not a newly built unit. Judging by the rattle it will be lucky to make it to 20 years in service if the workmanship is anything to go by.
superkev
1 Mar 2015
west yorkshire
I remember the ceiling panels of the 158s rattling when they where new and there certainly lasting
Eventually cured but things never happen fast on the railway.
K
TRAX
2 Dec 2015
France
My personal observation is that CAF is inconsistent with build quality. Some of their stuff is very well built and has a real impression of quality, while some others make their products look ‘low-cost’.
squizzler
4 Jan 2017
Jersey, Channel Islands
K
Noise attenuation on rolling stock is not my field of expertise but I would assume the rattles in the interior trim can be made to go away by putting grommets on the screws or sticky padding onto the rear of the offending panels where they are in contact with something else. Are these little details that can be done as the builds progress, and rectified on units already in service?
142Pilot
24 Sep 2018
You can’t beat inconveniencing your paying customers and then gloating about it.
Pure class.
The truth hurts.
And they way it's going that is exactly what is going to happen.
It's not gloating, I'd love to drive them. However their is an uglier bigger issue behind what I put.
The truth hurts.
Would that be a 3-letter issue starting with D in another thread? I'm sure I'd read that initial training will be for guarded operation?
If not, what other issue is there with them?
