superkev
Yes strange devices torque converters.Strange beasts, Voith hydrodynamic gearboxes. Three speed versions have only two gears. First speed involves a loose torque converter driving low gear, second consists of draining the converter and filing a fluid coupling which drives the same gear but with less slip and third speed uses another fluid coupling driving high gear. No friction materials and little to wear then.
They also do a shunter version which has two speeds (and one gear) in each direction, so no reverser needed and you can use the other direction as a retarder.
I suppose with all that slip and churning oil it's simplicity/reliability against efficiency.
Didn't I read that the SWT ZF fitted 159 is using 10% less fuel as well as being a bit quicker.
Missed opportunity i think for a some similar mid life 're engineering the Northern 158s rather than just redecorating them.
K
