Northern Dec 2019 Timetable Bid
Deerfold
26 Nov 2009
The Blackpool to York trains seem to drop Sowerby Bridge after the change, removing a third of the station's services.
Staffordian
11 Jul 2019
Northern have put their track access application in for the December 2019 timetable. It is now publically available at the following address: https://www.networkrail.co.uk/indus...on-operating-companies/sale-of-access-rights/
Whilst we won't see the timetable details for a while yet, I thought I would outline the main bits from the document.
- An extra daily service Middlesbrough to Whitby & return
- New daily service between Middlesbrough & Newcastle (10 north, 11 south) via Stillington & ECML calling Thornaby, Stockton, Durham and Chester-le-Street
- New Horden station added to calls on coast stopper
- 1846 Carlisle to Whitehaven moved to 2000
- A new Sunday morning 0830 Blackburn to Preston
- New service from Halifax to Hull via Bradford, Leeds & Selby including the current Leeds-Selby service. (Calls at Bradford, New Pudsey, Bramley, Leeds, Crossgates, Garforth, E Garforth, Micklefield, S Milford, Selby, Brough)
- Huddersfield-Leeds local service to be curtailed at Bradford
- An extra service Leeds to Hull / return, Huddersfield to Bradford / return
- Sunday Leeds to Lancaster services extended to Morecambe
- New daily service between York and Scarborough, 15 Mon-Sat and 13 Sunday services each direction (should be hourly).
- Linking the York-Hull & Hull-Bridlington together as one through service
- Alderley Edge & Stalybridge to Wigan services extended to Southport in place of existing services from Leeds & Blackburn that will be curtailed at Wigan Wallgate
- Hourly mid-Cheshire Sunday services
- 0749 Macclesfield-Manchester to start back from Stoke
It also mentions there were other services that they are currently unable to bid for due to pressures on performance that were promised in the TSR and they will continue pushing for these to be implemented.
As well as Middlesbrough - Newcastle via Stillington and hourly Sunday services on the mid-Cheshire line, the other proposal not to make it in is the hourly York - Scarborough service. Horden station is also not shown, but may be confirmed nearer the time. Everything else appears to be included.
Staffordian
11 Jul 2019
With the Huddersfield-Bradford-Leeds service being curtailed to Huddersfield-Bradford I hope Low Moor gains a call from another direct Leeds service, I don’t think a change at Bradford would go down well as I would estimate 90% of passengers boarding the current Leeds services all travel through to Leeds.
Indeed, the Leeds - Chester trains will stop at Low Moor from December. From Bradford, they are evenly spaced with the Bradford - Huddersfield trains, but unfortunately the northbound calls are only 7/8 minutes apart.
158756
12 Aug 2014
This was a recent (and rather strange, given the Northern Connect idea) addition to the Blackpool-York route. Did it replace calls on another service?
Deerfold
26 Nov 2009
Sowerby Bridge is supposed to get calls on this service because it's Northern Connect.
It returned Sowerby Bridge to Bradford to the 2tph it'd had for over 20 years but lost in 2009 (though a long way off being half hourly).
mrcaa
12 Mar 2019
Seems the lack of certainty of having enough drivers working on a Sunday has knocked out the December 2019 proposals for hourly Sunday services on Mid Cheshire Line. Been a franchise requirement for December 2017.
Two trains an hour on weekdays is still an "aspiration" as well .
Mike Amesbury MP blasts further delay to two trains an hour for Northwich passengers https://www.northwichguardian.co.uk...s-delay-two-trains-hour-northwich-passengers/
Is the "aspiration" still to have two trains an hour from Chester to Altrincham (with one of them continuing on to Manchester Piccadilly)? Wasn't the original plan to have a second train per hour from Greenbank to Manchester Piccadilly before that was quashed?
30907
One fairly random change in the data I've seen is this:
http://www.realtimetrains.co.uk/train/Y56865/2020/01/15/advanced
The Hexham to Danby train will now only go as far as Castleton Moor, but will call additionally at Kildale.
I do recall some saying that Castleton was a substantially more useful terminating point, considering that Danby station isn't all that close to the village?
Early morning service is also in the system as the 0453 Middlesbrough to Whitby and 0627 return.
Castleton Moor gives a better margin for delays.
rg177
International Transport
22 Dec 2013
Newcastle-upon-Tyne
The turnaround time is actually the same.
On closer inspection, the outward calls additionally at Great Ayton and Kildale (and obviously, Castleton Moor).
The return calls additionally at Kildale and Great Ayton too.
I do wonder if this is an attempt to attract an extra couple of passengers to the beyond Nunthorpe leg by stopping some more rather than just sending it fast(ish) to a stop where clearly it isn't getting much use.
158756
12 Aug 2014
Is this lack of staff (presumably so for the Sunday service), lack of trains or have Network Rail said no to the principle of there ever being a service via Stillington or 2tph to Scarborough?
It's a station to be served by Northern Connect because that encompasses almost every service along the Calder Valley. As far as I'm aware this never meant such a station would be served by every passing train.
Haven't heard about this for a while. Wouldn't be a surprise if it went on the back burner now they can't get to Manchester. If they are ever going to run a train terminating at Altrincham the line really needs to be rolled into the Metrolink fare system.
MetroCar4058
18 Jun 2014
Network Rail don't have the paths on the ECML for Stillington.
Glenn1969
22 Jan 2019
Halifax, Yorks
The new 2338 Leeds- Halifax is being extended to be a 2215 Hull- Halifax and depart Leeds 11 minutes earlier at 2327
northernchris
24 Jul 2011
There's some surprises in there such as the Sheffield - Hull stopper being split at Doncaster with the arrival from Sheffield going down to Adwick empty before coming back to form the return to Sheffield
Hoping there's still some more services to be added as some of the current additional peak services aren't showing
Killingworth
30 May 2018
Sheffield
Using Platform 0 more to reduce crossings over the ECML. Trouble is Platform 0 is a long hike for interchanging passengers.
Deerfold
26 Nov 2009
It's a station that has doubled its usage the last 10 years, with massive increases for years before that'll. It seems a shame to cut frequencies it used to have.
rick9525
13 Jul 2009
Any sign of the missing 23:00 Piccadilly to Hadfield Train which since the timetable change has left an hour gap at the time a lot of people are coming home from a night out? It was a big improvement to have half hourly throughout the evening but is very annoying this one is still missing.
John C
3 Dec 2011
The wolds coast route becomes mostly Sheffield-Scarborough throughout the day with one Scarborough-Hull-Selby-York service at 08:15.
Staffordian
11 Jul 2019
And also has much better connections with TPE services at Seamer. Now 7 mins at Seamer towards York - used to be 1 min, or in practice 61 mins. Towards Filey/Brid now 23/24 mins, rather than 54 and can also change at Scarborough, which would be an easier change.
MetroCar4058
18 Jun 2014
Does this mean the Newcastle-Middlesbrough via Stillington will never go ahead, or is it possible paths will be made available in the future?
I’m not sure, I didn’t find out that much detail. I’d assume they’d have to find a way around it as isn’t it a franchise agreement?
TBY-Paul
9 Feb 2013
If paths can't be found now, the chances of paths being found in the future are slim.
Because the junction at Ferryhill is on the flat it's not just a case of finding paths in one direction. eg a Middlesbrough to Newcastle service doesn't just need a path northward, you need a path clear on the southbound (up) line in order to allow the service to get from the Stillington line across the Southbound (Down) line to the Northbound (up) line. If the service was allowed it would use up more capacity than just the path needed for the service it's self. The current situation happens a Darlington, with limited access across the ECML.
I think the service is a commitment, but necessarily the route, in theory the service could run up the Durham coast line, missing out some stations. eg calls at Middlesbrough-Thornaby-Stockton-Hartlepool-Sunderland-Newcastle. It might give a slightly quicker service than the normal stopping service, but not much quicker.
edit :- after some consideration, I think the franchise commitment mentioned calls at Middlesbrough, Thornaby, Stockton, Durham & Newcastle. So now I'm not so sure.
**unfortunately my old laptop Hard drive failed a few months ago and I've lost all my bookmarks to various documents (which I'm slowly building up again on my new Laptop).
geoffk
4 Aug 2010
Likewise Mytholmroyd.
geoffk
4 Aug 2010
It seems odd for the Chester service to call at Sowerby Bridge and Mytholmroyd (and soon Low Moor also) while the service terminating at Victoria runs fast Halifax - Hebden Bridge. Presumably a pathing issue.
CJ
18 May 2009
Stockport
Majority of the Liverpool Lime Street - Crewe (via Manchester Airport) services and vice versa seem to be omitted from RTT (I'm guessing they haven't decided on what to do about these services)?
It also looks like the service patterns for the local stations on the Airport line will be changing again.
Marton
9 Nov 2008
The connections to TPE at Middlesbrough have been messed up again. Arrivals from Nunthorpe just after the TPE leaves: 45 minute wait quite often. It is now 20.
Sweetjesus
15 Jun 2019
For Stockport line, it appears that certain services are missing - not sure if they're actually removed or they're not inputted yet, an example being 0606 from Hazel Grove. I believe there are a few more missing throughout the day.
Greybeard33
18 Feb 2012
Greater Manchester
Timetables for the Atherton line have been loaded. These confirm that through services between Kirkby and Victoria are being restored, but still no 4th hourly service. The Leeds via Brighouse and Blackburn via Burnley services will mostly terminate at Wigan Wallgate, but a few will go to North Western in the peaks. No interworking.
The Southport services will all be via Bolton, with no more interworking between the Stalybridge and Alderley Edge services. The Stalybridge stoppers are still timed for a 75mph Sprinter throughout, so no credit for possible improved 769 performance under the wires between Bolton and Victoria. Southport to Victoria will take 80 minutes on the Stalybridge service, with stops at Moses Gate, Farnworth and Kearsley, versus 70 minutes on the current Leeds service via Atherton. I hope the users group are satisfied with their achievement!
Greybeard33
18 Feb 2012
Greater Manchester
There are also no Blackpool to Manchester Airport services loaded yet, only the Airport to Blackpools.
Airport platform allocations look a bit of a mess. The Lime Street to Airport semi-fasts are mostly stacked on top of the TPE Cleethorpes trains, which will not fit if TPE strengthen these to 6-car double 185s as promised.
Amstel
24 Jul 2018
The Hazel Grove trains are timed as 323s, the current timetable is for 319s. Are we getting our 323s back which we lost over 20 years ago?
