Greybeard33
Annoyingly the running time is 37 minutes (Ormskirk being 32), which makes both quite wasteful of units to do an hourly service. Colne is 1h10 which is similarly bad. I can see the benefits of joining them up (e.g. Ormskirk + Colne = a cycle of 1h42 each way with 18 minutes layover, which is a reasonably decent fit for 4 units), but also the problems it has clearly caused.
I guess it's just one of those things where the Takt has more benefit than not using the extra unit, particularly towards Blackpool. There doesn't seem anywhere else obvious to send it.
The M-F interworked diagrams have 1h5 layover in P3C/4C, between arrival from Colne and departure to Ormskirk. This is roughly the same as the sum of the three layovers at Preston for the Saturday split diagrams. So no extra unit needed on Saturday, unless the Blackpool diagrams are strengthened. Not sure about the crew diagrams, though.This has been happening on Saturdays for quite a while now. Blackpool South trains terminate in P1 at Preston then clear off to a siding outside the station for half an hour before coming back into P1 a couple of minutes before the departure time. The Colne and Ormskirk trains use 3C and 4C all day.
Who do you suggest should fine whom?If any sense, huge fine (5 figures) for every train not reinstated after the half term.
