Northern Unit Refurbishments
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
Personally it'd make sense to retain them incase the other bog breaks and I think it'd be pointless taking the redundant cabs out of the /2's as a future franchise holder may wish to use them in the short term before replacing them.
Have the eight 150's that are to be reformed into hybrids been chosen yet?
I think that the ex GWR units will be on the list so that their introduction does not disrupt normal services. I think that 150 124 might be on the list.
pemma
23 Jan 2009
Knutsford
The existing toilets will have to be removed, replaced or locked out-of-use even if a new accessible toilet is fitted in the same set. While the second toilet doesn't have to wheelchair accessible it would have to be a lot more like the second toilet on a 185 which still caters for passengers with sight issues, even though it's not a fully accessible toilet. Plus dumping waste on the track has will be banned from 1st Jan 2020.
Arriva Rail North have leased the 150s until 2025 (when they will be 40 years old.) I'd be surprised if any future operator makes long term plans for their use. Presumably if the redundant cabs are removed it'll be the 8 x 150/2s which are least reliable which get broken up to become centre cars.
There is no practical difference between the small bog on a 350 (say) and that on a 150, other than some Braille stickers which is easy enough to do. The 185 appears to have a different design which is sort of a medium sized half way house, but this design is clearly not mandatory as it features only on 185s and 700s.
OK, there are the stupid automatic taps[1], but I can't see why those should be a requirement; just about everybody uses conventional taps at home, the only kind you see in adapted homes are the type with a larger lever on the tap for easier turning which are cheap enough.
The main reason to replace the bog is to avoid it dumping on the track.
[1] The most stupid of all of those are the ones on new Electrostars which mandate me to dump a "serving" of soap in the sink before I can turn the water on to clean my spectacles. Insane.
pemma
23 Jan 2009
Knutsford
Some non-PRM modified 150 toilets have floor based buttons you have to stand on to make the toilet flush or make water come out of the tap - I'm not sure that's allowed even in the second toilet.
This kind of kitchen tap design is suitable for most, including those with arthritis: https://www.plumbworld.co.uk/images/silksteel-product-25430-gallery-TmAf-default-H.png Although, for a train toilet you wouldn't want such a big loop on the section the water comes through.
I had the same issue in a public toilet the other day. Something had splashed on my coat and I just wanted a bit of water to wash it off but the handwash machine doesn't allow you access to the water before it's given you some soap.
Possibly not, though it isn't a difficult thing to change, just "plainline" the valve in the foot tap (you wouldn't even need to remove it) and fit a regular tap to the sink. This was done to at least some Mk2s and Mk3s ages ago.
You'd also want a version of it that slowly turns itself off. I'd imagine that exists, though.
The tap you pictured is a kitchen tap, anyway; there will be a bathroom version with a smaller loop.
Yeah, it is really quite annoying.
NorthernSpirit
21 Jun 2013
I were thinking of private charter firms (or even the desperate DRS who want to get into the passenger market) may take them on and reforming them further into five or six car units, which might be ideal for the various events such as Christmas markets, airshows, balloon fiestas, music events, etc... which would provide enough space for everyone flocking to them. Which why I thought it'd be pointless taking the second bog out, even if a 150 ended up with two new PSVAR bogs - one would have to be ripped out rather than retaining it, as these new vacuum bogs aren't exactly top notch when it comes to trying to flush the things as the tanks are full.
Whoever takes over from Arriva Rail North may well use some of the decent 40 year old class 150s to run the parly services with whilst everyone else gets the 'new' stuff.
507021
19 Feb 2015
Chester
A posting on Facebook says 155347 is heading to Kilmarnock now, so presumably 155345 is on its way back to Neville Hill.
brel york
4 Feb 2011
the plant
Porter brook 150s have controlled emission tanks fitted with the new toilet , the angel ones don’t yet but it’s getting fitted
The button on the floor uses a vacuum to push water to the tap , it’s a length of plastic pipe from the floor up to a tap in the cupboard , this pushes water out of the tap at the sink
brel york
4 Feb 2011
the plant
The porter brook 150 have **** tanks fitted , the angel ones don’t yet but it’s coming
M1544
20 Sep 2016
it deffo had Led tail lights as I saw it aswell. Had yellow topped seat handles but couldn’t tell what moquette was on them.
boeing737229
7 Apr 2017
The original version didn’t use the colours from the Arriva style guide.
Surely the ARRIVA Turquoise fitted in better than yellow!
The new uniforms use Arriva turquoise, so itd make sense for the handrails etc to all be in Arriva turquoise too
ash39
8 Feb 2012
I believe 124 is also with Northern, but it's gone to Crewe, presumably for mods & repaint?
Does anyone know if there's any chance of the any of the ex-GWR 150's being pressed into service in current condition, or is the plan for them all to be 'Northernised' before service entry?
sd0733
7 Nov 2012
150222 was sitting on Newton Heath last night looking very shiny In new Northern livery
150122 and 102 newly arrived from GWR were round the back visible from the tram still with full FGW branding
brel york
4 Feb 2011
the plant
102 is due at Doncaster on the 18 dec for prm mods & corrosion
