Northern withdraws some CAF trains due to yaw bracket failures
Bayum
21 Mar 2008
Are there any pictures of what the yaw dampers should look like to compare against the ones pasted earlier?
Adam0984
18 Feb 2014
Yes there is a temporary fix being applied with the previously mentioned 331s been the first to get the modification
superkev
1 Mar 2015
west yorkshire
Is the fix in the picture from post #233 above the one being applied. If so looks quite substantial and permanent.
Thanks
K
js1000
14 Jun 2014
Liverpool to Manchester Airport express service to resume on Monday. That resumption was delayed from the May timetable change so seems as if Northern are now on top of this issue.
Jamesrob637
12 Aug 2016
Aren't those only in the peaks anyway even non COVID?
Yes that is the modification being applied, hopefully they will all be back in service by the weekend.
That looks like it will spread the load over a wider area to prevent future damage to the T slots, but it’s not clear to me if it will also be a satisfactory repair to any T slots that are already damaged/broken?
9 Dec 2012
What are the chances of these being back on Barrow services on Monday, I'm travelling between Barrow and Preston and could do with the superior wifi before I get in a Pendo to Euston !
josla1
10 Apr 2020
Warrington
Majority of Barrow/Windermere to Manchester via Preston have been 195’s anyway. There has been one daily diagram of a 156 from what I’ve seen whilst working. The rest have been 195’s.
skyhigh
14 Sep 2014
I believe it's just a temporary fix to get all the sets back into use while a proper repair is worked out - the trial unit definitely still had a visible crack when I saw it last. Mind you, I've been off a couple of weeks, and given how quickly things are changing they could well have a permanent fix now
If it spreads the load widely enough, then maybe it doesn't matter that part of the T-slot is damaged.
Ben Anslow
13 Jul 2017
Surely they will have or had fixed it to some degree either way having seen pics of 195021 a few weeks ago (on this thread I think) a permanent solution is on the drawing boards be interesting to see if ride quality improves a little bit
Possibly, but doesn’t seem the best quality engineering to hide something that’s damaged. Be interesting to see if it really is a “temporary” repair as well…
As it's only bolted on, it could be removed periodically for inspection. If the structural analysis suggests it will last indefinitely, and the inspections show no deterioration, then there's no real reason to touch the aluminium.
HSP 2
4 Dec 2019
11B
We were out on Saturday 5/6/21 and seen a 195/0 (024?) with the modification. But what we did notice was that the mod. had only been applied to the gangway end brackets and not to the cab end brackets. This got us thinking on a three or four car set have the mods. been done to all of the brackets on the intermediate coaches.
This also lead us to thinking could? this also be related to the first set of problems with these units, the intermediate couplings. The last part is only a guess but normally one fault can lead onto another one.
Ben Anslow
13 Jul 2017
I don’t think any of the dampers at the cab ends have as much issue with stress as the engine weight is towards the rear of the carriage which is where most cracks had been found. I’m not sure if I am completely correct here but I believe they didn’t give very much specification requirements to caf at first hence these issues the coupler issue was noticed I believe after testing on the Furness line going around the extremely tight curve at Carnforth
mbonwick
26 Oct 2006
Kendal
It matters.
This is only a temporary solution anyway, as eventually it will cause the same damage to the T-slots - it'll just take longer as there are more attachment points. Unlike steel, aluminium does not have an endurance threshold and will suffer fatigue at any loading.
HSP 2
4 Dec 2019
11B
This is what a yaw damper should look like its the long horizontal tube like part. HTH
It matters.
Do you know for certain that it matters or is this your opinion? Apologies if I've missed it, but I've not seen any official information that the solution is temporary.
The fact that aluminium has a finite fatigue life means any solution will fail eventually - it's just a question of pushing that life out to longer than the life of the train. Something we need to be aware of on this forum in 30 years time when we're discussing yet another life extension for 195s.
Adam0984
18 Feb 2014
It is a temporary solution to get them back in service.
Northern and CAF (and I suppose will involve WMT and TfW) are working for a long term solution. The data from 195002 and the measuring device that was fitted will contribute to this solution and what strains the trains actually go through
mbonwick
26 Oct 2006
Kendal
I know - my job and background is as a metallurgist, albeit not in the rail industry.
Seeing the design up close, I (and a lot of colleagues and other technical railway observers) can't believe that it was ever accepted into production, let alone service - this issue was clearly inevitable.
